Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025
28.8.2025 (Thursday) 02:36 - All running AOK
Posted by TaplowGreen at 10:27, 27th August 2025
Cancellations to services between Oxford and Didcot Parkway
Due to a derailment within the depot between Oxford and Didcot Parkway the line towards Didcot Parkway is blocked.
Train services running through these stations may be cancelled. Disruption is expected until the end of the day
Posted by Timmer at 07:42, 26th August 2025
This is probably why Elizabeth line and Oxford to London services are being affected, signalling fault affecting the fast London bound platforms at Reading.
Cancellations to services at Reading
Due to a fault with the signalling system at Reading fewer trains are able to run on some lines.
Train services running to and from this station will be cancelled. Disruption is expected until the end of the day.
Due to a fault with the signalling system at Reading affecting platforms 10 & 11, some services will be altered; delayed or cancelled.
Elizabeth line are conveying passengers between Reading and London Paddington in both directions until further notice.
Posted by TaplowGreen at 07:33, 26th August 2025
From National Rail - judging by the cancellations between Oxford-Paddington it's not only affecting the Elizabeth Line.
A fault with the signalling system between Reading and Twyford means some lines are disrupted.
As a result, Elizabeth line trains running between Reading and Maidenhead may be delayed or cancelled.
Disruption is expected to continue until 09:00.
Posted by TaplowGreen at 22:54, 24th August 2025
Delays to services between Newbury and Reading
Due to a fault with the signalling system between Newbury and Reading trains have to run at reduced speed.
Train services running to and from these stations may be delayed by up to 20 minutes. Disruption is expected until 23:00 24/08.
Posted by TaplowGreen at 12:37, 23rd August 2025
Delays to services between London Paddington and Reading
Due to a points failure between London Paddington and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations may be delayed by up to 30 minutes. Disruption is expected until 13:30 23/08.
Posted by TaplowGreen at 18:39, 21st August 2025
Delays to services between Twyford and Maidenhead
Due to a fault with the signalling system between Twyford and Maidenhead trains have to run at reduced speed on some lines.
Train services running through these stations may be delayed by up to 20 minutes. Disruption is expected until 19:00 21/08.
Posted by TaplowGreen at 19:21, 19th August 2025
Cancellations to services between Didcot Parkway and Oxford (also affecting much wider area)
Due to the emergency services dealing with an incident at Didcot Parkway all lines are blocked. Disruption is expected until 17:15 19/08.
Train services between Didcot Parkway and Oxford may be cancelled or delayed.
A person has been struck by a train, leading to all lines being blocked.
Disruption now expected "until the end of the day" across the region.
Posted by TaplowGreen at 16:40, 19th August 2025
Posted by TaplowGreen at 08:03, 16th August 2025
Cancellations to services between Reading and Westbury
Due to a fault with the signalling system between Reading and Westbury some lines are blocked.
Train services running to and from these stations may be cancelled, delayed or diverted. Disruption is expected until 09:00 16/08.
Due to a fault with the signalling system, west country train services are currently unable to run between Reading and Westbury. Trains from the west country towards Reading are unaffected.
Posted by TaplowGreen at 10:21, 8th August 2025
From National Rail
between London Paddington and West Ealing
A fault with the signalling system between London Paddington and Acton Main Line means trains must run at a reduced speed on some lines. As a result, trains operating to / from these stations may be cancelled, delayed by up to 20 minutes or revised.
Disruption is expected until 11:00.
Posted by Electric train at 09:27, 6th August 2025
What is needed is some analytical boffin to gather all the failures reported here in these forums for the TV and trend them say over the last 4 years ie post COVID lockdowns
Posted by TaplowGreen at 07:27, 5th August 2025
Due to a points failure between Reading and London Paddington some lines are blocked.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 11:00 05/08.
Posted by TaplowGreen at 13:50, 4th August 2025
Alterations to services between Reading and London Paddington
Due to damage to the overhead electric wires between Reading and London Paddington trains have to run at reduced speed on some lines towards London Paddington.
Train services running to and from these stations may be delayed by up to 20 minutes or revised. Disruption is expected until 15:00 04/08.
Posted by TaplowGreen at 12:34, 1st August 2025
Following a points failure at Slough the line towards London Paddington will be reopened shortly. Disruption is expected until 13:45 01/08.
Train services between Reading and London Paddington may be cancelled.
Posted by TaplowGreen at 11:58, 28th July 2025
Cancellations to services at Tilehurst
Due to a points failure at Tilehurst some lines are blocked.
Train services running through this station may be cancelled or revised. Pangbourne will not be served. Disruption is expected until 12:45 28/07.
