Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025
4.7.2025 (Friday) 14:48 - All running AOK
Posted by grahame at 11:46, 4th July 2025
Oh yes it does - won't it reduce the loadings by having people miss connections, and increase the passenger angst and chance of passenger disturbances on the branch trains?   The JourneyCheck wording written from an operational rather than from a passenger journey viewpoint?
You’re saying it would have been more sensible to write “We apologise, but this will increase the likelihood of a passenger disturbance on branch line trains, but your train might well be quieter.”
"The trains on the branches will be running at normal times, but connections may not be made so you may have to wait for the next train?
Posted by bobm at 10:00, 4th July 2025
Particularly disruptive missing Twyford, given it is Henley Royal Regatta this week.
Posted by IndustryInsider at 09:50, 4th July 2025
Posted by grahame at 08:26, 4th July 2025
The majority of our services between Reading and London Paddington will not be able to call at Twyford, Maidenhead or Slough. Please see details on alternative services below. Please note, this does not affect our Henley, Marlow or Windsor branch line services.
Edit to correct quoting
Posted by TaplowGreen at 07:33, 4th July 2025
Due to engineering works not being finished on time between London Paddington and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 07:10 04/07.
Due to engineering works not being finished in time, the line between London Paddington to Reading will be delayed; altered or cancelled.
Rail replacement services are not in operation
Delays/cancellations now until 0830
Our high speed long distance trains that only run between Oxford and London Paddington will not run. Our high speed long distance trains between Worcester and London Paddington will still run which means Oxford will see an hourly service to / from London Paddington.
If you're travelling to or from Twyford, Maidenhead or Slough, you will need to use Elizabeth Line services. Please note, Elizabeth Line services are also affected by this problem. For more information regarding Elizabeth Line services, please visit www.tfl.gov.uk. Your GWR tickets are being accepted on this route at no extra cost.
Posted by TaplowGreen at 05:49, 4th July 2025
Posted by NickB at 18:18, 2nd July 2025
Delays still occurring at Slough
Posted by TaplowGreen at 16:50, 2nd July 2025
Delays to services at Slough
Due to damage to the overhead electric wires at Slough trains have to run at reduced speed on some lines.
Train services running through this station may be delayed. Disruption is expected until 17:30 02/07.
Posted by TaplowGreen at 14:18, 1st July 2025
Delays to services between London Paddington and Slough
Due to a points failure between London Paddington and Slough some lines are blocked.
Train services running to and from these stations may be delayed by up to 20 minutes. Disruption is expected until 15:30 01/07.
Elizabeth Line suspended Paddington to Reading/Heathrow.
Posted by TaplowGreen at 17:46, 24th June 2025
Alterations to services at Twyford
Due to a fault with the signalling system at Twyford trains have to run at reduced speed on all lines.
Train services running through this station will be delayed or terminated at and started back from Reading.
Some stations between Reading and London Paddington will not be served. Disruption is expected until 18:15 24/06.
Posted by TaplowGreen at 10:59, 23rd June 2025
Alterations to services between Oxford and Didcot Parkway
Due to a safety inspection of the track earlier today between Oxford and Didcot Parkway all lines will be blocked.
Train services running through these stations will be delayed or revised. Disruption is expected until 12:00 23/06.
Posted by NickB at 17:26, 20th June 2025
Line side fire at Acton causing delays from paddington now. Most Elizabeth Line trains cancelled.
Lovely day for it.
Posted by TaplowGreen at 13:28, 20th June 2025
Due to a fault with the signalling system at Burnham fewer trains are able to run on some lines. Disruption is expected until 15:00 20/06.
Train services between Reading and London Paddington may be cancelled, delayed or revised. Twyford, Maidenhead and Slough will not be served.
Due to a fault with the signals in the Burnham area, we have had to reduce our train service in the Thames Valley this afternoon.
Posted by a-driver at 22:53, 19th June 2025
Not a very good day......
Alterations to services at Didcot Parkway
Due to a points failure at Didcot Parkway some lines are closed.
Train services running through this station may be delayed or revised. Disruption is expected until 18:45 19/06.
Better than I expected though considering air temperatures hit over 32°c in London
Posted by TaplowGreen at 17:02, 19th June 2025
Posted by TaplowGreen at 14:16, 19th June 2025
Cancellations to services between Newbury and Bedwyn
Due to a fault with the signalling system between Newbury and Bedwyn all lines are disrupted.
Train services running through these stations will be cancelled. Disruption is expected until the end of the day.
Due to an issue with the signalling system between Newbury - Bedwyn the service will be suspended until further notice.
