| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 17:16, 3rd November 2025  |   ![]() ![]() ![]()  |
1W01 09:52 Paddington to Hereford : started from Reading
1W02 1152 London Paddington to Hereford : arrived Great Malvern + 18 and cancelled thereafter.
15:18 Hereford to London Paddington due 18:29 will be started from Great Malvern.
Last Updated:03/11/2025 14:21
| Re: North Cotswold line delays and cancellations - 2025 Posted by Richard Fairhurst at 12:09, 3rd November 2025  |   ![]() ![]() ![]()  |
05:23 Hereford to London Paddington due 08:24 will be started from Worcester Shrub Hill.
This is due to engineering works not being finished on time.
Last Updated:03/11/2025 05:37
This train is formed from a set that is running empty from Stoke Gifford.This is due to engineering works not being finished on time.
It passed Abbotswood Junction + 122 and will probably be about 20 late departing Shrub Hill.
53 minutes late by Charlbury. The IET that usually follows it was a "planned cancellation" this morning, and the Oxfordshire Halts train after that was 17 late. In other words, Cotswold Line in the autumn, SNAFU...
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 06:23, 3rd November 2025  |   ![]() ![]() ![]()  |
Monday November 3
05:16 Worcester Shrub Hill to London Paddington due 07:24 will be started from Evesham.
It will no longer call at Worcester Shrub Hill, Worcestershire Parkway Hl, Pershore and Maidenhead.
It is being delayed at Evesham.
Last Updated:03/11/2025 06:09
This train is formed of the stock from last night's 21:50 Paddington - Evesham, which spent the night at Evesham and should have run empty to Shrub Hill at 04:20.It will no longer call at Worcester Shrub Hill, Worcestershire Parkway Hl, Pershore and Maidenhead.
It has departed from Evesham +33.
The stock for 1P18 0713 Great Malvern to London Paddington, also empty from Stoke Gifford, has passed Ashchurch +36 and is on a 12 minute turn-round at Great Malvern.
Later:
07:13 Great Malvern to London Paddington due 09:42 will be diverted between Worcester Shrub Hill and Reading and terminated at Reading.
It will no longer call at Worcestershire Parkway Hl, Pershore, Evesham, Honeybourne, Moreton-In-Marsh, Kingham, Charlbury, Hanborough, Oxford and London Paddington.
It is being delayed at Great Malvern.
Last Updated:03/11/2025 07:46
Departed Great Malvern +41.It will no longer call at Worcestershire Parkway Hl, Pershore, Evesham, Honeybourne, Moreton-In-Marsh, Kingham, Charlbury, Hanborough, Oxford and London Paddington.
| Re: North Cotswold line delays and cancellations - 2025 Posted by TonyN at 17:45, 31st October 2025  |   ![]() ![]() ![]()  |
This is due to more trains than usual needing repairs at the same time
May be due to the wrong sort of leaves blocking the engine air intakes.
Attached picture taken yesterday afternoon at Cheltenham.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 10:35, 31st October 2025  |   ![]() ![]() ![]()  |
Friday October 31
Two early warnings of evening short workings have now disappeared from JourneyCheck. But have been replaced by
19:53 London Paddington to Hereford due 22:57 will be cancelled.
Last Updated:31/10/2025 10:12
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 15:55, 30th October 2025  |   ![]() ![]() ![]()  |
1W02 11:52 London Paddington to Hereford (14:44) : +7 at Oxford, +17 at Shrub Hill, arrived Ledbury +19 and cancelled thereafter.
15:18 Hereford to London Paddington due 18:29 will be started from Ledbury.
This is due to a late running train being in front of this one.
Last Updated:30/10/2025 14:43
16:30 update:
17:04 Didcot Parkway to Evesham due 18:23 will be cancelled.
Last Updated:30/10/2025 16:05
18:51 Evesham to Oxford due 19:50 will be cancelled.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 07:32, 30th October 2025  |   ![]() ![]() ![]()  |
Thursday October 30
Presumably this is indicative of engine failures:
05:16 Worcester Shrub Hill to London Paddington due 07:24 will no longer call at Honeybourne.
Last Updated:30/10/2025 01:54
RTT reports it as being a 9-car set, 800 321.This is due to a fault on this train.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 18:03, 29th October 2025  |   ![]() ![]() ![]()  |
20.04 on Sunday from Paddington to Hereford started 22 late and ended 55 late. Fortunately the Royal Blenheim in Oxford is a very convivial waiting room.