Posted by Electric train at 06:14, 25th July 2025
Consistency being maintained.....
Following a broken down train at Twyford some lines will be reopened shortly. Disruption is expected until 17:15 22/07.
Train services between London Paddington and Reading may be delayed by up to 15 minutes.
Broken down freight train.
So not an infrastructure problem or failure that caused the disruption
Posted by a-driver at 20:53, 22nd July 2025
Posted by TaplowGreen at 16:32, 22nd July 2025
Posted by a-driver at 11:49, 22nd July 2025
See also: https://www.firstgreatwestern.info/coffeeshop/index.php?topic=30475.msg363433#msg363433
Fair play to the SWR managers concerned for pitching up given the circumstances, it must have been quite uncomfortable for them. Would be good to see Hopwood et al at Paddington (or indeed anywhere!) doing a similar session during a GWR meltdown, seeing (and hearing) what their customers have to put up with at first hand may concentrate a few minds.........
I’d rather have the top brass from the DfT and Network Rail.  They’re the ones inflicting the misery.
Posted by TaplowGreen at 05:38, 22nd July 2025
Posted by Chris from Nailsea at 19:13, 21st July 2025
Posted by TaplowGreen at 19:05, 21st July 2025
We're now getting back to the days where this is virtually a daily event. If not points it's signal or track issues.
London Paddington and Reading some lines are blocked.
Train services running to and from these stations may be cancelled or delayed by up to 30 minutes. Disruption is expected until 11:15 21/07.
And it’s not confined to just GWR, it’s the same across the country.  Look at Waterloo today.
There’s some serious issues within Network Rail that need addressing urgently.
Reported at length on BBC London news tonight.........South Western even had a "Meet the Manager" event today at Waterloo! Perfect timing!
Posted by a-driver at 16:56, 21st July 2025
Posted by TaplowGreen at 15:16, 21st July 2025
The obvious solution, don't increase road fuel duty again. You couldn't make it up could you.
I'm unclear as to the correlation? (Which as we know, is not causation!)
Posted by CyclingSid at 12:35, 21st July 2025
Posted by TaplowGreen at 10:56, 21st July 2025
Posted by TaplowGreen at 11:35, 20th July 2025
Due to a safety inspection of the track at Hayes & Harlington fewer trains are able to run on the line towards London Paddington. Disruption is expected until the end of the day
Posted by GBM at 05:57, 18th July 2025
Due to a speed restriction over defective track between Reading and London Paddington fewer trains are able to run on the London Paddington bound local stopping line.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until the end of the day.
We're sorry for the delay to your journey today. Following a safety inspection of the track in the Twyford area, a speed restriction has had to be implemented on some lines. Network Rail advise that due to the nature of the fault found, this disruption will last until the end of the day.
In order to avoid the speed restriction, both ours & other operators local stopping trains will need to share the high speed lines with our high speed long distance trains that run between Reading and London Paddington. This will cause some delay due to congestion, much like a lane closure on a motorway.
In order to reduce congestion in the area and to reduce any further impact to your journey, we will need to cancel some trains.
We will only be running one train per hour between Oxford and London Paddington.
Some of our trains that run between Newbury and London Paddington will only run between Newbury and Reading. You may need to change trains at Reading if you are travelling to or from London Paddington.
Posted by TaplowGreen at 19:55, 17th July 2025
Due to a points failure between London Paddington and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled, delayed or terminated at and started back from Reading. Slough, Maidenhead and Twyford will not be served. Disruption is expected until 20:30 17/07.
Posted by TaplowGreen at 05:25, 16th July 2025
Due to a fault with the signalling system the line is blocked. Disruption is expected until 08:30 16/07.
Train services between Reading and Newbury may be cancelled or delayed.
Due to a fault with the signalling system, trains are currently suspended between Reading and Newbury.
Posted by TaplowGreen at 07:07, 15th July 2025
Delays to services between West Ealing and Greenford
Due to a fault with the signalling system between West Ealing and Greenford all lines are blocked.
Train services running to and from these stations will be delayed. Disruption is expected until 07:45 15/07.
Due to a fault with the signalling system between West Ealing and Greenford, the line is currently blocked.
Posted by Electric train at 07:07, 13th July 2025
Why oh why didn’t GWR send a unit to Didcot once they had overcome the Traincare issues?  Is it because those poor customers who had been stranded at Reading for 2 hours were already a lost cause in terms of repayment claims - so to minimise the damage to the GWR coffers it was better to send units to London?
