| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 16:48, 28th March 2026 | ![]() ![]() ![]() |
... and it gets even worse - from the BBC:
CalMac warns of 'critical shortage' as eight ferries now out of action
MV Lord of the Isles suspended all sailings after an engine problem
Engine problems have put an eighth CalMac ferry out of action, as the operator apologised for a "critical" shortage of ships.
MV Lord of the Isles, which has been sailing the Oban to Mull route, suspended all sailings on Saturday after a "technical issue" with its main engine.
Three other large ferries - including CalMac's troubled Glen Sannox vessel - are already unavailable, while four other ships are undergoing annual maintenance.
The state-owned firm told island communities that the situation was the "most pressing" it had faced and disruption would continue into next week.
CalMac said "virtually every island served by a major vessel" on its west of Scotland network was being affected by the shortage of ships.
(BBC article continues)
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 15:16, 28th March 2026 | ![]() ![]() ![]() |
'Almost every island' facing disruption due to ferry shortage, warns CalMac
CalMac's two newest ships MV Glen Sannox and MV Isle of Islay are both unavailable while faults are investigated
West coast ferry operator CalMac has said "almost every island served by a major vessel" is facing disruption as it grapples with an "unprecedented" shortage of ships.
Three large ferries - including its two newest vessels MV Glen Sannox and MV Isle of Islay - are still unavailable while faults are investigated, and four other ships are away for annual maintenance. But some relief has come to Arran after a fourth major vessel, MV Caledonian Isles, was repaired and resumed services from Ardrossan.
The state-owned firm said it had established an incident management team which would be on hand throughout the weekend to help manage services and repairs.
MV Caledonian Isles is now back in service, restoring sailings from the mainland to Brodick in Arran
CalMac chief executive Duncan Mackison said that despite repairs to Caledonian Isles and a smaller vessel, MV Coruisk, the operator was still dealing with an "unprecedented level of challenges on our network."
"This disruption is affecting virtually every island served by a major vessel and we are profoundly sorry for that," he added. "We are doing what we can to restore these services as quickly as possible."
MV Glen Sannox, which sails to Arran from Troon, developed a problem with a flexible coupling in its exhaust system early on Thursday. A quick repair allowed it to return for one sailing but the problem re-occurred so it has now been withdrawn until Tuesday for a permanent fix and checks to ensure it is available for Easter weekend.
A separate recurring issue with an engine warning light which began shortly after its return from annual maintenance in Merseyside is believed to have been remedied. CalMac suspects it was due to incorrect oil levels and an electrical fault which have now been addressed.
MV Isle of Islay, the first of four new ferries built in Turkey, was meant to enter service on the Islay route on Friday but that has been pushed back until at least Monday. A specialist engineer has been brought in to investigate an engine management system fault and other "snagging issues" are also being looked at.
MV Isle of Arran, a 42-year-old ship affectionately known as the Auld Trooper, has a problem with its fire suppression system. Other faults have since been found with a coupling and a bow thruster, and it is likely to be out of action until early next week.
Four other vessels - MV Hebrides, MV Loch Frisa, MV Isle of Lewis and the chartered catamaran MV Alfred - are all away for scheduled maintenance or repairs.
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 08:25, 11th March 2026 | ![]() ![]() ![]() |
Glen Sannox ferry needs £3.2m repairs after one year in service
Glen Sannox began serving the Isle of Arran in January last year
A troubled Scottish ferry needs new propellors as part of multi-million pound repairs after just over a year in service, MSPs have heard.
Shipyard bosses told a Holyrood committee that repair costs for the Glen Sannox could hit £3.2m after a small crack was discovered in the hull.
Ferguson Marine chief executive, Graeme Thomson, said that extra steel had been added to strengthen the CalMac vessel, but only new propellors would tackle "the root cause" of the crack. "There is an opportunity to improve the design of the propellers," he told Holyrood's net zero, energy and transport committee on Tuesday.
Glen Sannox began serving the Isle of Arran in the Firth of Clyde in January 2025, seven years late and four times over budget.
The 336ft (102m) vessel, with space for 127 cars and 852 passengers, was the first major new ferry to join the fleet off the west of Scotland in a decade.
Glen Sannox was briefly taken out of service last year for the crack on a weld seam to be repaired, and was again off duty in November for annual maintenance at Cammell Laird's yard on Merseyside. That work was extended to include steel strengthening to tackle the vibration issue.
The committee heard that the problem related to "cavitation" - when bubbles detach from a propellor and pop, causing damaging vibrations.
Thomson said that the source of the crack was "vibration through the hull caused when the ship went astern." Similar work would be needed on its sister ship, the Glen Rosa, he added.
The issue is understood to run right back to the ferries' controversial design, which was intended to allow them to ply both the Arran route and the higher-speed 'Uig triangle', which links Skye to North Uist and Harris in the Outer Hebrides.
Glen Sannox was the first UK ferry capable of running on the dual fuels of liquified natural gas (LNG) and marine gas oil (MGO), a low-sulphur type of diesel.
Spelling question, for the BBC: 'propellors', or 'propellers'?
| Re: Caledonian MacBrayne ferries in Scotland Posted by CyclingSid at 08:54, 5th March 2026 | ![]() ![]() ![]() |
A bit like the replacement Cowes chain ferry, buy something new and flashier then find you can't use it part of the time.
| Re: Caledonian MacBrayne ferries in Scotland Posted by Oxonhutch at 21:45, 4th March 2026 | ![]() ![]() ![]() |
| Re: Caledonian MacBrayne ferries in Scotland Posted by Noggin at 12:08, 4th March 2026 | ![]() ![]() ![]() |
It's like the 1970s all over again.