Posted by TaplowGreen at 14:13, 19th June 2025
Delays to services between London Paddington and Reading
Following a fault with the signalling system between London Paddington and Reading some lines are now open.
Train services running to and from these stations are returning to normal. Disruption is expected until 14:30 19/06.
Due to a signalling issue lines between London Paddington - Reading, some services maybe delayed, altered or cancelled.
Posted by TaplowGreen at 11:55, 19th June 2025
Cancellations to services between Newbury and Reading
Due to a fault with the signalling system between Newbury and Reading some lines are blocked.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 12:30 19/06.
Due to a fault with the signalling system at Newbury, the lines are block between Newbury to Reading in both directions.
Services will be delayed; altered and cancelled as a result.
Posted by TaplowGreen at 16:28, 18th June 2025
Cancellations to services between Oxford and Didcot Parkway
Due to a fault with the signalling system at Oxford fewer trains are able to run on some lines. Disruption is expected until 18:00 18/06.
Train services between Oxford and Didcot Parkway may be cancelled, delayed or revised.
Posted by TaplowGreen at 07:41, 18th June 2025
A fault with the signalling system at Slough means that Elizabeth line trains must run at a reduced speed on some lines. Services operating through Slough may be delayed by up to 15 minutes or cancelled.
Disruption is expected until 12:15
Posted by TaplowGreen at 18:12, 11th June 2025
Delays to services between Twyford and Maidenhead
Due to a safety inspection of the track between Twyford and Maidenhead trains have to run at reduced speed on the line towards London Paddington.
A small section of the railway line between Reading and London Paddington is closed whilst Network Rail carry out a safety inspection. GWR can still run trains safely, as other tracks are available for use, but this will lead to some congestion and slower running as trains make their way through.
Posted by nickswift99 at 08:51, 11th June 2025
Another bridge strike at Burnham this morning. Trains being cautioned over the affected area.
Posted by charles_uk at 11:33, 10th June 2025
Alterations to services between London Paddington and Slough
Due to a safety inspection of the track between London Paddington and Slough some lines will be blocked.
Train services running to and from these stations may be delayed or revised. Disruption is expected until 13:45 10/06.
Doesn't seem to be causing significant issues at the moment but the disruption until guestimate has been extended from 11:15 to 13:45 so far...
Posted by Electric train at 17:15, 9th June 2025
Alterations to services between London Paddington and Reading
Due to the emergency services dealing with an incident between London Paddington and Reading some lines are closed.
Train services running to and from these stations may be delayed or revised. Disruption is expected until 12:45 09/06
Rapidly pushed out to 1400 & now 1500
National Rail reporting no Elizabeth Line services between Paddington-Heathrow/Reading......Advice seems to be to go via Waterloo.
Report in a local news paper https://www.sloughexpress.co.uk/news/traffic-and-travel/201654/major-disruption-on-london-paddington-to-reading-train-line-after-casualty-on-tracks.html?utm_medium=Social&utm_source=Facebook&fbclid=IwY2xjawKz5whleHRuA2FlbQIxMABicmlkETBYRnJvRkR2RzlQTXE5SURwAR7k8vmJj-al5-L4zohMl9WOPau7kOswUS93SrOABFN-7PQzBg3_My5mDdXnDw_aem_J2_-9E6iEUR1Ri7n9xWwOw#Echobox=1749471219
Casualty on the tracks at Hanwell station
Posted by TaplowGreen at 13:16, 9th June 2025
Posted by TaplowGreen at 12:33, 9th June 2025
Posted by Electric train at 13:14, 5th June 2025
Burnham Station, according to the Bucks Free Press.
https://www.bucksfreepress.co.uk/news/25214998.burnham-station-bridge-lorry-crash-roof-ripped-off/
Would seem to have been a bit of sandwich
Posted by Chris from Nailsea at 16:53, 4th June 2025
Posted by TaplowGreen at 16:48, 4th June 2025
Does anyone know which bridge was struck?
I believe it was Burnham.
Posted by Hal at 13:39, 4th June 2025
Posted by TaplowGreen at 13:09, 4th June 2025
Due to a road vehicle colliding with a bridge earlier on this train's journey between Slough and Reading trains have to run at reduced speed on some lines.
 Disruption is expected until 14:00 04/06.
Posted by Fourbee at 12:17, 30th May 2025
There's an article in this month's Rail magazine with some of the people working on Project Brunel (the project tasked with improving the performance of the infrastructure between Reading and Paddington). Fairly interesting read.