I'm often less than impressed with decisions operators make during disruption, but I genuinely don't think that minimising repayment claims figures highly, other than as a by-product of the underlying "how can we best sort out this mess?", for which there are various meanings of the word "best".  Where the cost more directly affects the response is likely to be in areas such as arranging alternative transport (bus, taxi etc), for which there are probably guidelines on severity/timescale of disruption etc and someone will need to authorise it.  Staff overtime may be another area, though working time limits will restrict that anyway.
I have been involved quite a few times in the conference calls that are managing service disruption, there are so many moving parts and demands.  I as the electrification Engineer or my colleges PWay and S&T Engineers may need access to fix a fault  this may add to the initial impact but ultimately will result in a full recovery but that has to be balance against the urgent operational need to provide even a limited service also more importantly we have to say sometimes it is unsafe to use this section of the railway.  The TOC and NR Ops have to consider train crew, suitable rolling stock, train pathing out and return
I'm not involved in the Western Region but each Region has a Silver Command head by senior leaders of NR and the TOCs this will be Route Director level.
The result has been that services west of Reading that 10 years ago were run by 3 car Turbos now run often with very lightly loaded 387s. Some have (of course) already been reallocated to Heathrow Express duties, but the rolling stock shortage across GWR territory extends to all non-electrified Thames Valley services too (remember the 769s?).
Listening to the recent interview Jeff Marshal did with Mark Hopwood the GWR do not see the rebuild of 'D' Stock as being the answer to future rolling stock.
It has always been my view you can cascade rolling stock, but the rebuilding a traction unit to a different form of traction especially when its greater than 40% of it life is just not value for money
The contrast with the glacial progress in introducing the 185s further west is striking. If all that I have learned as a member of this forum over the years, this bears the fingerprints of DfT. Will GBR, when it eventually takes over do better (or be allowed to)?
Ultimately HM Treasury holds the purse strings, those strings and fare increases are politically controlled.
Posted by eightonedee at 18:24, 12th July 2025
Following up on a-driver's comments on the transfer of some of the class 387s, I am afraid this seemed inevitable. The fleet was procured when it was anticipated not only that electrification would get to Oxford, but also would extend to the Windsor, Marlow, Henley and Basingstoke branches. The Elizabeth Line has also absorbed quite a proportion of GWR stopping train traffic east of Reading.
Posted by Ralph Ayres at 17:33, 12th July 2025
Posted by a-driver at 17:08, 12th July 2025
Why are GWR 387s being released elsewhere when they can’t hold/recover the timetable together with the stock they have.
GWR were instructed to release the 387's by the DfT.  As Oxford wasn't electrified the DfT calculated that GWR had a surplus of 387's
There was I believe, a points failure at Didcot with no access from Reading to Oxford.  Trains used Foxhall Jn which requires a reversal and free platforms at Didcot.
Why do customer service facing staff have no better (and in some cases less) information that Joe Public? If I wasn’t aware of RTT or OTT I would be completely at the whim of the train companies
Multiple failures at Didcot, Maidenhead and Ladbroke Grove simply means a constantly changing situation and an overstretched controller juggling resources and attempting to perform miracles!
Decision are never made to benefit the company.  The controllers sole intention is trying to keep things moving with what you've, some days whatever decision you make minutes later something else happens that scuppers that plan.
Posted by lbraine at 16:29, 12th July 2025
A miserable couple of days relying on the UK train service.
I’ll start elsewhere and then bring it back to GWR towards the end.
I needed to go to Cambridge on Thursday (actually a day early than needed but the extortionate day return price meant going a day before was 1/2 the price).
My Thames Valley stopper gave up at Reading - no reason given, just an announcement from the Driver pulling into Reading. Not to worry - hustled across to platform 10/11 to catch a fast 5 car IEP at 12:34, pausing briefly to notice the number of delayed services on the list. Hmmm - glad I went now as later on could be a mess.
Arrived at King Cross at the start of a major meltdown - the next 3 Cambridge Great Northern train all delayed/cancelled. RTT actually showed all running. Message on the boards said due to a signal failure journeys north of Cambridge would be delayed and subject to cancellation.
Hmmm - but surely running to Cambridge should be fine? Jumped onto OTT and started looking at the maps and it was clear the issue was at the Kings Cross/Cambridge box boundary - south of Cambridge, hence no trains. Gate line staff were pretty hopeless, basically telling people to wait. Jumped onto National Rail where they said fault would not be fixed until 10:00 pm
I started sharing this with other stranded customers - amazingly much to the clear annoyance of the Great Northern staff.
Back onto RTT/OTT - and worked out that if I jumped on the Victoria line to Tottenham Hale I could catch a slow all station stopper from Liverpool Street to Cambridge. Yes it was going to take forever - but I should get there.