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 10:21, 4th March 2026 | ![]() ![]() ![]() |
Another update, from the BBC:
Ardrossan harbour to be taken into public ownership
CMAL is set to finalise a deal to take Ardrossan Harbour into public ownership
Ardrossan harbour is to be nationalised with the Scottish government's ferries and ports agency expected to finalise the deal this month, the transport secretary has announced
Fiona Hyslop said negotiations between Caledonian Maritime Assets Ltd (CMAL) and owner Peel Ports have now concluded.
The government has been forced to buy the harbour because new CalMac ferries ordered by CMAL for the Arran route are too big to berth safely at the existing facilities and it needs extensive redevelopment. Hyslop did not confirm how much the sale would cost but said negotiations had been "complex" but would bring "wider benefits" to ferry services in the long term.
CMAL is entirely owned by the Scottish government, and Hyslop revealed it had been necessary to make a "shareholder directive" to the CMAL board to conclude the deal. Hyslop said the port would remain the main port for ferry services from the mainland to Arran.
Speaking in Holyrood, Hyslop said: "This purchase will secure the port in public ownership to allow us to focus on the redevelopment of the facility as the primary mainland port for Arran. There is work to be done to move forward to tender for the port redevelopment, but CMAL are already considering short term work to ensure resilient operations whilst the MV Caledonian Isles continues to operate from Ardrossan and we are committed to funding a two port service until the major work starts."
Ministers also announced Ferguson's shipyard in Port Glasgow is to be directly awarded contracts to build four new vessels.
| Re: Caledonian MacBrayne ferries in Scotland Posted by grahame at 08:05, 4th March 2026 | ![]() ![]() ![]() |
Isn't that the same yard which had the massive overruns/overspends on the last ferry contracts given to them by the Scottish Assembly?
Yes.
But - it's the only yard of the sort left, and it's now owned by the nation, and it has far more first hand experience of handling difficult contracts through political minefields.
| Re: Caledonian MacBrayne ferries in Scotland Posted by TaplowGreen at 07:58, 4th March 2026 | ![]() ![]() ![]() |
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 01:56, 4th March 2026 | ![]() ![]() ![]() |
Ferguson shipyard to be given contracts to build four new ships
The publicly-owned Ferguson shipyard is to be directly awarded contracts to build four new vessels under plans announced by the Scottish government.
Ministers have proposed that the Clyde yard be commissioned to build two small ferries as well as a marine research vessel and a marine protection ship.
The decision, announced in the Scottish Parliament, is subject to a due diligence process.
Transport Secretary Fiona Hyslop said another contract, to replace the CalMac ferry MV Lord of the Isles , would not be directly awarded, but would go to a competitive tendering process.
In a statement to parliament, she proposed that contracts to build two new vessels for the Sound of Harris and Sound of Barra - under Phase Two of the Small Vessel Replacement Programme - are directly awarded to Ferguson Marine.
Shortly afterwards, Deputy First Minister Kate Forbes announced plans to award Ferguson Marine contracts to replace the Scotia marine research vessel, and the Minna marine protection vessel.
Forbes told parliament that the award of the four contracts would help unlock up to £14.2m of promised funding to modernise the Port Glasgow shipyard.
MSPs also heard that the contract for a replacement for MV Lord Of the Isles would go to open tender in the next few weeks with a view to placing an order with a shipyard later this year, despite calls for it also to be directly awarded to Ferguson's.
Forbes said the government planned to directly award the contract to replace Minna, a fisheries protection vessel previously built by Ferguson's
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 21:54, 10th February 2026 | ![]() ![]() ![]() |
Crew of new CalMac ferry involved in dramatic Moroccan rescue
The CalMac crew launched a rescue mission off the coast of Morocco
The crew of a new CalMac ferry have helped save a man from the sea off from Morocco during a dramatic night time rescue.
The MV Isle of Islay is currently making its way to Scotland after being built in a Turkish shipyard.
The ferry had to leave its berth in Gibraltar due to stormy conditions and while in Moroccan waters the crew spotted a man in the water.
The crew quickly deployed the fast rescue craft to recover him and get him onboard. The man was looked after onboard for "several days" before being handed over to Moroccan authorities.
Louis de Wolff, CalMac's fleet management director, said: "CalMac crews are well-trained in acting fast to take part in rescues at sea, often supporting the coastguard in Scottish waters. None of us expected MV Isle of Islay to be involved in a rescue so soon after being delivered, but it is testament to the professionalism of our crew that the individual was saved from dangerous sea and weather conditions in just a few minutes."
The ferry, which is the first of four being built in Turkey, is facing difficult conditions on its journey to Scotland. Across several days last week, windspeeds in the local area were consistently higher than 30 knots and gusting at over 50 knots.
The vessel sheltered off the east coast of Morocco before berthing at Almeria port over the weekend. It will remain there until later this week when an anticipated weather window will allow the vessel to sail to A Coruña in northern Spain.
From there the ship will head across the Bay of Biscay which is known for its rough seas, to reach UK waters when there is a suitable weather window.
MV Isle of Islay, before setting off from the Turkish shipyard where it was built
De Wolff added: "We're bringing the vessel home in winter, when sea and weather conditions in the Mediterranean and North Atlantic, where we'll be headed next, are at their most treacherous. This has been compounded by a series of storms hitting the Iberian peninsula over the last two weeks. The crew continue to do a first-class job in bringing her closer to Scotland and we will confirm arrival details nearer the time."