My main recollections: undergrowth was cut back that was tripping the OLE, too many/heavy trains using it (broken rails), pigeons nesting in bridges culled particularly at Ealing Broadway as they were tripping the OLE when a train passed, 777 axle counters replaced that still get loose, but are monitored/tightened before they fail again, addressing wet bed issues to do with drainage being covered over when track was realigned.
This may not have been the sentiment intended or I misread it: the team want to maintain the current level of progress without slipping back (!).
Posted by TaplowGreen at 14:22, 29th May 2025
........and it's fallen over again.....
Cancellations to services between Slough and London Paddington
Due to urgent repairs to the railway between Slough and London Paddington some lines towards London Paddington are closed.
Train services running to and from these stations may be cancelled, delayed by up to 20 minutes or revised.
Disruption is expected until 16:15 29/05.
Posted by a-driver at 17:30, 28th May 2025
Interesting - GWR has said that all lines are open, speed limit imposed, expect delays - proper fix tonight
IETs will probably run diesel Paddington to Reading.  Possibly a minor issue like a broken dropper wire
Posted by ChrisB at 16:59, 28th May 2025
Posted by TaplowGreen at 15:22, 28th May 2025
Due to damage to the overhead electric wires between London Paddington and Reading some lines will be blocked.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 13:30 28/05.
No damage confirmed. A trains pantograph automatically dropped. That could be caused by damage to the overheads but it could also be an issue with the pantograph itself or just a spurious fault.
NR will inspect all 4 lines first as a precaution
Delays & cancellations now until 3pm......or will it be the familiar/dreaded "until the end of the day"?
........and it's now pushed out to 1800 on National Rail.....
.......and almost inevitably.....
Elizabeth line between Shenfield and Heathrow Terminal 5, and also between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading
Great Western Railway on all routes to / from London Paddington
Heathrow Express between London Paddington and Heathrow Terminal 5
Damage to the overhead electric wires between London Paddington and Southall means some lines are blocked.
Trains between London Paddington and Heathrow Airport / Reading may be cancelled, revised or delayed by up to 20 minutes.
Posted by TaplowGreen at 14:50, 28th May 2025
Posted by TaplowGreen at 14:40, 28th May 2025
Posted by a-driver at 13:02, 28th May 2025
Posted by nickswift99 at 12:53, 28th May 2025
There was a signal failure yesterday between Reading and Paddington. Journeycheck then reported further delays due to trespassers on the line. Was there an unexpected detraining somewhere?
Posted by TaplowGreen at 12:40, 28th May 2025
Posted by TaplowGreen at 06:07, 28th May 2025
Cancellations to services between Bourne End and Marlow
Due to a fault with the signalling system between Bourne End and Marlow all lines are blocked.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 06:45 28/05.
Posted by TaplowGreen at 05:02, 21st May 2025
Due to engineering works not being finished on time between London Paddington and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 07:00 21/05.
Due to engineering works not being finished on time between London Paddington to Reading, trains will be delayed, altered or cancelled as result. Speed restrictions may apply.
Posted by TaplowGreen at 20:37, 17th May 2025
From National Rail, apparently the problem is at Southall.
between London Paddington and Heathrow Terminals / Reading
Lines have now reopened following a safety inspection of the track between London Paddington and Heathrow Terminals / Reading. As normal service resumes, trains may still be cancelled, delayed by up to 10 minutes or revised.
Disruption is expected until 21:15.
Posted by TaplowGreen at 07:22, 13th May 2025
Ongoing from yesterday.......
Alterations to services between Bourne End and Marlow
Train services running to and from these stations will be suspended.
Posted by Electric train at 06:33, 11th May 2025
ORR» has made it quite clear to NR that working on a !live" railway is basically no longer permitted without very stringent control measures
Would it be a good idea if the Office of Rail and Road also had responsibility for regulation of road safety? It might, for example, encourage ORR to develop policies that minimise overall casualties, instead of deterring people from using rail and pushing them onto a more dangerous mode of transport.
The ORR regulate health and safety (eg 1974 Health and Safety at Work Act for workforce safety) for the entire mainline rail network in Britain, as well as London Underground, light rail, trams, and the heritage sector, were as for highways this duty lies with the H&S Executive
Posted by grahame at 06:13, 11th May 2025
(Caution: this is a joke)
Might be interesting to see how that works out. Perhaps everytime a repair is necessary on a motorway we can shut it completely until it’s fixed.
Customers/drivers can just find another way home, like taking the M40 and M5 rather than the M4.
Many a true word written or asked in jest - "reductio ad absurdum".  At times it feels like the spirit of thoughtful comedy.  And that is - emphaticlally - not - a joke.
