Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by TaplowGreen at 09:48, 23rd February 2025 | ![]() ![]() ![]() ![]() |
Alterations to services between Westbury and Swindon via Melksham
Due to engineering works not being finished on time at Swindon all lines are closed. Disruption is expected until 10:30 23/02.
Train services between Westbury and Swindon via Melksham may be delayed by up to 45 minutes or revised.
As a result of engineering work not being finished on time there will be severe delays / disruption to services on this route this morning. Please accept our aplogies for any inconvenience this may cause.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by GBM at 09:20, 23rd February 2025 | ![]() ![]() ![]() ![]() |
08:06 Warminster to Swindon due 08:58
08:06 Warminster to Swindon due 08:58 was terminated at Melksham.
It will no longer call at Chippenham and Swindon.
This is due to earlier engineering works not being finished on time.
09:08 Swindon to Westbury due 09:49
09:08 Swindon to Westbury due 09:49 will be started from Melksham.
It will no longer call at Swindon and Chippenham.
That has to be a first for Melksham?
A train terminating, then starting there!
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 09:19, 23rd February 2025 | ![]() ![]() ![]() ![]() |
Nothing on journey check about what passengers should do - purely "feature" not "benefit" which I was taught was not the way to do it in my sales training.
There is an x34 bus at 08:48 from Melksham to Chippenham (railway station if required) that goes past the top of station approach in Melksham - doesn't actually stop there normally, but it [sh/c]ould.
There is an x34 bus at 09:25 from Chippenham railway station to Melksham and Trowbridge (on Sunday, of course, it does not go to the stop near Trowbridge station, and even by the time it reaches Melksham and passes close to the station, the train will have left.
Lots of things illustrated by these goings on ...
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 08:57, 23rd February 2025 | ![]() ![]() ![]() ![]() |
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 05:52, 23rd February 2025 | ![]() ![]() ![]() ![]() |
14:47 Westbury to Swindon due 15:34
15:44 Swindon to Westbury due 16:25
15:44 Swindon to Westbury due 16:25 will be cancelled.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by Trowres at 20:41, 21st February 2025 | ![]() ![]() ![]() ![]() |
2M24 (see above) is running.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by Trowres at 19:25, 21st February 2025 | ![]() ![]() ![]() ![]() |
Strangely, it seems to have disappeared from Real Time Trains altogether.
On RTT, it has acquired "VCN" status, so you need to select the "CAN" option to view cancelled services. The reason given is ZW - unknown cause.
Also bearing a VCN status and ZW code on RTT is 2M34, the 20:14 Swindon-Westbury. There's nothing on Journeycheck about this service, and it is currently (at 19:22) shown on TIGER as "on time". Watch this space!
Incidentally, the 18:37 Westbury-Swindon was delayed at Trowbridge for about 25 minutes (due to a "broken down train"). It lost a further 5 minutes due to missing its slot on the single line through Melksham.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by bobm at 17:54, 21st February 2025 | ![]() ![]() ![]() ![]() |
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 08:49, 21st February 2025 | ![]() ![]() ![]() ![]() |
17:35 Swindon to Westbury due 18:19
17:35 Swindon to Westbury due 18:19 will be cancelled.
Busiest train of the day ... no alternative suggested except "get your money back and have a free journey on the next train" as it's over an hour later. Why chose this train to cancel if you're short of crew?
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by John D at 08:40, 21st February 2025 | ![]() ![]() ![]() ![]() |
Clearly not telling public the truth.
Train is announced as terminating early at Westbury (but the alleged fault allows it to continue from time of announcement through to Westbury, so if it could continue that far, could have got to Southampton).
Train is miraculously fixed at Westbury, and can be used to form another service missing a train.
2V58 the return train from Southampton is showing as cancelled for reason M8 (problem with the train), ie it's not available, although codes YR or YU (tactical unit swaps) sound more likely
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by TaplowGreen at 08:25, 21st February 2025 | ![]() ![]() ![]() ![]() |
16:23 Westbury to Swindon due 17:05
16:23 Westbury to Swindon due 17:05 will be cancelled.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 08:15, 21st February 2025 | ![]() ![]() ![]() ![]() |
And again ....
05:11 Gloucester to Southampton Central due 08:09
05:11 Gloucester to Southampton Central due 08:09 will be terminated at Westbury.
It will no longer call at Dilton Marsh, Warminster, Salisbury, Romsey and Southampton Central.
That is very odd indeed ...
So it was capped at Westbury due to a fault on the train, but then 5 minutes later conveniently able to form a train to Weymouth? Yes - there is a fault on the train (no loos reported on the Weymouth train) but it very much looks to me that "this is due to a fault on this train" is NOT why it didn't continue to Southampton - it was "hijacked" to form the Weymouth service. Am I reading this wrong? Are we being fed porkies?