When it arrives in Scotland the vessel, which can carry 450 passengers and 100 cars or 14 HGVs, will serve Islay and Jura.
| Re: Caledonian MacBrayne ferries in Scotland Posted by Oxonhutch at 18:06, 24th December 2025 | ![]() ![]() ![]() |
Hadn't realised the Queen Mary was so small
| Re: Caledonian MacBrayne ferries in Scotland Posted by TaplowGreen at 14:41, 24th December 2025 | ![]() ![]() ![]() |
Beautiful vessels. Thank God they weren't commissioned by the SNP, they'd probably still only be half built.
| Re: Caledonian MacBrayne ferries in Scotland Posted by grahame at 09:35, 24th December 2025 | ![]() ![]() ![]() |
May I post here, to the effect that I have probably only continued to quote such ongoing 'news' updates from the BBC, as they enable me to add yet more fresh images of ferries on this forum.
I love ferries. CfN.
The Paddle Steamer group at https://www.facebook.com/groups/1486421944705081/ is allowing - in the run up to Christmas - the sharing of picture and stories about other vessels running on similar routes. Here - shared from the group - are two of which my memories are fond personal ones
| Re: Caledonian MacBrayne ferries in Scotland Posted by GBM at 15:02, 23rd December 2025 | ![]() ![]() ![]() |
The ride home from Cemre is going to be a plum job for the crew if they haven't retired by then. It's on the Asian side of the Sea of Marmara, close the the Bosphorus (translation: Ox-ford). Tourists pay good money for a cruise along that route.
In my previous to previous occupation, we discharged product oil just North of Istanbul, then back out into the Meddi Sea.
Going back down the Bosporus Strait (compulsory pilotage and single line traffic), our Old Man (Captain) found it quite amusing that we headed a long line of outgoing ships.
Right behind us was a Russian Warship, and all those in our line confined to our top speed of around 11 knots.
Guaranteed the Russians would have liked to 'get a move on'.
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 22:30, 22nd December 2025 | ![]() ![]() ![]() |
| Re: Caledonian MacBrayne ferries in Scotland Posted by TonyK at 22:01, 22nd December 2025 | ![]() ![]() ![]() |
Complete and ongoing fiasco from Day 1 of the procurement process.
Even by the usual standards of public investment, this has been a shocker. I would expect Turkey to be cheaper than elsewhere, as it is for dental implants and weight loss surgery.
| Re: Caledonian MacBrayne ferries in Scotland Posted by TaplowGreen at 08:52, 20th December 2025 | ![]() ![]() ![]() |
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 04:47, 20th December 2025 | ![]() ![]() ![]() |
CalMac ferry Glen Rosa delayed again by up to six months
MV Glen Rosa, seen here leaving dry dock in Greenock, will have to return for a longer docking to fix corrosion problems
The delivery date for MV Glen Rosa - the second of two dual-fuel ferries being built for CalMac - has been pushed back by up to another six months.
The state-owned Ferguson shipyard said corrosion had been discovered during recent inspections and the ship will require an extra period in dry dock next year.
In a letter to MSPs, it said that would have a knock-on effect on commissioning the ferry, and it was now aiming to deliver it in the final three months of next year.
In a separate update, ferries body CMAL confirmed that MV Isle of Islay, the first of four CalMac ferries being built in Turkey, faces another short delay and will not be handed over this year.
MV Glen Rosa and its sister vessel MV Glen Sannox were meant to enter service in 2018 but the build has been plagued by design challenges and disputes over costs which saw the firm fall back into administration and nationalised.
The second of the hybrid propulsion ships has been moored at the quayside of the Port Glasgow shipyard for fitting out work since its slipway launch in April last year.
At the time of the launch it was hoped it would be handed over this autumn as it was in a far more complete state than Glen Sannox, famously sent down the slipway seven years earlier with painted-on windows and plywood funnels.
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 18:48, 11th December 2025 | ![]() ![]() ![]() |
Union warns 'inaction' could sabotage shipyard's survival
The biggest union at the publicly-owned Ferguson shipyard has claimed that government inaction is jeopardising its future.
GMB Scotland said a failure to deliver promised investment or new orders to Ferguson Marine would amount to "sabotage". The union has been calling for a direct award of a new CalMac ferry order to help the Port Glasgow yard restore its reputation after delays and huge cost overruns building two dual-fuel ships.
Deputy First Minister Kate Forbes said the shipyard was of "national importance" and the government had previously acted to save jobs but any contract awards must satisfy procurement and state subsidy rules. During a debate at Holyrood on Tuesday she also made clear the release of modernisation funding was dependent on the firm presenting a revised business plan which factored in new orders.
The Holyrood debate discussed a report from the parliament's public audit committee which criticised previous governance failures but also called for more support for the shipyard to help it become more competitive. It warned the shipyard's viability was at risk without urgent action to address years of underinvestment and give the firm "a realistic chance" of securing new work.
GMB Scotland general secretary Louise Gilmour said the report should serve as an "emergency flare".
"The public audit committee could not have sounded the alarm more clearly or loudly over the future of Ferguson Marine," she said. "Its report demanded swift and effective action from the Scottish government but, in the six months since, we have heard only excuses and seen no action at all." She said ministers from John Swinney down had taken turns to "wring their hands and tell us how complicated it is".
"Scotland has a publicly-owned shipyard which successfully built small ferries for generations and a publicly-owned ferry company that urgently needs them. It is not that complicated," she added.
In September, a cross-party coalition of community leaders, trade unions, and local politicians urged First Minister John Swinney to award the contract for a replacement for the CalMac ferry MV Lord of the Isles directly to the shipyard.
The project has been ready to go to procurement since mid-summer, but three months on, no timescale has been given for a decision.
Forbes said any such award must be lawful and Transport Scotland was still considering the business case.
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 17:52, 2nd December 2025 | ![]() ![]() ![]() |
New delay for Turkish-built CalMac ferry MV Isle of Islay
The first of four new CalMac ferries being built in Turkey has been delayed again.