Apart from a protracted discussion with Great Anglia gate line staff who had to be convinced that this was a valid route for my ticket I arrived at Cambridge at 5pm (to a scene of armageddon as hundreds stood in the longest queues for taxis to Royston from which trains to Kings X were running.
In total my 2:15 scheduled journey took 5 1/2 hours.
Friday was the return trip - leaving Cambridge at 1:00pm on a GWR liveried  Class 387, albeit with logo removed. I actually spotted 3 more on this trip - I was unaware GWR were transferring these to other operators. Even the WiFi onboard was GWR, so it must be a recent movement.
Kudos to Network Rail who had repaired the signalling interface problem and it’s was a smooth, fast 45 trip to Kings Cross and then onto Paddington.
Arriving at 2:30pm the Thames Valley Didcot stopped was cancelled - alongside several others. Again, back onto RTT and I could see the train actually scheduled to start from Reading.
So why were GWR announcements saying to wait for the next train in 30 minutes.
Jumped into a 10 car IEP bound for Penzance and actually found a seat ! Things were looking up and a smooth ride to Reading took place. This where the GWR customer experience really bottomed out.
I arrived to see the train I was trying to catch showing for Platform 12. Five minutes after the supposed departure  this changed to Delayed - which a s everyone knows is GWR speak for a coin-toss as to whether the train will depart or not.
Some disgruntled customers started merging to for a group to get a taxi to Pangborne - as the previous train has been cancelled.
Time ticked by the the next service was due - but it too fell to the dreaded Delayed banner. I started talking to some friendly GWR staff who like me were glued to their OTT like app trying to work out what the hell was going on.
We finally got an announcement - as they officially Cancelled the first train I was going for - to say there was an issue as Reading Traincare meaning units could not be released. By now the next service has appeared and was showing as Delayed.
To summarise - for at least 2 hours GWR had failed to run 4 local services to Didcot.
Finally, around 4pm Class 387’s started emerging from Reading Traincare.
Excellent news, or so I thought - surely at least one of these units would service the crowd of hundred customers on Platform 12 and send a train to Didcot. (By this time I have seen a service at Slough, in bound).
But No! GWR sent all these units (I witnessed at least 3) towards London.
At 4:30 I board the Class 387 - the one that arrived from Slough. This was a sauna as the aircon on-board was not working and people arriving fell out of the train gasping for air, and issuing us dire warnings.
So here is my ire (in no particular order)
Why at Paddington did they not tell customers that the cancelled train would start at Reading (OK - it did not in the end but did they know that at that point in time?)
… I could go on.
I have watched and read much on the coming of Great British Railways - and have been neutral about the pros and cons. Privatisation has brought investment to the railway (alongside large shareholder payouts) but this investment has done nothing to allow the railways to continue to operate on days when it is stressed. So what is the point? Maybe public ownership will correct some my experiences - but maybe not.
But most importantly I want a railway that puts customers FIRST and the banishment of operational decisions that benefit no one except the train operating company themselves.
I’ve written this 24 hours after arriving home - giving at lease my blood pressure time to fall, if not the actual temperature. My original draft was far far more spicey.
Posted by Ralph Ayres at 10:37, 12th July 2025
From National Rail.......not mentioned on JourneyCheck.....
between Maidenhead and Reading
A fault with the signalling system is means all lines are blocked between Maidenhead and Reading. Stations between these stations will not be served.
Trains will be cancelled or revised.
Disruption is expected until 21:00.
Trains between London Paddington and Heathrow Airport / Maidenhead can still run but may be delayed
All lines appear to be open though.
The lines may have been open but certainly around 1900 when I arrived trying to reach West Drayton, nothing was running on the relief lines with TfL having given up completely. Only reported delay was west of Reading, and nothing had been mentioned in the banner on the NRE app or I'd have taken a very different route from my starting point of Alton having already had to detour thanks to two successive GWR cancellations on the line from Gatwick.  The information booth seemed to know less than I could work out from the departure screens and kept telling people to ask gateline staff; I'd expected the booth would at least have a feed of the signal diagram showing actual locations, train running info etc.  Eventually got on an eastbound IET which I'm sure was shown as calling additionally at Slough to get me closer, but ran non-stop to Paddington. By that time Lizzie trains were running west to Heathrow via Hayes so took that option followed by a bus. Fortunately I was in no hurry and the trains had working air conditioning.
Posted by a-driver at 21:07, 11th July 2025
Posted by TaplowGreen at 20:21, 11th July 2025
Posted by TaplowGreen at 18:00, 11th July 2025
Cancellations to services between Reading and Didcot Parkway
Due to a points failure between Reading and Didcot Parkway some lines are blocked.