Posted by NickB at 00:22, 11th May 2025
Posted by Trowres at 21:30, 10th May 2025
Posted by Electric train at 06:39, 10th May 2025
Is the absence of crew that are able to make the repair during daylight hours a new thing or a recent (past 5yrs) thing?
From a non-expert/passenger perspective it seems remiss not to be able to fix problems for 12+ hours after they occur, but is the logic that the disruption to fix during daylight hours is => than managing the closed line for a day?
Very good question, certainly the habit of routinely forecasting disruption "until the end of the day" seems quite a recent development.
I too do find the idea that there is no-one available from Network Rail to react to this type of incident for 12 hours incredible, especially given the significance, and state of the infrastructure in the Paddington-Reading area - these are hardly isolated incidents.
I suspect that the issue may relate to access for staff to a live railway.   In older day and you still see it in other counties, trains run on adjacent lines while work is ongoing but in order to reduce / eliminate as far as possible casualties, it's very rare if at all these days.  So that means as nighttime stoppage ...
I feel for staff having to put a time on disruption and how long it will go on.  The honest thing to say is "we don't know" but that is not helpful without an estimate, and systems are not set up to say "probably" and "possibly" and "if we're lucky", and I'm not sure how such terms and information would be taken by members of the public who are less analytic than readers here.
There is are a number of reasons why the repair cannot be undertaken in the day.
NR has geared up it workforce to carryout maintenance on track to nights, for a number of reasons first is workforce safety, the ORR has made it quite clear to NR that working on a !live" railway is basically no longer permitted without very stringent control measures, second is performance maintenance during the day would impact on service performance.
On and Off tracking the OTM's (on track machines) to move the equipment and materials to site during normal train running is high risk, also the OTM's may be in the wrong place and need transporting by road.
If a temporary repair could have been made then it would have with reduced speed.
The question that I am sure the Route and TOCs will be asking is why yet another "catastrophic" broken rail on the Western ML
Posted by TaplowGreen at 20:10, 9th May 2025
I tend to reserve my feelings for the customers- those who have paid for a service and end up being massively inconvenienced, time & time again on this route.
Those "having to put a time on disruption" at least have the comfort of being paid to do so.
Posted by grahame at 18:16, 9th May 2025
Posted by TaplowGreen at 17:20, 9th May 2025
Posted by NickB at 17:13, 9th May 2025
Posted by UstiImmigrunt at 16:30, 9th May 2025
Correct, no staff available during the day to replace the rail. There is tonight but it means cancelling the booked possession on the relief lines.
I've seen a picture of the broken rail and it is a bad break with the pandorol clip detached from the hook and a few inches away from the rail.
Posted by TaplowGreen at 09:52, 9th May 2025
Due to a broken rail between London Paddington and Reading some lines are blocked.
Train services running to and from these stations will be cancelled or delayed by up to 60 minutes. Disruption is expected until 09:30 09/05.
Due to a broken rail at Slough services passing through this area will be delayed, altered or cancelled.
And now........"Disruption is expected until the end of the day"
Posted by TaplowGreen at 08:53, 9th May 2025
Posted by TaplowGreen at 09:14, 1st May 2025
Due to a points failure between Newbury and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 10:00 01/05.
Due to an Axle Counter Failure near Thatcham Station, the line towards Reading is delayed. Trains maybe cancelled, altered or delayed as a result.
Posted by TaplowGreen at 17:47, 30th April 2025
........for future reference, a warm (26°) sunny Spring day now apparently constitutes "severe weather" for the purposes of the railway.
Customers on platform/concourse utterly incredulous (especially those from genuinely hot countries struggling to get to Heathrow) when the announcement was made.
Kudos to rail staff who were advising people of this dramatic meteorological phenomenon and managed to keep a straight face.
Posted by TaplowGreen at 15:11, 30th April 2025
First warm day of the year so of course the railway melts down........
Due to a speed restriction because of high track temperatures between London Paddington and Reading fewer trains are able to run.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 17:00 30/04.
Posted by TaplowGreen at 19:41, 29th April 2025
Due to a points failure between Reading and Newbury some lines are blocked.
Train services running to and from these stations will be cancelled, delayed or diverted between Reading and Taunton. Some stations between Reading and Taunton will not be served. Disruption is expected until 13:15 29/04.
A few diverted trains resulting.
Still ongoing, now forecast disruption until 2000
Posted by GBM at 11:44, 29th April 2025
Posted by TaplowGreen at 20:17, 28th April 2025
Due to a points failure between Reading and Newbury some lines are disrupted.