Caledonian Maritime Assets Ltd (CMAL) said it still hoped to take delivery of MV Isle of Islay before Christmas but warned this would be a "challenge".
CMAL had previously told MSPs it expected the ship to be handed over in November, before making the two-week voyage to Scotland.
The government-owned ferries agency says a number of issues are still being addressed before the ferry can be signed off by UK regulators.
MV Isle of Islay, which will will operate on the Kennacraig to Islay route, is the first of four 95m-long ferries being built for the CalMac fleet at the Turkish Cemre shipyard.
When the contract was awarded it was due for delivery in October last year, but construction has been hit by a series of delays which CMAL says were due to supply chain issues and labour shortages.
In an update letter to Holyrood's net zero, energy and transport committee, CMAL said the UK's Maritime and Coastguard Agency (MCA) carried out a final survey in the last week of October, and the shipyard is addressing issues that were raised. MCA inspectors are due to carry out another final survey on 8 December.
The update letter said: "If all completion activities go smoothly, the shipyard is targeting delivery of MV Isle of Islay prior to the Christmas period. This will be a challenge but CMAL, CalMac, Cemre and the regulatory authorities are all working hard and collaboratively towards reaching this target date for vessel delivery just before the Christmas holidays."
The journey to Scotland will involve a refuelling stop at Gibraltar and a journey across the Bay of Biscay. After arriving in Scotland, CalMac will carry out crew familiarisation and berthing trials at various ports before the ship enters service.
Work is continuing at the Cemre shipyard on MV Loch Indaal - also destined for the Islay route - and two other ferries MV Lochmor and MV Claymore will eventually serve the Western Isles.
CMAL said costs remained "on budget".
| Re: Caledonian MacBrayne ferries in Scotland Posted by TonyK at 22:14, 10th November 2025 | ![]() ![]() ![]() |
Over £1m spent on sending Scottish ferry staff to Turkey
More than £1m has been spent sending CalMac and CMAL staff to Turkey to oversee the construction of four new ferries, a freedom of information request has revealed.
The two companies, which operate and manage Scotland's nationalised ferry networks, have spent £1,016,162 on remuneration, subsistence, accommodation, flights and car hires on staff visiting the Turkish yard since 2022.
The Scottish Conservatives, who obtained the figures, said taxpayers were being "left to pick up the tab" for the SNP's "ferries fiasco which has left islanders without the vessels they need".
CalMac and CMAL said their staff's work in Turkey was "vital" and "essential".
A CalMac spokeswoman said most of the money related to staff costs, including wages, which would have been paid regardless of where the crew were. She said the extra amount - £23,000 - was for travel and subsistence costs which covered flights to and from Turkey, hotel accommodation, and general subsistence costs.
CMAL also said the same wages would have been paid to its staff regardless of travel costs.
The Cemre shipyard in Turkey was awarded the contracts to build four new vessels worth more than £200m.
These vessels are the MV Isle of Islay - which is due in November and will operate on the Kennacraig to Islay route - the MV Loch Indaal, MV Lochmor and MV Claymore at six-month intervals after the first vessel's delivery.
CalMac sent eight staff to Turkey, spending £845,981, while £170,181 was spent on five CMAL employees.
One Ferguson Marine employee was also sent to Turkey but the costs were covered by CMAL.
The first of the Turkish ferries, MV Isle of Islay, was launched a year ago by Morag McNeill, the chairwoman of CMAL, in a ceremony at the Cemre shipyard.
The nationalised Ferguson Marine is currently building two separate ferries - the Glen Sannox and the still under construction Glen Rosa.
The costs of the vessels has risen to more than four times their original £97m price tag, and were pushed back for completion several times.
Tory transport spokeswoman Sue Webber said taxpayers were being forced to foot yet another hefty bill. "After squandering half-a-billion pounds on the Glen Sannox and Glen Rosa, ministers have blown another £1m flying staff to Turkey to keep tabs on the ferries being built there. Some project oversight is understandable after the huge problems with the Ferguson-built ferries - but this level of spending seems excessive."
Webber said the SNP had "betrayed islanders and taxpayers at every turn" by leaving remote communities reliant on out-of-date vessels while "letting costs spiral out of control for hard-pressed Scots".
"SNP ministers, who are responsible for Ferguson Marine, must finally provide the support the yard needs to compete, so that ferries can be built here in Scotland, not abroad," she added.
The CalMac spokeswoman said: "New vessels are an essential addition to the CalMac fleet and we are very much looking forward to MV Isle of Islay joining us next month. Staff and crew have been spending valuable time at the yard in Turkey carrying out vital work to support CMAL with the build process and to ensure that the vessel is built as specified, and meets all legal and classification standards. This is the same as the process involved for MV Glen Sannox before she joined the fleet."
She added that staff working in Turkey included marine and technical specialists as well as the senior crew who will be responsible for the vessel's safe passage to Scotland. "Their role includes the implementation of the important processes and procedures required to gain the necessary safety management and other certification needed to operate the vessel in UK waters," she added. "Thirteen brand new vessels will be joining CalMac by 2029 and will be of huge benefit to service resilience and reliability, to the benefit of all customers, including island communities."
A spokesperson for CMAL said: "CMAL is required on site throughout the build of vessels to provide essential quality assurance and supervision. Remuneration is the same regardless of the build location, and travel and accommodation costs are standard. These form part of the overall project budget, which remains on target."
A Transport Scotland spokesperson said: "As people would expect, CMAL has been and is continuing to work closely with the shipyard to reduce the time between delivery of each of the new vessels where possible. We expect delivery of MV Isle of Islay later this year and MV Lochmor was successfully launched on 23 August 2025 marking another construction milestone."