Train services running to and from these stations will be cancelled. Disruption is expected until 20:00 11/07.
Posted by grahame at 16:37, 11th July 2025
The train being used on the Slough to Windsor route has developed a fault, and we have been unable to fix the problem.
No spare trains are currently available, therefore the service along this route is suspended until further notice.
..............unhappy tourists/commuters, happy taxi drivers.
I'm not in the UK at the moment and they seem to do things differently here.  As I understand it earlier today, there was a fault on the train we were waiting in, and we all transferred to another just along the platform. There seems to be an appreciable supply of parked trains at most operating centres, some of which I suspect are spare donors but some are in running order, and this provision of a few spares - no doubt each given a run from time to time - seems to make sense.  I would prefer and older train occasionally to no train.
Such a system could not be easily adopted in the UK due to the rolling stock leasing regime and the need for every train to pay its way every day.
Posted by TaplowGreen at 16:22, 11th July 2025
Another Turbo has sat down.
Cancellations to services between Newbury and Bedwyn
Due to a broken down train between Newbury and Bedwyn fewer trains are able to run.
Train services running through these stations may be cancelled or revised. Disruption is expected until the end of the day.
The train operating the Newbury/Bedwyn shuttle has failed.
Some long distance GWR Westcountry services will call additionally and rail replacement transport is being arranged.
...........and another
Cancellations to services between Slough and Windsor & Eton Central
Due to a fault on this train between Slough and Windsor & Eton Central fewer trains are able to run on the line.
Train services running to and from these stations have been cancelled. Disruption is expected until the end of the day.
Updated;
Posted by TaplowGreen at 16:11, 11th July 2025
Posted by Timmer at 16:09, 11th July 2025
Posted by lbraine at 16:02, 11th July 2025
Mini melt down at Reading taking place. Announced as an issue getting u its out of Reading Traincare Depot.
Three missing Thames Valley services (Delayed)
Cancellation to Basingstoke and Newbury
Seems the Class 387 don’t like the heat !
Posted by TaplowGreen at 11:19, 11th July 2025
Due to a fault with the signalling system between London Paddington and Reading trains have to run at reduced speed on some lines towards Reading.
Train services running to and from these stations will be delayed by up to 15 minutes. Disruption is expected until 1130
Posted by IndustryInsider at 16:48, 4th July 2025
Oh yes it does - won't it reduce the loadings by having people miss connections, and increase the passenger angst and chance of passenger disturbances on the branch trains?   The JourneyCheck wording written from an operational rather than from a passenger journey viewpoint?
You’re saying it would have been more sensible to write “We apologise, but this will increase the likelihood of a passenger disturbance on branch line trains, but your train might well be quieter.”
"The trains on the branches will be running at normal times, but connections may not be made so you may have to wait for the next train?
Ah, fair enough, it looked like you were after a more radical change of wording than that.  Though I would suggest the phrase ‘on the branches’ would mean nothing to a fair few passengers, so you would still want to list them like in the original message.
Posted by TaplowGreen at 16:14, 4th July 2025
That would be a more customer centric approach, perhaps with a suggestion to consider other means of getting to the stations in question to pick up the branch lines with links to local bus timetables, car parking information etc.......but that would require a customer centric culture........and this is the railway.
Posted by grahame at 11:46, 4th July 2025
Posted by bobm at 10:00, 4th July 2025
Particularly disruptive missing Twyford, given it is Henley Royal Regatta this week.
Posted by IndustryInsider at 09:50, 4th July 2025
Posted by grahame at 08:26, 4th July 2025
The majority of our services between Reading and London Paddington will not be able to call at Twyford, Maidenhead or Slough. Please see details on alternative services below. Please note, this does not affect our Henley, Marlow or Windsor branch line services.
Edit to correct quoting
Posted by TaplowGreen at 07:33, 4th July 2025
Due to engineering works not being finished on time between London Paddington and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 07:10 04/07.
Due to engineering works not being finished in time, the line between London Paddington to Reading will be delayed; altered or cancelled.
Rail replacement services are not in operation
Delays/cancellations now until 0830
Our high speed long distance trains that only run between Oxford and London Paddington will not run. Our high speed long distance trains between Worcester and London Paddington will still run which means Oxford will see an hourly service to / from London Paddington.
If you're travelling to or from Twyford, Maidenhead or Slough, you will need to use Elizabeth Line services. Please note, Elizabeth Line services are also affected by this problem. For more information regarding Elizabeth Line services, please visit www.tfl.gov.uk. Your GWR tickets are being accepted on this route at no extra cost.