Train services running to and from these stations may be cancelled, delayed or revised. Some stations between Reading and Taunton will not be served. Disruption is expected until 14:30 28/04.
14:03 London Paddington to Penzance due 19:25
14:03 London Paddington to Penzance due 19:25 will be diverted between Reading and Taunton.
It will call additionally at Westbury.
It will be delayed due to the diversion and is expected to be 33 minutes late.
Last Updated:28/04/2025 14:17
Previous train (13:03) terminated short at Reading.  And it looks like this one can slip through the single line section between Chippenham and Trowbridge between local trains - good.
"Until 14:30"?  No - the disruption to the 14:03 has it being forecast 33 minutes late into Penzance at 19:58 rather than 19:25,  so disruption until 20:00?
Disruption still ongoing.
Posted by grahame at 14:32, 28th April 2025
Posted by TaplowGreen at 14:15, 28th April 2025
Posted by TaplowGreen at 15:46, 25th April 2025
Guess what?
Due to a points failure between Reading and London Paddington trains have to run at reduced speed on some lines.
Train services running to and from these stations will be cancelled or delayed by up to 40 minutes. Disruption is expected until the end of the day.
Due to a points failure at Slough West the line between Reading to London Paddington will be heavily delayed.
There is also a points failure at Maidenhead East causing delays.
Last Updated:25/04/2025 15:06
Held together with tape and bits of string.
Posted by charles_uk at 15:19, 25th April 2025
Guess what?
Posted by a-driver at 20:07, 22nd April 2025
Following damage to the overhead electric wires at London Paddington all lines are now open.
Disruption is expected until 19:00 22/04.
Train services between London Paddington and Reading may be cancelled, delayed by up to 45 minutes or revised
Not strictly damage to the overheads.
The pantograph on a train heading into Paddington automatically dropped. This could be due to a defect with the overheads but it could also be a train fault or just a spurious fault.  NR will examine the overheads on the line or lines where the fault occurred as a precaution, especially if the driver can not see any obvious damage to the pantograph on the train.
Posted by NickB at 19:31, 22nd April 2025
Now 20:00
But let’s face it, in a few minutes it will change to ‘until the end of the day’.
Posted by TaplowGreen at 17:33, 22nd April 2025
Posted by Mark A at 14:43, 22nd April 2025
Agreed.
Perhaps what the industry could avoid though is the appearance that they're still promoting 'X' as their primary channel for information - the National Rail web site's a case in point and it's a practice that has a very 2012-era vibe. A current example: regarding the issue with the bridge in Cardiff, on the NR disruptions list, the site's (again) advising 'End of the day' and the first source of information offered is a web link to a (hijackable) hashtag on their 'X' feed - so they're linking to something that is no longer a public web site: there's little to no information in the public domain as to what the issue actually is and the time needed for a temporary/permanent fix.
https://www.nationalrail.co.uk/service-disruptions/cardiff-central-20250420/
Posted by grahame at 13:07, 22nd April 2025
Reducing the comms to a template pick-and-mix template message of the sort:
'Due to'... a fault on a train/lack of staff/delay to a previous service ... 'the' {service} 'is' delayed/cancelled/scrapped. 'We're very sorry for the delay.'... is an approach that delivers an information-poor environment to the intending traveller.
Yes and no - reducing it purely to that is poor - however, to get something out quick when time is of the essence of staff are rushed of their feet makes sense
Posted by Mark A at 12:33, 22nd April 2025
Good point. An issue is the quality, style, and depth of the information that finds its way to rail industry web sites, and the fragmentation of the industry itself.
South Eastern Railways, or was it the part of Network Rail that cares for the track in that part of the world, when something happened that impacted the service, developed the habit of using Twitter to communicate in detail & in an accessible form, as to how a particular issue was being tackled and when something would be fixed, and many people found this genuinely helpful in planning their use of the railway.
Also, starting a sentence with 'Due to' is less than ideal.
Posted by grahame at 12:26, 22nd April 2025
There's no need for train operators to maintain teams looking after all the various social media outlets, just one well-resourced one supplied with up-to-the-minute information from "Control" and the depots and staff on the ground.
Agreed - a single site with web site and app interface to the same data.
Perhaps at a URL like https://www.greatbritishrailways.info
There's no reason why anyone should expect X, Bluesky, Facebook, Instagram or any other such service to be a main source of travel information
Correct - and especially avoiding a requirement to sign up to a network of private content, especially one that has gained political overtones.  There IS the need to run 24x7 and to be robust and have a findable alternative in the event of IT issues, a need to cope with high volumes, to protect against spam, to make it easy to find what's needed, and to answer both privately where appropriate, and in public where lots of people will have the same questions.