That's much ado about nothing. I would assume you can't learn how to sail a particular ferry whilst sailing on its maiden voyage across the Med and up the Atlantic from a YouTube video.
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 13:20, 25th October 2025 | ![]() ![]() ![]() |
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 19:28, 13th October 2025 | ![]() ![]() ![]() |
New chairman to take the helm of nationalised shipyard
A new interim chairman has been appointed for Ferguson Marine, the nationalised shipyard in Port Glasgow.
Duncan Anderson will take over from the current board chairman Andrew Miller, who will step down at the end of his three-year term next month. Mr Anderson is a chartered marine engineer with more than 40 years of experience in ship operations and shipbuilding.
The change of board leadership comes at a crucial time for the shipyard, which is working to complete the CalMac ferry MV Glen Rosa as well as seeking new orders to secure a future for its 300-strong workforce.
Mr Miller, who was appointed chairman in 2023 after a seven-year stint at state-owned Prestwick Airport, was at times a controversial figure. He played a key role last year in the sacking the former chief executive David Tydeman, seen by many as a stabilising figure who made progress in delivering the CalMac ferry MV Glen Sannox after years of delays. But he was dismissed after a series of missed deadlines and substantial cost increases, with the chairman also claiming he had offered "unsubstantiated opinions" to MSPs without the authorisation of the board.
Earlier this year, Mr Miller was criticised for "tone deaf" comments when he compared the effect of media scrutiny of Ferguson's to the physical abuse of children who then struggled to become "well-rounded" adults.
The chief executive of Ferguson Marine, Graeme Thomson, who joined the firm in May, paid tribute to the outgoing chairman, saying "several significant milestones" were achieved during his tenure. Ferguson Marine said Mr Miller would leave the role at the end of November "to focus on future work arrangements, overseas obligations, and family commitments".
It said the new interim chairman had been involved in the construction of more than 100 vessels during his career in shipyards in Europe, the Middle East and South East Asia.
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 19:56, 6th October 2025 | ![]() ![]() ![]() |
Shipyard's promised investment is 'conditional' - Forbes
MSPs have previously warned that the Ferguson yard on the Clyde needs urgent investment to allow it to survive
Only a small fraction of the £14.2m investment promised 16 months ago to help the nationalised Ferguson shipyard win new orders has so far been handed over, the Scottish government has confirmed.
Deputy First Minister Kate Forbes said 11 funding requests had been approved, totalling £570,0000 since she first announced the investment in June last year. But in a letter to MSPs , she said the remainder of the modernisation money was conditional on a "robust business case" being made by the Ferguson board.
GMB, the main union representing Ferguson workers, said the firm was being placed in a "Catch 22" situation. It called on the government to give it a new ship order which would then unlock the investment funding.
The Port Glasgow shipyard, which employs about 300 workers and apprentices, is currently working to complete MV Glen Rosa, the second of two gas-powered CalMac ferries that have been beset by design problems and delays. While it has secured some subcontracting work for BAE Systems, it has no ship orders after the ferry is completed in the second quarter of next year.
Holyrood's public audit committee wrote to Kate Forbes last month, questioning the government's commitment to the shipyard after it emerged that procurement orders for major equipment items had been withdrawn. In her reply, Forbes suggested that the firm had simply issued these notices as a means of testing the market and gaining information about potential delivery times.
It is understood the equipment - a semi-automated panel line and profiling and cutting machines - was recommended by consultants First Marine International, which was tasked with reviewing the shipyard's productivity three years ago.
In her letter, Forbes said all 11 requests for capital funding from the shipyard so far had been approved, and the money had been spent on building repairs and health and safety as well as some equipment modernisation. But she added: "Access to the remainder of the modernisation funding will be conditional on a clear, board-approved business case, evidenced through the revised business plan".
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 08:58, 15th September 2025 | ![]() ![]() ![]() |
Campaigners call for direct award of ferry to Ferguson shipyard
The proposed design of the replacement Lord of the Isles would be smaller and less complex than the dual fuel ferries recently built in Port Glasgow
A campaign including community, civic and religious leaders as well as politicians from three parties is calling for more government help for the Ferguson shipyard.
An open letter to First Minister John Swinney says the nationalised firm in Port Glasgow should be directly awarded a contract for a new CalMac ferry, as it looks to move on from the controversy over two delayed and overbudget ships.
Local politicians from Labour, the SNP and the Scottish Conservatives as well as the Bishop of Paisley have signed the letter, drawn up by the GMB union.
Transport Scotland said any direct award would have to comply with rules on procurement and state subsidy in order to avoid a risk of legal challenge.
The campaign is asking the Scottish government to ensure a replacement for MV Lord of the Isles is manufactured at the nationalised yard, to help restore its reputation after a "bruising 10 years".
Ferguson Marine has been mired in controversy over the construction of two larger CalMac vessels, MV Glen Sannox and Glen Rosa, which involved a demanding specification and a gas propulsion system unfamiliar to UK yards.
The yard employs about 300 workers and apprentices in an area which has high levels of deprivation. In the space of 18 months recently it lost another 1,200 jobs as several major employers closed down or relocated.
Campaigners say that while the reasons for the yard's problems are still debated, the "skilled and committed workforce is entirely blameless".
The letter says that foreign firms with "bids underpinned by low wages" will always beat UK shipyards on cost, but the social and economic value of Ferguson Marine to Inverclyde "is incalculable".
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 15:15, 8th May 2025 | ![]() ![]() ![]() |
An update, from the BBC:
CalMac directly awarded new ferry service contract
The contract to run Scotland's west coast ferry services in future has been directly awarded to the existing publicly-owned operator CalMac Ferries Ltd.