Posted by TaplowGreen at 05:49, 4th July 2025
Posted by NickB at 18:18, 2nd July 2025
Delays still occurring at Slough
Posted by TaplowGreen at 16:50, 2nd July 2025
Delays to services at Slough
Due to damage to the overhead electric wires at Slough trains have to run at reduced speed on some lines.
Train services running through this station may be delayed. Disruption is expected until 17:30 02/07.
Posted by TaplowGreen at 14:18, 1st July 2025
Delays to services between London Paddington and Slough
Due to a points failure between London Paddington and Slough some lines are blocked.
Train services running to and from these stations may be delayed by up to 20 minutes. Disruption is expected until 15:30 01/07.
Elizabeth Line suspended Paddington to Reading/Heathrow.
Posted by TaplowGreen at 17:46, 24th June 2025
Alterations to services at Twyford
Due to a fault with the signalling system at Twyford trains have to run at reduced speed on all lines.
Train services running through this station will be delayed or terminated at and started back from Reading.
Some stations between Reading and London Paddington will not be served. Disruption is expected until 18:15 24/06.
Posted by TaplowGreen at 10:59, 23rd June 2025
Alterations to services between Oxford and Didcot Parkway
Due to a safety inspection of the track earlier today between Oxford and Didcot Parkway all lines will be blocked.
Train services running through these stations will be delayed or revised. Disruption is expected until 12:00 23/06.
Posted by NickB at 17:26, 20th June 2025
Line side fire at Acton causing delays from paddington now. Most Elizabeth Line trains cancelled.
Lovely day for it.
Posted by TaplowGreen at 13:28, 20th June 2025
Due to a fault with the signalling system at Burnham fewer trains are able to run on some lines. Disruption is expected until 15:00 20/06.
Train services between Reading and London Paddington may be cancelled, delayed or revised. Twyford, Maidenhead and Slough will not be served.
Due to a fault with the signals in the Burnham area, we have had to reduce our train service in the Thames Valley this afternoon.
Posted by a-driver at 22:53, 19th June 2025
Not a very good day......
Alterations to services at Didcot Parkway
Due to a points failure at Didcot Parkway some lines are closed.
Train services running through this station may be delayed or revised. Disruption is expected until 18:45 19/06.
Better than I expected though considering air temperatures hit over 32°c in London
Posted by TaplowGreen at 17:02, 19th June 2025
Posted by TaplowGreen at 14:16, 19th June 2025
Due to a fault with the signalling system between Newbury and Bedwyn all lines are disrupted.
Train services running through these stations will be cancelled. Disruption is expected until the end of the day.
Due to an issue with the signalling system between Newbury - Bedwyn the service will be suspended until further notice.
Posted by TaplowGreen at 14:13, 19th June 2025
Following a fault with the signalling system between London Paddington and Reading some lines are now open.
Train services running to and from these stations are returning to normal. Disruption is expected until 14:30 19/06.
Due to a signalling issue lines between London Paddington - Reading, some services maybe delayed, altered or cancelled.
Posted by TaplowGreen at 11:55, 19th June 2025
Cancellations to services between Newbury and Reading
Due to a fault with the signalling system between Newbury and Reading some lines are blocked.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 12:30 19/06.
Due to a fault with the signalling system at Newbury, the lines are block between Newbury to Reading in both directions.
Services will be delayed; altered and cancelled as a result.
Posted by TaplowGreen at 16:28, 18th June 2025
Due to a fault with the signalling system at Oxford fewer trains are able to run on some lines. Disruption is expected until 18:00 18/06.
Train services between Oxford and Didcot Parkway may be cancelled, delayed or revised.
Posted by TaplowGreen at 07:41, 18th June 2025
A fault with the signalling system at Slough means that Elizabeth line trains must run at a reduced speed on some lines. Services operating through Slough may be delayed by up to 15 minutes or cancelled.
Disruption is expected until 12:15
Posted by TaplowGreen at 18:12, 11th June 2025
Due to a safety inspection of the track between Twyford and Maidenhead trains have to run at reduced speed on the line towards London Paddington.
A small section of the railway line between Reading and London Paddington is closed whilst Network Rail carry out a safety inspection. GWR can still run trains safely, as other tracks are available for use, but this will lead to some congestion and slower running as trains make their way through.
Posted by nickswift99 at 08:51, 11th June 2025
Another bridge strike at Burnham this morning. Trains being cautioned over the affected area.
Posted by charles_uk at 11:33, 10th June 2025
Alterations to services between London Paddington and Slough
Due to a safety inspection of the track between London Paddington and Slough some lines will be blocked.
Train services running to and from these stations may be delayed or revised. Disruption is expected until 13:45 10/06.