Posted by eightonedee at 11:47, 22nd April 2025
Seeing the discussion above (and being very glad that our "stay at home over bank holiday weekends" policy was vindicated again!), can I make what might be a controversial suggestion on social media?
If you have a smartphone, and access to social media, you will have access to the train operator's own website and on-line information system. The world of social media is an ever-fragmenting one, making it ever more difficult to keep all their subscribers informed by their means.
So, wouldn't it be sensible for train operators instead to concentrate on keeping their own sites up-to-date (and more importantly, supplied with full and up-to-date information on all train problems, so that (for example) Grahame would have been able to find out whatever caused the two cancellations immediately it happened - or at least have been warned about them in good time.
There's no need for train operators to maintain teams looking after all the various social media outlets, just one well-resourced one supplied with up-to-the-minute information from "Control" and the depots and staff on the ground. Perhaps if there are spare staff as a result, they can be employed in liaising with bus companies and taxi operators to summon help, and perhaps recruiting and running a back up system of out-of-hours emergency services from them run on a retainer contract basis.
There's no reason why anyone should expect X, Bluesky, Facebook, Instagram or any other such service to be a main source of travel information, any more than they should rely on them for up-to-the-minute football scores or commodity market prices. Just have plenty of posters and notices at stations and in trains with the operator's web address - or better still, screens with live information relevant to the site or train in question.
Posted by Rob S at 10:21, 22nd April 2025
I was caught up in the situation last night, trying to catch the 1950 from Plymouth to Swindon direct, initially cancelled from Plymouth onwards when I arrived at the station on foot (about 1920) we were told to catch the 2025 to Exeter, then a service from there to Bristol and then the last train might be held for us there, or taxis etc.
In the end after the train pulled in to Plymouth (about 1944) and everyone got off I noticed at 1956 that the relevant platform departure board was now saying the 1950 to Paddington was going to leave at 1957....then we had an announcement that it was reinstated but would be leaving at about 2010 awaiting the driver....it eventually left at 2025 as the original 2025 to Exeter (coming up from Penzance) was cancelled. In the end I got to Swindon about 40 minutes late.
Posted by ChrisB at 09:29, 22nd April 2025
It'll all be down to what the DfT wants these days
Posted by Mark A at 09:24, 22nd April 2025
At an absolute minimum, customer service channels such as Twitter should not be closing in the early evening when these sort of (increasingly frequent) meltdowns are ongoing - it never used to close so early, then we had a spate of early closures due to "staff sickness", and since then it closes at 7pm every day - it really doesn't take long to train someone to answer Tweets, and it's a means by which customers at home/in the office can make an informed decision as to whether it's worth trying to travel.
In defense of anyone working on the task of fielding enquiries via social media, carrying that role out well does draw on various skills.
That aside, there's an argument in favour of the railway changing the tools they use for this. Twitter very much proved its worth for timely customer support, and it might be that a response to an individual enquiry helped several others in the process and also possibly helped staff be informed of situations.
'X' has very much changed in the way it works and is now a closed system, its content not available on the web, responses are available only to people with an account and logged in. A percentage of people who use the trains have moved away from 'X' entirely and companies who use 'X', given the general shenanigans, are starting to see a certain amount of tarnishing of their brand.
Perhaps railway managers view social media for customer support in times of disruption isn't as useful as it once was - evidenced by the fact that the hours of the day during which rail companies offer support via 'X' are shrinking, and there's less of an effort to react to events by strengthening this support in time of need.
One of the decisions to be made is whether to let this slide continue, or as an alternative, follow the users of their services to the social media that they now use. GWR looks to be on the way to doing this, in that they've created their account on Bluesky (~35 million users of which ~7.5% are in the UK) and are using it for the time being for promotion rather than customer support.
Now, it's very difficult for an organisation to walk away from an account where they see they have a million followers, so, it would be informative to know the cost implications in using both of these two platforms in parallel for customer support - given the tools that they'll be using, the additional task would likely be a small percentage, and for a considerable gain in terms of reach. One aspect alone, the open-ness and far greater availablity of other systems, is well worth consideration.
Posted by TaplowGreen at 07:24, 22nd April 2025
............really couldn't make it up..........
Due to earlier engineering works not being finished on time between London Paddington and Slough fewer trains are able to run on some lines. Disruption is expected until 10:00 22/04.