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 07:52, 21st February 2025 | ![]() ![]() ![]() ![]() |
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 07:09, 21st February 2025 | ![]() ![]() ![]() ![]() |
And again ....
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 07:46, 18th February 2025 | ![]() ![]() ![]() ![]() |
Here we (don't) go again
05:11 Gloucester to Southampton Central due 08:09 was terminated at Westbury.
At least it says "this" train - so it's not been theived off the Southampton service to run the Weymouth train from Westbury this time
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 17:05, 17th February 2025 | ![]() ![]() ![]() ![]() |
16:23 Westbury to Swindon due 17:05 is being delayed between Melksham and Chippenham.
This is due to trespassers on the railway.
Will be formed of 3 coaches instead of 2.
18:37 Westbury to Swindon due 19:21
20:14 Swindon to Westbury due 20:57
21:16 Westbury to Swindon due 21:58
22:31 Swindon to Westbury due 23:12
Facilities on the 22:31 Swindon to Westbury due 23:12.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 06:36, 17th February 2025 | ![]() ![]() ![]() ![]() |
05:11 Gloucester to Southampton Central due 08:09 was 8 minutes late but is expected to be on time from Swindon.
Still connected with the Paddington train at Swindon - which looks like it might have been held back a few seconds. Good - no problem here.
The 05:11 from Gloucester in reality is a chaining together of a series of separate workings and through passengers from Gloucester to Southampton must be rare as hen's teeth. Even the crew changes along the way. It is scheduled to stop longer than is needed purely to drop off and pick up passengers at Swindon, Chippenham, Westbury and Salisbury and paths allowing could (and has been know to) make up much more time. Good - whilst extended station dallies are not to be encouraged, a margin of time in schedules to ensure that trains turn up and connect on time even if held up earlier in their or a previous journey makes sense - especially where though passengers at "pause" stations are a minority of passengers.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 10:06, 16th February 2025 | ![]() ![]() ![]() ![]() |
Another micro example of the macro failure to look out for the passengers - the customers?
Rather than just criticise, I should offer an alternative. The x34 bus now runs on a Sunday from Trowbridge to Chippenham, and tickets should be accepted on that and it should be included in the journey planner. Passengers who normally travel through Melksham should be allowed to travel via Bath Spa, changing trains there, and be advised they can do so at the same price which should be offered by the online booking applications once the cancelled train is removed from them. You will note than none of this "looking after the passengers" results in extra vehicle or staff miles on the ground - it's helping people use what's already there!
Looking wider (and not just for a solution this Sunday morning) in terms of train and bus interconnection at stations, the x34 is a fascinating case. The service runs seven days a week, daytime only; the Sunday service was revived quite recently after a gap of many years. Evening services, provided by a competing operator, were lost a decade ago when that operator pulled out of the route. Further study to follow ....
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 09:52, 16th February 2025 | ![]() ![]() ![]() ![]() |
10:46 Westbury to Swindon due 11:31
11:41 Swindon to Westbury due 12:22
11:41 Swindon to Westbury due 12:22 will be cancelled.
Zero information about any alternative ... but you are told about delay/repay. Another micro example of the macro failure to look out for the passengers - the customers?
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 08:57, 16th February 2025 | ![]() ![]() ![]() ![]() |
09:08 Swindon to Westbury due 09:49 will be cancelled.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 09:22, 14th February 2025 | ![]() ![]() ![]() ![]() |
Out of order - from yesterday:
The railway was closed at Trowbridge "at the request of the police due to ammunition being found near the line" and these things happen. The ongoing information at Melksham was AWFUL - for the longest time the 06:32 just said "delayed" and the 07:21 was on time. Even when the southbound train was stated with a time again - estimated 07:18 - the northbound train at 07:21 still said "on time". That makes a mockery of the "system knowledge" as it's predicting an impossibility on the single line and I found myself chatting with other passenger and telling them "not before 07:33" for the Worcester train.
"Delayed" on a 3 line screen is useless; there IS a big screen there (facing the car park) and all that was saying was the same thing with 2 lines each for the following 3 or 4 services. Could have been more descriptive. When I eventually got to Westbury, the screens there were showing distrupted train departures alternating with a desciption of what the problem was and why. Why on earth could the same not be done - automatically share across stations big and small with responsive design so there's no need for human input on a. station by station business at the time of extreme re-organisation?
I was at the Rail Innovation Exhibition yesterday (ironic) and lots of clever stuff. BUT there could be so much basic stuff done getting information right for passengers at the time of disruption - accurate (and not afraid to say "don't know"), consistent, and perhaps with interactive tools. Lots of things being displayed but frightening on the information display side as to how fragmented, partial and at times embryonic it is - leaving passengers literally out in the cold. I did a better job in Melksham reading my phone and helping to explain roughly what was going on from scant evidence.