A couple of sets running (if "running" is the word) around yesterday with engines out which didn't help.
This seems to be an issue again today. I thought that IETs had sufficient redundancy to be able to keep to time with engines out - is this correct?
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 08:42, 29th October 2025  |   ![]() ![]() ![]()  |
Wednesday October 29
 Alterations to services between Oxford and Worcester Shrub Hill
Due to a points failure between Oxford and Worcester Shrub Hill trains have to run at reduced speed on the line towards Worcester Shrub Hill.
Train services running through these stations may be delayed or revised. Disruption is expected until 10:00 29/10.
Last Updated:29/10/2025 08:14
05:53 London Paddington to Great Malvern due 08:38 will be terminated at Oxford.
Last Updated:29/10/2025 07:10
08:56 Great Malvern to London Paddington due 11:27 will be started from Oxford.
Last Updated:29/10/2025 07:14
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 18:03, 28th October 2025  |   ![]() ![]() ![]()  |
Last Updated:28/10/2025 14:35
15:23 London Paddington to Worcester Foregate Street due 17:47 will be terminated at Worcester Shrub Hill.
It has been delayed at London Paddington and is now 16 minutes late.
Last Updated:28/10/2025 17:49
Departed +16, arrived Evesham +18, held there (+33).It has been delayed at London Paddington and is now 16 minutes late.
18:02 Worcester Foregate Street to London Paddington due 20:29 will be started from Worcester Shrub Hill.
- and may well be late.This is due to a late running train being in front of this one.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 15:14, 28th October 2025  |   ![]() ![]() ![]()  |
According to RTT, 1W02 1152 Paddington to Hereford, was right time at Oxford, five late off Moreton in Marsh, stood for almost half an hour at Shrub Hill, whence it departed 35 minutes late. It got to Great Malvern 38 minutes late, and progressed no further from there except for the ECS to turn back at Malvern Wells
The poor performance of this service in its daily (non) operation is something to behold
| Re: North Cotswold line delays and cancellations - 2025 Posted by ChrisB at 16:27, 25th October 2025  |   ![]() ![]() ![]()  |
Lasted until about 1100
| Re: North Cotswold line delays and cancellations - 2025 Posted by TaplowGreen at 08:19, 25th October 2025  |   ![]() ![]() ![]()  |
Cancellations to services at Evesham
Due to a fault with the signalling system at Evesham fewer trains are able to run on some lines.
Train services running through this station may be cancelled or delayed. Disruption is expected until 09:00 25/10.
Due to a fault with the signalling system at Evesham some services maybe delayed; altered or cancelled as a result.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 14:23, 21st October 2025  |   ![]() ![]() ![]()  |
10:59 Great Malvern to London Paddington due 13:25 will be cancelled.
Last Updated:21/10/2025 10:21
The above is formed from 1W15 0750 Paddington to Worcester, which was caped after Foregate Street, where it had arrived 17 minutes late. It was more-or-less on-time until arriving at Shrub Hill
And having expired at Foregate St, it was then in the way of 1P24 09:56 Great Malvern to London Paddington, which had to drum its fingers at Henwick (+25), be held at Norton (+37) and skipped Didcot.
Everything on our line has consequences...
As soon as the singling of lines between Oxford and Hereford was proposed in the early 1970s, the staff on the ground knew what chaos would ensue. But the management just was not interested in listening to anything the LDCs had to say. The cutbacks went ahead. Despite some more recent replacement of double line, the hassles and the delays continue. If you added up the cost of all the delay and inconvenience over 50+ years, I'm quite sure it would far outweigh whatever has been "saved" bu having fewer miles of track to maintain
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 12:37, 21st October 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by Richard Fairhurst at 12:19, 21st October 2025  |   ![]() ![]() ![]()  |
I think that this is the 18:45 from Paddington.You're quite right. I tend to view the world in terms of departure times from Charlbury
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 10:42, 21st October 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 11:43, 20th October 2025  |   ![]() ![]() ![]()  |
I think that this is the 18:45 from Paddington.| Re: North Cotswold line delays and cancellations - 2025 Posted by Richard Fairhurst at 08:10, 20th October 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 17:45, 19th October 2025  |   ![]() ![]() ![]()  |
But now
14:28 Hereford to London Paddington due 17:24 has been cancelled.