Doesn't seem to be causing significant issues at the moment but the disruption until guestimate has been extended from 11:15 to 13:45 so far...
Posted by Electric train at 17:15, 9th June 2025
Alterations to services between London Paddington and Reading
Due to the emergency services dealing with an incident between London Paddington and Reading some lines are closed.
Train services running to and from these stations may be delayed or revised. Disruption is expected until 12:45 09/06
Rapidly pushed out to 1400 & now 1500
National Rail reporting no Elizabeth Line services between Paddington-Heathrow/Reading......Advice seems to be to go via Waterloo.
Report in a local news paper https://www.sloughexpress.co.uk/news/traffic-and-travel/201654/major-disruption-on-london-paddington-to-reading-train-line-after-casualty-on-tracks.html?utm_medium=Social&utm_source=Facebook&fbclid=IwY2xjawKz5whleHRuA2FlbQIxMABicmlkETBYRnJvRkR2RzlQTXE5SURwAR7k8vmJj-al5-L4zohMl9WOPau7kOswUS93SrOABFN-7PQzBg3_My5mDdXnDw_aem_J2_-9E6iEUR1Ri7n9xWwOw#Echobox=1749471219
Casualty on the tracks at Hanwell station
Posted by TaplowGreen at 13:16, 9th June 2025
Posted by TaplowGreen at 12:33, 9th June 2025
Posted by Electric train at 13:14, 5th June 2025
Burnham Station, according to the Bucks Free Press.
https://www.bucksfreepress.co.uk/news/25214998.burnham-station-bridge-lorry-crash-roof-ripped-off/
Would seem to have been a bit of sandwich
Posted by Chris from Nailsea at 16:53, 4th June 2025
Posted by TaplowGreen at 16:48, 4th June 2025
Does anyone know which bridge was struck?
I believe it was Burnham.
Posted by Hal at 13:39, 4th June 2025
Posted by TaplowGreen at 13:09, 4th June 2025
Due to a road vehicle colliding with a bridge earlier on this train's journey between Slough and Reading trains have to run at reduced speed on some lines.
 Disruption is expected until 14:00 04/06.
Posted by Fourbee at 12:17, 30th May 2025
There's an article in this month's Rail magazine with some of the people working on Project Brunel (the project tasked with improving the performance of the infrastructure between Reading and Paddington). Fairly interesting read.
My main recollections: undergrowth was cut back that was tripping the OLE, too many/heavy trains using it (broken rails), pigeons nesting in bridges culled particularly at Ealing Broadway as they were tripping the OLE when a train passed, 777 axle counters replaced that still get loose, but are monitored/tightened before they fail again, addressing wet bed issues to do with drainage being covered over when track was realigned.
This may not have been the sentiment intended or I misread it: the team want to maintain the current level of progress without slipping back (!).
Posted by TaplowGreen at 14:22, 29th May 2025
........and it's fallen over again.....
Cancellations to services between Slough and London Paddington
Due to urgent repairs to the railway between Slough and London Paddington some lines towards London Paddington are closed.
Train services running to and from these stations may be cancelled, delayed by up to 20 minutes or revised.
Disruption is expected until 16:15 29/05.
Posted by a-driver at 17:30, 28th May 2025
Interesting - GWR has said that all lines are open, speed limit imposed, expect delays - proper fix tonight
IETs will probably run diesel Paddington to Reading.  Possibly a minor issue like a broken dropper wire
Posted by ChrisB at 16:59, 28th May 2025
Posted by TaplowGreen at 15:22, 28th May 2025
Due to damage to the overhead electric wires between London Paddington and Reading some lines will be blocked.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 13:30 28/05.
No damage confirmed. A trains pantograph automatically dropped. That could be caused by damage to the overheads but it could also be an issue with the pantograph itself or just a spurious fault.
NR will inspect all 4 lines first as a precaution
Delays & cancellations now until 3pm......or will it be the familiar/dreaded "until the end of the day"?
........and it's now pushed out to 1800 on National Rail.....
.......and almost inevitably.....
Elizabeth line between Shenfield and Heathrow Terminal 5, and also between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading
Great Western Railway on all routes to / from London Paddington
Heathrow Express between London Paddington and Heathrow Terminal 5
Damage to the overhead electric wires between London Paddington and Southall means some lines are blocked.
Trains between London Paddington and Heathrow Airport / Reading may be cancelled, revised or delayed by up to 20 minutes.
Posted by TaplowGreen at 14:50, 28th May 2025
Posted by TaplowGreen at 14:40, 28th May 2025
Posted by a-driver at 13:02, 28th May 2025
Posted by nickswift99 at 12:53, 28th May 2025
There was a signal failure yesterday between Reading and Paddington. Journeycheck then reported further delays due to trespassers on the line. Was there an unexpected detraining somewhere?