Yes, I did try the help point. It was obvious to me that the 06:32 would miss the connection at Westbury on into the 07:00 to Paddington with my "this train only" ticket, and if that misses the next fastest way to London in the 07:21 change at Swindon. The nice chap on the help point told me that my next train was the 07:58 from Westbury and my ticket would be accepted on it, but that my advanced ticket was for that route only and would not be accepted if I took the next alternative which happened to use a different route (via Swindon) even if it got me there quicker. He then told me that I COULD use my ticket on SWR trains such as one that was running from Yeovil Pen Mill because "ticket acceptance is in place". I got the impression that his geography was not great and he was of the understanding that Yeovil is just a short walk up the road from Melksham.
2O19 "adjusted" to not run beyond Salisbury (it was so late that the school traffic it normally carries south of there would have gone on the following train operated by SWR if they could all get in!)
2M81 got to Westbury on time, and sat there until the line re-opened ... and for some considerable time thereafter. It was still there when I arrived at 07:30 when it should have left at 07:05 ... and stayed even longer as trains via Bath Spa were displatched out of order - perhaps because it was so late that "what's another 10 minutes?". There were hard decisions to make here - a backlog of trains and a limited line.
Net result ... 2M81 ran only just ahead of the path of 2M13, probably took much of its traffic, and delayed 2M13 as well. Two trains at Melksham, 14 minutes apart, to Swindon must be close to a record. Interesting to see it can be done, and perhaps just a gentle warning of how NOT to do it if we end up with competing Go-op trains - they need to be spaced out!
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 08:35, 14th February 2025 | ![]() ![]() ![]() ![]() |
06:35 Salisbury to Worcester Foregate Street due 09:47
06:35 Salisbury to Worcester Foregate Street due 09:47 will be terminated at Swindon.
It will no longer call at Kemble, Stroud, Stonehouse, Gloucester, Cheltenham Spa, Ashchurch For Tewkesbury, Worcester Shrub Hill and Worcester Foregate Street.
This is due to a fault with the signalling system.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 07:43, 12th February 2025 | ![]() ![]() ![]() ![]() |
Yes, it went to Weymouth at 06:50.
Perhaps it always should - with a train starting from Westbury forming the Southampton service a few minutes later. Discussion point but the failure of the train from Swindon (and Trowbridge) to connect onwards to Weymouth is one of life's frustrations ... not on the same scale as war and famine, but still a frustration ...
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by bobm at 07:30, 12th February 2025 | ![]() ![]() ![]() ![]() |
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 06:33, 12th February 2025 | ![]() ![]() ![]() ![]() |
If it can get to Westbury - am I to read it / can I guess that the train is being raided off the Southampton service to go somewhere else instead?
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 18:51, 11th February 2025 | ![]() ![]() ![]() ![]() |
Journey Check reports just 3 cancellations (and no short runs and just one delayed train) across the whole of the GWR network as I write.
and in case you wondered
Train Cancellations
15:45 Bristol Temple Meads to Warminster due 16:43
Restored (hope not too many people have replanned their journey) but now
17:50 Gloucester to Salisbury due 20:06
17:50 Gloucester to Salisbury due 20:06 will be delayed at Stroud.
Edit to add ... 7 minute delay, mostly made up by a quick reversal at Swindon
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 11:18, 11th February 2025 | ![]() ![]() ![]() ![]() |
Train Cancellations
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 15:13, 10th February 2025 | ![]() ![]() ![]() ![]() |
14:18 Westbury to Swindon due 15:00
15:15 Swindon to Westbury due 15:59
Toilet facilities are reduced.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 09:43, 10th February 2025 | ![]() ![]() ![]() ![]() |
Facilities on the 06:35 Salisbury to Worcester Foregate Street due 09:47.
Sensible. On schooldays should always be 3 carriages - otherwise it overloads in the Stroud Valley. During covid was the "most overcrowded train" on GWR ...
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 08:38, 9th February 2025 | ![]() ![]() ![]() ![]() |
08:06 Warminster to Swindon due 08:58 will be started from Westbury.
It will no longer call at Warminster and Dilton Marsh.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 06:16, 7th February 2025 | ![]() ![]() ![]() ![]() |
Good - makes sense
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 06:02, 7th February 2025 | ![]() ![]() ![]() ![]() |
Facilities on the 05:11 Gloucester to Southampton Central due 08:09.
Will be formed of 2 coaches instead of 3.