Last Updated:19/10/2025 16:50
16:58 Great Malvern to London Paddington due 19:24 will be started from Worcester Shrub Hill.
This is due to a passenger being taken ill on this train.
Last Updated:19/10/2025 16:08
14:45 London Paddington to Great Malvern due 17:15 was terminated at Didcot Parkway.
Last Updated:19/10/2025 15:58
And
1W39 13:45 London Paddington to Great Malvern (16:16) : departed +19, held Oxford (+32), arrived Worcester Shrub Hill +43 and cancelled thereafter.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 10:08, 19th October 2025  |   ![]() ![]() ![]()  |
Sunday October 19
09:58 Great Malvern to London Paddington due 12:24 will be cancelled.
Last Updated:19/10/2025 07:57
Stock running from Shrub Hill to Paddington ECS.This is due to a shortage of train crew.
Added 13:45:
14:28 Hereford to London Paddington due 17:24 will be started from Oxford.
Last Updated:19/10/2025 10:39
Added 13:45:
12:45 London Paddington to Hereford due 16:04 will be started from Reading.
Last Updated:19/10/2025 11:15
14:45 London Paddington to Great Malvern due 17:15 will be terminated at Worcester Shrub Hill.
Last Updated:19/10/2025 00:12
The 14:45 is an odd working - it doesn't turn round at Great Malvern. Instead, it runs ECS back to Stoke Gifford (17:30-19:54).This is due to a shortage of train crew.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 06:14, 18th October 2025  |   ![]() ![]() ![]()  |
Saturday October 18
18/10/25 06:18 Hereford to London Paddington due 09:23 will be cancelled.
This is due to the emergency services dealing with an incident earlier today.
Last Updated:17/10/2025 21:04
07:43 Great Malvern to London Paddington due 10:27 will be cancelled.
Last Updated:18/10/2025 01:07
1P25 1431 Foregate St to London Paddington : started from Oxford.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 17:24, 17th October 2025  |   ![]() ![]() ![]()  |
Sparing a thought, many thoughts indeed, for all involved in what appears to be another sad and bad situation
Indeed so.
16:32 Great Malvern to London Paddington due 19:29 will be cancelled.
This is due to the emergency services dealing with an incident near the railway earlier today.
Last Updated:17/10/2025 16:31
18:02 Worcester Foregate Street to London Paddington due 20:29 will be cancelled.
Last Updated:17/10/2025 16:52
14:53 London Paddington to Worcester Foregate Street due 17:04 has been delayed between London Paddington and Oxford and is now 29 minutes late.
Last Updated:17/10/2025 16:34
15:52 London Paddington to Great Malvern due 18:26 has been delayed at London Paddington and is now 40 minutes late.
Last Updated:17/10/2025 16:36
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 15:56, 17th October 2025  |   ![]() ![]() ![]()  |
13:50 London Paddington to Great Malvern due 16:15 has been cancelled.
This is due to the emergency services dealing with an incident.
Last Updated:17/10/2025 14:52
15:18 Worcester Foregate Street to London Paddington due 17:29 will be cancelled.
Last Updated:17/10/2025 14:59
15:23 London Paddington to Worcester Foregate Street due 17:47 has been cancelled.
Last Updated:17/10/2025 15:44
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 13:43, 17th October 2025  |   ![]() ![]() ![]()  |
Following the emergency services dealing with an incident between London Paddington and Reading all lines have now reopened.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 15:00 17/10.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 13:09, 17th October 2025  |   ![]() ![]() ![]()  |
We've now got
Due to the emergency services dealing with an incident between London Paddington and Reading all lines are closed.
Last Updated:17/10/2025 12:58
with several Paddington departures flagged up on JourneyCheck as "may be starting late".Due to the emergency services dealing with an incident between London Paddington and Reading all lines are closed.
Meanwhile, in other changes
10:59 Great Malvern to London Paddington due 13:25 was started from Worcester Foregate Street and will be terminated at Oxford.
This is due to train crew being delayed.
Last Updated:17/10/2025 12:22
19:53 London Paddington to Hereford due 22:57 will be terminated at Worcester Shrub Hill.
Last Updated:17/10/2025 11:31
| Re: North Cotswold line delays and cancellations - 2025 Posted by charles_uk at 11:38, 17th October 2025  |   ![]() ![]() ![]()  |
It's not a good day today... not that the week as a whole has been brilliant
10:53 London Paddington to Worcester Shrub Hill due 13:01 will be terminated at Oxford.