Posted by TaplowGreen at 07:05, 22nd April 2025
Given that GWR Twitter packs up and goes home at 1900 these days, what help/advice is available to travellers on a day when once again the decreptitude of the infrastructure between Reading & Paddington causes a complete meltdown?
Not defending GWR here, but I don’t think there was much advice they could offer. Almost the entire service far and wide across the GWR network was shot to pieces because of this major infrastructure failure this afternoon.
That's good, because there is no defence for the railway here.
Friends got back to Paddington last night to find the familiar carnage - few or no staff in evidence and absolutely no visible management presence to be seen. Those few staff did their best but were overwhelmed.
Families with children with long distances to travel in tears. Vulnerable older people simply not knowing what to do and not being helped.
On the infrastructure subject, I read this on another forum "GWML has had a huge amount of investment in it over the last decade but has become the most unreliable main line in the UK. The kit on WCML and ECML is much older but doesn't suffer anywhere near as much with incidents that collapse the whole route. ORR should be having an independent investigation to get to the root of the problems".
Interesting point?
Posted by Chris from Nailsea at 22:52, 21st April 2025
Fair comments, Timmer.
We had a weekend guest here in Nailsea who was inconvenienced on her journey home this afternoon by the emergency bridge work near Cardiff Central.
Altogether, not a good Bank Holiday weekend for the railways.
Posted by Timmer at 22:34, 21st April 2025
Thoughts with the passengers and staff who are still stranded this evening. This really was a bad one on such a major travel day.
Posted by TaplowGreen at 21:33, 21st April 2025
"South Western Railway ticket acceptance is now revoked, due their operations being severely affected by a fatality at Putney.
Chiltern Railways ticket acceptance is now revoked"
https://www.express.co.uk/news/uk/2044029/paddington-station-live-rail-train-cancelled
Posted by UstiImmigrunt at 20:03, 21st April 2025
UPDATE:
Due to a fault with the signalling system at Twyford fewer trains are able to run. Disruption is expected until 23:59 21/04.
Train services between London Paddington and Reading may be cancelled, delayed or revised.
Due to a significant signalling fault in the Twyford area, trains are unable to operate on the Great Western Mainline.
Trains will be moved to stations where possible and hold there pending a fix to the signalling. Network Rail teams are on site at Thames Valley Signalling Centre and at Reading, working to resolve the issue.
This is affecting train services from Reading to Basingstoke, the West Country via Newbury Westbury and Taunton, South Wales, Cheltenham Spa and Oxford and the North Cotswolds.
Sounds like a major outage this afternoon. Nothing is leaving Paddington High Level other than the Heathrow Express
It doesn't have to be a major outage to stop all departures. The stranded train policy is brought in. Wherever possible trains are stopped in platforms and don't move until the problem is resolved. This is to prevent passengers self evacuating onto open railway lines.
There was a rule book alteration many years ago, a new reason for a driver to be authorised to pass a signal at danger, proceed into a platform where another train is stopped, think for example Keysham or Nailsea.
Today's 1530 BTM Paddington had a delight 2 hours at Chips and Ham, 1530 Paddington WSM is currently 222 mins late!
Posted by Chris from Nailsea at 19:00, 21st April 2025
See also the 'chaos at Cardiff Central' incident: https://www.firstgreatwestern.info/coffeeshop/index.php?topic=30170.0
Not a good Easter Monday on the railways.
Posted by ChrisB at 18:57, 21st April 2025
Till the end of the day....
Posted by Timmer at 18:28, 21st April 2025
UPDATE:
Posted by Timmer at 17:39, 21st April 2025
Unsurprisingly, Exeter to Waterloo trains are shown as ‘full and standing’. Feel for those further up the line who will have absolutely no hope of boarding.
Posted by Timmer at 17:22, 21st April 2025
Due to a fault with the signalling system at Twyford fewer trains are able to run. Disruption is expected until 21:00 21/04.
Due to a signalling fault in the Twyford area, trains are unable to operate on the Great Western Mainline. Trains will be moved to stations where possible and hold there pending a fix to the signalling.
This is causing all kinds of problems for those returning to London following the Easter weekend with trains, particularly those coming up from the Southwest, terminating well short of London at Westbury, Taunton, Exeter and one train up from Penzance only getting as far as Plymouth!
Posted by TaplowGreen at 15:54, 17th April 2025
A special treat for Easter!
(National Rail, generally more reliable and up to date, warning of disruption till 1800)
Following a points failure between London Paddington and Reading some lines have now reopened.