Posted by TaplowGreen at 12:40, 28th May 2025
Posted by TaplowGreen at 06:07, 28th May 2025
Cancellations to services between Bourne End and Marlow
Due to a fault with the signalling system between Bourne End and Marlow all lines are blocked.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 06:45 28/05.
Posted by TaplowGreen at 05:02, 21st May 2025
Due to engineering works not being finished on time between London Paddington and Reading trains have to run at reduced speed on some lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 07:00 21/05.
Due to engineering works not being finished on time between London Paddington to Reading, trains will be delayed, altered or cancelled as result. Speed restrictions may apply.
Posted by TaplowGreen at 20:37, 17th May 2025
From National Rail, apparently the problem is at Southall.
between London Paddington and Heathrow Terminals / Reading
Lines have now reopened following a safety inspection of the track between London Paddington and Heathrow Terminals / Reading. As normal service resumes, trains may still be cancelled, delayed by up to 10 minutes or revised.
Disruption is expected until 21:15.
Posted by TaplowGreen at 07:22, 13th May 2025
Ongoing from yesterday.......
Alterations to services between Bourne End and Marlow
Train services running to and from these stations will be suspended.
Posted by Electric train at 06:33, 11th May 2025
ORR» has made it quite clear to NR that working on a !live" railway is basically no longer permitted without very stringent control measures
Would it be a good idea if the Office of Rail and Road also had responsibility for regulation of road safety? It might, for example, encourage ORR to develop policies that minimise overall casualties, instead of deterring people from using rail and pushing them onto a more dangerous mode of transport.
The ORR regulate health and safety (eg 1974 Health and Safety at Work Act for workforce safety) for the entire mainline rail network in Britain, as well as London Underground, light rail, trams, and the heritage sector, were as for highways this duty lies with the H&S Executive
Posted by grahame at 06:13, 11th May 2025
(Caution: this is a joke)
Might be interesting to see how that works out. Perhaps everytime a repair is necessary on a motorway we can shut it completely until it’s fixed.
Customers/drivers can just find another way home, like taking the M40 and M5 rather than the M4.
Many a true word written or asked in jest - "reductio ad absurdum".  At times it feels like the spirit of thoughtful comedy.  And that is - emphaticlally - not - a joke.
Posted by NickB at 00:22, 11th May 2025
Posted by Trowres at 21:30, 10th May 2025
Posted by Electric train at 06:39, 10th May 2025
Is the absence of crew that are able to make the repair during daylight hours a new thing or a recent (past 5yrs) thing?
From a non-expert/passenger perspective it seems remiss not to be able to fix problems for 12+ hours after they occur, but is the logic that the disruption to fix during daylight hours is => than managing the closed line for a day?
Very good question, certainly the habit of routinely forecasting disruption "until the end of the day" seems quite a recent development.
I too do find the idea that there is no-one available from Network Rail to react to this type of incident for 12 hours incredible, especially given the significance, and state of the infrastructure in the Paddington-Reading area - these are hardly isolated incidents.
I suspect that the issue may relate to access for staff to a live railway.   In older day and you still see it in other counties, trains run on adjacent lines while work is ongoing but in order to reduce / eliminate as far as possible casualties, it's very rare if at all these days.  So that means as nighttime stoppage ...
I feel for staff having to put a time on disruption and how long it will go on.  The honest thing to say is "we don't know" but that is not helpful without an estimate, and systems are not set up to say "probably" and "possibly" and "if we're lucky", and I'm not sure how such terms and information would be taken by members of the public who are less analytic than readers here.
There is are a number of reasons why the repair cannot be undertaken in the day.
NR has geared up it workforce to carryout maintenance on track to nights, for a number of reasons first is workforce safety, the ORR has made it quite clear to NR that working on a !live" railway is basically no longer permitted without very stringent control measures, second is performance maintenance during the day would impact on service performance.
On and Off tracking the OTM's (on track machines) to move the equipment and materials to site during normal train running is high risk, also the OTM's may be in the wrong place and need transporting by road.
If a temporary repair could have been made then it would have with reduced speed.
The question that I am sure the Route and TOCs will be asking is why yet another "catastrophic" broken rail on the Western ML
Posted by TaplowGreen at 20:10, 9th May 2025
I tend to reserve my feelings for the customers- those who have paid for a service and end up being massively inconvenienced, time & time again on this route.
Those "having to put a time on disruption" at least have the comfort of being paid to do so.
Posted by grahame at 18:16, 9th May 2025