The Scottish government said the service would now be focused on a "public service model" instead of being run on a commercial basis.
The latest contract for the Clyde and Hebridean Ferry Service (CHFS) had been due to expire last September but was extended by a year.
Ministers had indicated that a direct award, without a competitive tender, was their preference, but they needed more time to ensure this could be done without a legal challenge.
No details of the contract's value or duration were given, but the previous eight-year contract for the heavily-subsidised ferry service was worth £975m. One estimate has suggested a subsidy of £3.7bn over 10 years would now be required.
CalMac is the UK's biggest ferry operator and has held the most recent contract to run the routes since 2016, serving 50 destinations.
But the firm has struggled in recent years to maintain services with an ageing and increasingly unreliable fleet which it leases from another government-owned firm. Since 2007, the ships and some of the harbours it relies on have been owned by Caledonian Maritime Assets Ltd or CMAL, in a division designed to comply with EU competition rules.
Delays in replacing the older vessels, in part due to the problems with two new dual-fuel ferries ordered a decade ago, have stretched the service almost to breaking point, with many vessels beyond their expected service life.
Transport Secretary Fiona Hyslop said the direct award to CalMac signalled a new public service model rather than treating it as a commercial contract. She said this would lead to change that better served the needs of island communities, and she denied it would be seen as a reward for failure.
She told BBC Scotland News: "There are over 170,000 sailings. There have been cancellations, some for technical reasons, some for weather reasons, but the vast majority of CalMac's sailing are delivered very well in indeed. If you talk to islands the support for the frontline services of CalMac staff is very appreciative."
CalMac chief executive Duncan Mackison welcomed the emphasis on treating the Clyde and Hebridean routes as a public service and promised improvements. He said: "During the extension period for the current contract, we recognised the need for change and are already driving change through the expansion of local teams, enhanced community engagement and improved responsiveness to local requirements.".
The Clyde and Hebridean Ferry Service contract is offered as a single "bundle" which the government says has the advantages of protecting less profitable lifeline routes and delivering economies of scale. Critics of that choice have argued that unbundling certain routes and allowing competitive tender would encourage efficiencies.
The Northlink routes to Orkney and Shetland are currently operated by privately-owned Serco, with the government setting fares and service levels and paying the firm a subsidy to make up the difference between costs and revenue.
Hyslop said it was the government's intention to continue putting the Northern Isles services out to competitive tender.
Trade unions have backed the direct award of the west coast routes to the existing publicly-owned operator, with the RMT union calling for a "People's CalMac". The unions have, however, been critical of the government's approach to ferry procurement which has left CalMac with ageing vessels prone to breakdown.
The GMB union also contrasted the direct award to CalMac with the recent £160m small ferries contract that went to tender and was won by a Polish firm rather than the nationalised Ferguson shipyard in Port Glasgow.
GMB Scotland general secretary Louise Gilmour said the government should now merge CalMac and CMAL to encourage a more joined-up approach focused on supporting both ferry services and Scottish industry. "Our islands' need for reliable and modern ferries can drive a healthy and secure shipbuilding and maritime sector," she said. "It seems an obvious ambition with significant economic benefits and one that should not be beyond Scotland's capabilities to deliver."
The Scottish Conservatives said the direct award provided continuity but that CalMac would continue to struggle unless the government provided it with a resilient fleet. The party's transport spokeswoman Sue Webber said: "Islanders have been betrayed by the SNP time and time again, and any ferry provider is only as good as the fleet it has to work with."
(Article continues)
(Article continues)
| Re: Caledonian MacBrayne ferries in Scotland Posted by broadgage at 19:13, 24th March 2025 | ![]() ![]() ![]() |
Did not know that hitachi built ferries.
| Re: Caledonian MacBrayne ferries in Scotland Posted by TonyK at 17:34, 24th March 2025 | ![]() ![]() ![]() |
Glen Sannox ferry sailings to resume after crack repair
The new Glen Sannox ferry is expected to resume sailings on Sunday after repairs have been completed on a crack in the ship's hull.
The brand new vessel only began operating in January after being delivered almost seven years late and costing more than four times the original contract price.
CalMac confirmed the news after divers carried out a detailed assessment of the damage on Saturday. The ferry had been operating for just over two months between Troon in South Ayrshire and Brodick in the Isle of Arran.
A CalMac spokesman said: "The dive inspection has identified a hairline crack on a weld seam on MV Glen Sannox's hull earlier today and we can confirm repairs are now underway at Brodick and expected to complete later today. We anticipate MV Glen Sannox to resume timetabled service on Sunday 16 March and will confirm this evening."
It added the MV Alfred would operate an extra return sailing on Saturday to provide cover and said the "vast majority" of booked customers had been able to travel.
(Article continues)
(Article continues)
Is this what they mean by "teams of crack divers"?
| Re: Caledonian MacBrayne ferries in Scotland Posted by Clan Line at 16:27, 17th March 2025 | ![]() ![]() ![]() |
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 13:46, 17th March 2025 | ![]() ![]() ![]() |
Ferguson shipyard misses out on new CalMac ferry order
The nationalised Ferguson shipyard has missed out on a crucial order for seven small all-electric ferries for west coast operator Caledonian MacBrayne.
Ferries procurement agency CMAL has instead named a Polish firm, Remontowa, as preferred bidder for the small vessels replacement programme (SVRP).
Ferguson's, the last commercial shipyard on the Clyde, had vowed to bid "aggressively" for the contract and had made it onto a shortlist of six bidders.
A total of £175m has been allocated to build the new "loch class" vessels and complete harbour and shore power upgrades. The first ferries are due to join the CalMac fleet in 2027.