Not a problem of the early part of the route though it may get cosy into Southampton. At least it's running now - giving s Southampton arrival at ten past 8 rather that ten past 10 as it was a month ago.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by ChrisB at 19:49, 5th February 2025 | ![]() ![]() ![]() ![]() |
A*week* between entries? Strewth!!
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 19:41, 5th February 2025 | ![]() ![]() ![]() ![]() |
17:50 Gloucester to Salisbury due 20:06 will be terminated at Westbury.
It will no longer call at Dilton Marsh, Warminster and Salisbury.
This is due to a late running train being in front of this one.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 22:07, 28th January 2025 | ![]() ![]() ![]() ![]() |
20:06 Westbury to Cheltenham Spa due 22:05
20:06 Westbury to Cheltenham Spa due 22:05 is being delayed between Stonehouse and Gloucester.
This is due to the police dealing with an incident.
Appreciate there have been fewer trains so far this year, but by this stage of 2024 we were on page six of the disruptions topic.
Indeed. With the engineering hand we were dealt this year, thiough, a comparison to previous years can only be a distant one.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by bobm at 17:16, 27th January 2025 | ![]() ![]() ![]() ![]() |
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by matth1j at 14:37, 27th January 2025 | ![]() ![]() ![]() ![]() |
Celebration! The trains are back and running again.
Woohoo - my 07:21 Melksham-Chippenham this morning was on time, and I was able to catch the 07:34 Weston service at Chippenham without 'sprinting' (I use the term loosely) across the platform. All those upgrades have worked
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 12:57, 27th January 2025 | ![]() ![]() ![]() ![]() |
12:17 Westbury to Swindon due 12:59
13:14 Swindon to Westbury due 13:57
13:14 Swindon to Westbury due 13:57 will be cancelled.
This is due to train crew being delayed by service disruption.
Those are the "clever" services which are crewed by staff coming off the 10:35 London to Exeter at Westbury which has been cancelled due to flooding ... not sure flooding where ... and our fair weather railway fails again!
Ah - it must be this
Cancellations to services between Reading and Taunton
Due to heavy rain flooding the railway earlier today between Reading and Taunton fewer trains are able to run on the line towards Reading.
Train services running through these stations will be cancelled or delayed. Disruption is expected until 13:00 27/01.
And they are economic with the truth there - disruption is expected until 13:57 and not just until 13:00 ...
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 12:36, 27th January 2025 | ![]() ![]() ![]() ![]() |
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 13:28, 26th January 2025 | ![]() ![]() ![]() ![]() |
14:22 Frome to Swindon due 15:33
14:22 Frome to Swindon due 15:33 will be started from Westbury.
It will no longer call at Frome.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 06:34, 26th January 2025 | ![]() ![]() ![]() ![]() |
Facilities on the 08:06 Warminster to Swindon due 08:58.
Celebration! The triains are back and running again. Lots of 2 <-> 3 carriage swiches today and in this queter season that won't make a huge difference (2 carriages on "The Weymouth" in the summer WOULD)
Running time 52 minutes, Warminster to Swindon. What a wonderful contrast to the last month. Buses have performed well, but the journey has taken twice as long.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by bobm at 18:22, 23rd January 2025 | ![]() ![]() ![]() ![]() |
During the Westbury closure the 17:35 from Swindon has been operated with the unit which worked the morning service from Trowbridge. The unit has spent the day idle in Platform 2 at Swindon.
Whatever the fault with it was, it left Swindon at 17:00 today to head to St Philips Marsh depot in Bristol.
As far as I am aware it is the only train, or bus replacement, not to operate for passengers over the duration of the works.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by grahame at 18:11, 23rd January 2025 | ![]() ![]() ![]() ![]() |
Oh dear ...
17:35 Swindon to Weymouth due 19:57
17:35 Swindon to Weymouth due 19:57 will be started from Trowbridge.
It will no longer call at Swindon, Chippenham and Melksham.
It will be delayed at Trowbridge and is expected to be 20 minutes late.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury Posted by bobm at 10:53, 5th January 2025 | ![]() ![]() ![]() ![]() |
Slightly confusing message in that there were no *train* services planned through Melksham today in any event due to the engineering work.
2025 - Service update and amendment log, Swindon <-> Westbury Posted by TaplowGreen at 22:42, 4th January 2025 | ![]() ![]() ![]() ![]() |
Cancellations to services between Trowbridge and Chippenham via Melksham
Due to heavy snow at Westbury disruption is expected until the end of the day.
Train services between Trowbridge and Chippenham via Melksham will be cancelled.
Due to engineering works in the Westbury area, rail services are already disrupted.
Rail replacement road transport was in operation, however due to the snow, some coach operators are standing down and therefore the advertised rail replacement road services may not run.