It will no longer call at Hanborough, Charlbury, Kingham, Moreton-In-Marsh, Honeybourne, Evesham, Pershore, Worcestershire Parkway Hl and Worcester Shrub Hill.
13:16 Worcester Shrub Hill to London Paddington due 15:22 will be started from Oxford.
It will no longer call at Worcester Shrub Hill, Worcestershire Parkway Hl, Pershore, Evesham, Honeybourne, Moreton-In-Marsh, Kingham, Charlbury and Hanborough.
Last Updated:17/10/2025 11:23
The down service was well beyond Reading before this appeared on JourneyCheck!
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 11:10, 17th October 2025  |   ![]() ![]() ![]()  |
1W15 07:50 London Paddington to Great Malvern (10:14) : held Oxford (+25), Wolvercote (+39) and Shrub Hill (+55), arrived Foregate St +56 and cancelled thereafter.
10:59 Great Malvern to London Paddington due 13:25 will be started from Worcester Foregate Street.
Last Updated:17/10/2025 09:47
| Re: North Cotswold line delays and cancellations - 2025 Posted by grahame at 10:24, 17th October 2025  |   ![]() ![]() ![]()  |
The kind offer about using the two services before/after this one isn't very useful if you're in Hereford, Ledbury or Colwall.
Going off topic (sorry!) I felt the same about the cancellation of the direct train from Trowbridge to London this morning ... the two services before had left before the cancellation was announced and the next two services are on Monday 20th and Tuesday 21st October. I am writing on 17th, by the way.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Richard Fairhurst at 08:54, 17th October 2025  |   ![]() ![]() ![]()  |
However, the 19:53 Paddington to Hereford service is now being terminated at Oxford due to a shortage of train crew so, presumably, that will take out tomorrow's 05:23 Hereford to Paddington service for the third day this week.
Apparently terminating short was due to a driver being assaulted.
The subsequent train (2052 from Paddington) was five carriages vs the usual nine, and very cosy - standing room only at least as far as Charlbury.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 08:41, 17th October 2025  |   ![]() ![]() ![]()  |
Friday October 17
More encouraging now: nothing about the 22:51 being terminated at Oxford on Journeycheck now and whilst Journeycheck is still showing the 21.53 as a short-form, RealtimeTrains and https://tiger.worldline.global/ are both showing this as a nine car train.
23:00 update - cancellation of tomorrow's 05:23 confirmed:
17/10/25 05:23 Hereford to London Paddington due 08:24 will be cancelled.
Last Updated:16/10/2025 22:32
The 05:23 ran, but only from Oxford:
05:23 Hereford to London Paddington due 08:24 has been reinstated.
It will be started from Oxford.
Will be formed of 5 coaches instead of 9.
Additional Facilities Information
Alternatively, you can travel on either of the two GWR services that are immediately before or after this one. Your ticket will be valid for travel on these GWR services at no additional cost. You can see how many coaches our services have with the 'Live Times' feature on the GWR app, or speak to staff for further information.
Last Updated:17/10/2025 06:00
The kind offer about using the two services before/after this one isn't very useful if you're in Hereford, Ledbury or Colwall.It will be started from Oxford.
Meanwhile
06:52 London Paddington to Great Malvern due 09:29 will be terminated at Oxford.
Last Updated:17/10/2025 06:55
09:56 Great Malvern to London Paddington due 12:23 will be started from Oxford.
Last Updated:17/10/2025 06:56
But we are being told where one of those naughty 9-car sets has disappeared to:
Facilities on the 05:53 London Paddington to Great Malvern due 08:38.
Will be formed of 9 coaches instead of 5.
Facilities on the 08:56 Great Malvern to London Paddington due 11:27.
Facilities on the 15:23 London Paddington to Worcester Foregate Street due 17:47.
Facilities on the 18:02 Worcester Foregate Street to London Paddington due 20:29.
Facilities on the 20:52 London Paddington to Great Malvern due 23:13.
Though that's not much help for
Facilities on the 17:34 London Paddington to Hereford due 20:25.
Facilities on the 18:57 London Paddington to Great Malvern due 21:18.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 08:33, 17th October 2025  |   ![]() ![]() ![]()  |
In the end, both the 21:53 and the 22:51 ran as 9-car sets:
1P42 19:02 Great Malvern to London Paddington (21:26) : held Norton (+11) and Oxford (+28), arrived +26.