The contract was a key part of Ferguson Marine's five-year business plan following delays and cost overruns in the construction of two much larger ferries for CalMac.
The 50m (164ft) all-electric ferries are similar to ones it has delivered successfully in the past and could have given it a pipeline of repeatable work lasting several years.
The Port Glasgow shipyard is still pursuing alternative business opportunities, including defence sub-contracting work from BAE Systems and private sector work.
Scottish government-owned CMAL said the award to the Polish firm represented "best value" for the public purse. But Scottish Labour said the government had failed to stand up for key Scottish industries, while the Scottish Conservatives claimed SNP mismanagement could prove to be the "death knell" for Ferguson's.
The Ferguson bid for the SVRP is understood to have ranked well for quality but missed out due to the difficulties in matching overseas yards on cost.
Chief financial officer David Dishon said: "We are very proud of our bid and although we priced it competitively, we were up against extremely tough competition from yards outside the UK which benefit from significantly reduced operating costs and advanced capital investment programmes. The weighting for price will therefore place all UK yards at a disadvantage. However, we were pleased to see Ferguson Marine's bid rated so highly on quality."
Remontowa, based in Gdansk, has previously built the CalMac ferries MV Argyle, MV Bute and MV Finlaggan, and was runner up to Ferguson's when the contracts for MV Glen Sannox and MV Glen Rosa were awarded in 2015.
A concept design drawing of the new all-electric ferries.
CMAL chief executive Kevin Hobbs said the bids had been assessed against a range of technical and financial criteria, weighted 65% on quality and 35% on cost. He said: "It is our responsibility to follow the Public Procurement Strategy for Scotland and appoint a yard capable of producing quality vessels which meet the needs of islanders, but that also deliver the best value for the public purse. We are confident in Remontowa's ability, and have worked with them before, most recently with the delivery of the MV Finlaggan in 2011."
There now follows a 10-day "standstill period" after which the contract will be signed.
The new ferries will operate on the Colintraive-Rhubodach (Bute); Lochaline-Fishnish (Mull); Tarbert (Loch Fyne)-Portavadie; Iona-Fionnphort (Mull); Sconser-Raasay; Tobermory-Kilchoan (Mull); and Tayinloan-Gigha routes.
Phase two of the programme will see the purchase of three more vessels which are capable of handling more challenging sea states, but that contract will go to tender separately.
(Article continues)
(Article continues)
| Re: Caledonian MacBrayne ferries in Scotland Posted by grahame at 05:52, 16th March 2025 | ![]() ![]() ![]() |
Additional sailings have also been added between Lochranza in Arran and Claonaig in the Kintyre peninsula. The operator said all passengers should have a booking prior to arriving in Troon, adding that those who had not booked could not be guaranteed travel
Claonaig is a VERY long way round and I don't think public transport goes anywhere near it ... I suppose for passengers with their own transport headed for northern Dumbartonshire it might have been a viable alternative.
Even when Glen Sannox is running (and it seems it's back after being patched up later today), it's running to and from a jetty in Troon which is not rail connected and it involves a transfer bus, rather than the service from Arran running to Ardrossan Harbour on the mainland which [is/was] adjacent to - err - Ardrossan Harbour station
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 20:54, 15th March 2025 | ![]() ![]() ![]() |
(Article continues)
(Article continues)
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 15:02, 15th March 2025 | ![]() ![]() ![]() |
Divers assess crack in hull of new Glen Sannox ferry
Divers are inspecting the new Glen Sannox following the discovery of a crack in the ship's hull.
All of the Glen Sannox's Saturday sailings have been cancelled while the MV Alfred will operate an additional service.
CalMac said it would provide an update on Sunday's sailings once a dive team had carried out a full assessment.
The ship had been operating for just over two months between Troon in South Ayrshire and Brodick in the Isle of Arran.
The vessel was removed from service on Friday after a crack was found on a "weld seam close to the waterline".
The ferry operator said reports that the boat had hit the harbour or that water was leaking into the car deck were "categorically untrue". However, CalMac advised that a "very small amount of water" had entered part of the rear of the ship near the steering gear.
Additional sailings have also been added between Lochranza in Arran and Claonaig in the Kintyre peninsula. The operator said all passengers should have a booking prior to arriving in Troon, adding that those who had not booked could not be guaranteed travel.
Divers from Shearwater Marine Services arrived at the port on Saturday morning.
A decision about Sunday's sailings will be taken later, the operator said in a statement on its website. It added: "We apologise for the disruption, and our port teams and customer engagement centre will be working hard to contact affected customers."
The Glen Sannox has space for 127 cars and 852 passengers.
(Article continues)
(Article continues)
| Re: Caledonian MacBrayne ferries in Scotland Posted by TonyK at 17:14, 13th January 2025 | ![]() ![]() ![]() |
The old age of the CalMac fleet can be compared with the old age of the GWR local / regional train fleet.
Put like that, they're quite new.
| Re: Caledonian MacBrayne ferries in Scotland Posted by grahame at 11:57, 13th January 2025 | ![]() ![]() ![]() |
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 21:29, 12th January 2025 | ![]() ![]() ![]() |
Scotland's ferries saga ship to finally set sail
The ship at the centre of Scotland's long-running ferries saga is scheduled to make its first passenger voyage before dawn on Monday.
MV Glen Sannox is due to leave Troon harbour in South Ayrshire, bound for the Isle of Arran, on its first sailing at 06:30.
But a yellow alert, external, issued by Caledonian MacBrayne on Sunday, said it may be subject to delay or cancellation due to high winds.