Train services running to and from these stations are returning to normal but some services will still be cancelled, delayed or revised. Disruption is expected until 16:00 17/04
Posted by TaplowGreen at 19:27, 13th April 2025
Due to a broken rail between Reading and London Paddington the London Paddington bound high speed line is blocked.
Train services running to and from these stations will be cancelled, delayed or terminated at and started back from Reading. Disruption is expected until the end of the day.
We're sorry for the delay to your journey. Due to a broken rail in the Twyford area, the high speed line towards London Paddington is blocked. This means our high speed long distance trains will need to share the line with other operators local stopping trains. This will cause delays due to congestion.
In order to reduce the delay to your journey, we may need to terminate or start some trains at Reading instead of London Paddington.
Your tickets will be accepted at no extra cost on Elizabeth Line services between Reading and London Paddington. Please note, Elizabeth Line services are also affected by this issue
Posted by IndustryInsider at 15:39, 9th April 2025
Radley, unfortunately.
Appleford.
Posted by ChrisB at 20:22, 7th April 2025
GWR Help advising that there's no bus availability (direct fast service buses are present, take 40 mins DID-OXF, serve station), and alternative offering was *serious suggestion* DID-PAD-MYB (free pass) - OXF - takes almost 3 hours unless fast DID-PAD used.
Called out the "assistant" and suggested that they try it out one day.
Posted by TaplowGreen at 19:31, 7th April 2025
.....will make for some interesting journeys home tonight.....
Alterations to services between Didcot Parkway and Oxford
Due to the emergency services dealing with an incident between Didcot Parkway and Oxford all lines are closed.
Train services running through these stations will be delayed or revised. Disruption is expected until 20:30 07/04.
As a result of the emergency services dealing with an incident the line between Didcot Parkway and Oxford has been closed to train movements.
The alternative route for GWR ticket holders to use Chiltern Railways services between London Marylebone and Oxford in both directions is no longer a viable option owing to a train failure on that route.
Posted by TaplowGreen at 21:17, 1st April 2025
Due to a points failure between Reading and Reading West some lines are blocked. Disruption is expected until the end of the day.
Train services between Reading and Newbury may be cancelled.
Network Rail staff are working to fix the points. To do this they will have to close the line completely from 21:30 for around 90 minutes.
During this time, we will not be able to run any trains between Reading and Newbury, in either direction. We will have some replacement transport in place, but this will not run to train times. Your journey may take longer to complete.
Posted by TaplowGreen at 06:38, 1st April 2025
Whilst it's never great to see the map covered in red lines, at least this weekend (as well as the inevitable staff shortage related cancellations), much of the disruption is due to engineering works, which I am told (amongst other activity) involves installing new rails between Reading and Paddington - hopefully this might help to relieve the virtually daily disruption and meltdowns which have been a feature of this route over the past couple of months?
......but then again.....following the installation of new track....
Due to a speed restriction over defective track between Reading and London Paddington trains have to run at reduced speed on some lines.
Train services running to and from these stations will be cancelled, delayed or revised.
Maidenhead, Twyford and Slough will not be served.
Posted by TaplowGreen at 16:16, 30th March 2025
Posted by TaplowGreen at 12:45, 28th March 2025
Cancellations to services between Twyford and Maidenhead
Due to a points failure between Twyford and Maidenhead some lines are blocked.
Train services running through these stations may be cancelled or delayed. Disruption is expected until the end of the day.
Posted by TaplowGreen at 14:06, 26th March 2025
The Coffeeshop may have been away, but nothing much has changed......
Due to a points failure between Reading and London Paddington some lines are blocked.
Train services running to and from these stations will be cancelled, delayed or terminated at and started back from Reading. Some stations between Reading and London Paddington will not be served. Disruption is expected until 15:00 26/03.
Posted by TaplowGreen at 09:46, 23rd March 2025
Almost beyond belief.....again.
Cancellations to services between Reading and Slough
Due to a points failure between Reading and Slough some lines towards London Paddington are blocked.
Train services running to and from these stations will be cancelled, delayed or revised. Twyford, Maidenhead and Slough will not be served. Disruption is expected until 15:00 20/03.
Apologies to customers, Network Rail advise we have multiple points failures between Reading and Slough in at least 3 different locations. In addition the high speed line from Reading towards London is currently shut.
These were the "multiple points failures" on Thursday afternoon.
8178B - Southall East
8336 - Maidenhead East
8326 - Slough West
8296 - Dolphin Junction
8334 - Maidenhead East
8301 - Dolphin Junction
8335 - Maidenhead East
8027 - Royal Oak
Project Brunel anyone?