The ship - which was meant to be delivered almost seven years ago - completed a return test sailing on Sunday and is the first new large vessel to join the UK's largest ferry fleet in nearly a decade.
With a capacity for 127 cars and 852 passengers, Glen Sannox will help relieve pressures on the state-owned operator which has struggled in recent years to maintain services with ageing and increasingly unreliable vessels.
(Article continues)
(Article continues)
| Re: Caledonian MacBrayne ferries in Scotland Posted by CyclingSid at 17:09, 30th December 2024 | ![]() ![]() ![]() |
Oops! 'Green' ferry emits more CO2 than old diesel ship
https://www.bbc.co.uk/news/articles/cwy87e72yg3o
Hope this will not be the fate of the rumoured electric Isle of Wight ferry
https://onthewight.com/red-funnel-to-add-zero-emission-electric-ferry-for-eco-friendly-isle-of-wight-travel-by-2025/
In the light of the CalMac experience I wonder how far late 2025 will stretch.
| Re: Caledonian MacBrayne ferries in Scotland Posted by grahame at 10:43, 21st November 2024 | ![]() ![]() ![]() |
Thanks for posting that, Chris. I had ... wondered ... whether I should but thought I was probably the only one interested. RONG! ..
I wonder that they have enough ships left in the fleet - sort of TOC on water limitations, frugality and late delivery of complex new vehicles. New Glen Sannox ... when?
It appears to have been delivered today for entry into service in January - https://www.bbc.co.uk/news/articles/cew1wxx0d0jo
The long-delayed ship at the centre of Scotland's ferries saga has been handed over by the Ferguson shipyard, exactly seven years after it was launched.
MV Glen Sannox, destined for CalMac's Arran route, is the first new large vessel for the west coast ferry fleet in nearly a decade.
The ferry operator will now conduct several weeks of crew familiarisation trials before the ship carries its first passengers in January.
| Re: Caledonian MacBrayne ferries in Scotland Posted by grahame at 15:35, 18th November 2024 | ![]() ![]() ![]() |
| Re: Caledonian MacBrayne ferries in Scotland Posted by Chris from Nailsea at 15:26, 18th November 2024 | ![]() ![]() ![]() |
Islanders bid a fond farewell to MV Hebridean Isles
One of Scotland's oldest lifeline ferries has been retired after nearly 40 years of service.
With two blasts of its horn, MV Hebridean Isles bade farewell as it left the quay at Stornoway for a final time on Sunday, bound for Glasgow before it goes to the breakers.
For islanders, whose lives are so interwoven with the sea, the ships of Britain's biggest ferry operator Caledonian MacBrayne are more than just large lumps of steel and aluminium.
"Heb Isles" leaves behind a ship-shaped hole in the hearts of many former passengers and seafarers who have come to regard it as a trusty old friend.
The ship was given the name of the islands it was destined to serve on a sunny day in July 1985 at the long-gone Cochrane shipyard at Selby, North Yorkshire.
It was a first on two counts - the "lady sponsor" the Duchess of Kent was the first member of the Royal Family to name a CalMac vessel. And it was the ferry operator's first vessel built outside of Scotland. Two pipers were sent down to play the Skye Boat Song at the launch ceremony.
Margaret Thatcher was in No 10, Sister Sledge was Number One in the charts - and health and safety rules were somewhat more relaxed than today. Shipyard workers hammered away the last supporting "shores" and wedges, then ducked and dashed for cover as the huge vessel slid above their heads in a spectacular sideways launch into the River Ouse.
The ship had cost £5.5m - and after a few months of fitting out, it made its maiden voyage off Scotland's west coast in December. For 15 years it was deployed on the "Uig Triangle" - between Skye, North Uist and Harris - before moving to the Islay crossing, but it has served most of Scotland's sea routes in its time.
Aside from the scheduled sailings, the crew would voluntarily give up their time to put on special "booze cruises" to raise money for island charities. The first, in 1992, saw a country and western band perform on the car deck, as thousands of pounds were raised to help purchase a breast cancer scanner for the Western Isles.
(News article continues, with more images)
| Re: Caledonian MacBrayne ferries in Scotland Posted by Clan Line at 21:17, 5th March 2023 | ![]() ![]() ![]() |
Another of Nicola's legacies............
https://www.bbc.co.uk/news/uk-scotland-scotland-politics-60860642
Above link (24/03/22):
"The latest estimate is that the ferries will be five years late, and will cost up to £250m - more than two and a half times the original budget of £97m".
Latest: https://www.heraldscotland.com/news/homenews/23363699.fears-new-ferries-may-never-sail-ferguson-marine-budget-stalls/
"a further £87m was needed to deliver the ferries with overall costs at that point snowballing from the original £96m to £340m"
| Re: Caledonian MacBrayne ferries in Scotland Posted by TaplowGreen at 17:12, 5th March 2023 | ![]() ![]() ![]() |
| Caledonian MacBrayne ferries in Scotland Posted by grahame at 17:06, 5th March 2023 | ![]() ![]() ![]() |
Ferry operator CalMac has warned the next two years will be "challenging" for residents of Scotland's islands due to the age of its fleet.
Chief executive Robbie Drummond also apologised to residents of Arran for recent disruption to services.
Mr Drummond said a shortage of spare vessels was also driving disruption.
A third of CalMac's ferries are more than 30 years old, and almost half the largest ships are beyond their expected service life.
Issues with three ferries have resulted in disruption across the company's west coast network.
CalMac is another government controlled transport operator, and they are having trouble too trying to run the service that they are supposed to with too few assets, and those they have getting more unreliable as they get worn out.
Is this habit of insisting on too-few, too-old assets due to poor planning, incompetence, or a cynical calculation which allows significant poor reliability to save money.