1P44 19:45 Great Malvern to London Paddington (22:24) : departed +16, saved 8 at Charlbury (
, delayed after Slough, arrived +37.1P46 20:56 Worcester Foregate Street to London Paddington (23:29) : arrived +15.
1P06 22:00 Hereford to London Paddington (01:17) : arrived +21.
1W33 16:58 London Paddington to Great Malvern (19:25) : delayed throughout, arrived +16.
1W03 17:34 London Paddington to Hereford (20:25) : delayed throughout, arrived +13.
1W34 17:57 London Paddington to Worcester Foregate Street (20:11) : arrived +15.
1W05 19:53 London Paddington to Hereford (22:57) : cancelled after Oxford. 5 cars.
1W43 21:53 London Paddington to Worcester Shrub Hill (00:01) : 9 cars.
1W45 22:51 London Paddington to Worcestershire Parkway (01:06) : 9 cars.
| Re: North Cotswold line delays and cancellations - 2025 Posted by charles_uk at 20:07, 16th October 2025  |   ![]() ![]() ![]()  |
Thursday October 16
Stock allocation is an issue this week, with this evening's departures not looking good:
The 5-car sets on the 19:53 and 21:53 do not bode well for Friday.
Nor does
Facilities on the 21:53 London Paddington to Worcester Shrub Hill due 00:01.
Last Updated:16/10/2025 04:00
Nor does
22:51 London Paddington to Worcestershire Parkway Hl due 01:06 will be terminated at Oxford.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 08:05, 16th October 2025  |   ![]() ![]() ![]()  |
Thursday October 16
Facilities on the 06:43 Worcester Shrub Hill to London Paddington due 08:44.
Facilities on the 19:53 London Paddington to Hereford due 22:57.
Nor does
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 22:16, 15th October 2025  |   ![]() ![]() ![]()  |
18:57 London Paddington to Great Malvern due 21:18 will be terminated at Worcester Shrub Hill.
It has been delayed previously and is expected to be 57 minutes late from Oxford.
This is due to trespassers on the railway.
Last Updated:15/10/2025 20:41
Delayed at Hayes & Harlington (+34), +54 by Reading, arrived Shrub Hill +59 and cancelled therafter.It has been delayed previously and is expected to be 57 minutes late from Oxford.
19:53 London Paddington to Hereford due 22:57 has been delayed at London Paddington and is now 24 minutes late.
Last Updated:15/10/2025 20:19
Departed +24, further delayed before Reading (+44), arrived Shrub Hill +35, saved 14 at Great Malvern (+21), only to be held at Ledbury (+34), arrived +32.This is due to trespassers on the railway.
1W41 20:52 London Paddington to Great Malvern (23:13) : departed +12, held Wolvercote (+28?) and at Norton (+47), arrived +57.
1W43 21:53 London Paddington to Worcester Shrub Hill (00:01) : held Reading (+24), arrived +20. 5-car set.
19:45 Great Malvern to London Paddington due 22:24 is being delayed at Oxford.
This is due to trespassers on the railway earlier today.
Last Updated:15/10/2025 21:51
22:10 : cancelled after Oxford "due to a problem with the traction equipment (MD)" according to RTT.This is due to trespassers on the railway earlier today.
Thu Oct 16 08:00 : final scores added.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 10:29, 15th October 2025  |   ![]() ![]() ![]()  |
As flagged yesterday, the 06:43 Worcester Shrub Hill to Paddington service was a five car short-form, as was the first up service of the day, the 05:16 Worcester Shrub Hill to Paddington train.
But the 05:23 from Hereford did operate (and was a nine-car).
| Re: North Cotswold line delays and cancellations - 2025 Posted by charles_uk at 09:33, 15th October 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by Richard Fairhurst at 11:33, 14th October 2025  |   ![]() ![]() ![]()  |
The 15:23 arrived Reading +33, was cancelled thereafter, and is now (17:00) running ECS to Shrub Hill (due 18:27).
That ECS was a pretty speedy run via Stroud, arriving at Shrub Hill just after 1800 just in time to start the London-bound journey. I was planning on getting the 1841 from Charlbury, saw that was cancelled, and decided to run for the 1807 rather than assuming the 1909 would turn up on time after its South Cotswolds perambulations.
The (North) Cotswold Line service does seem to fall apart in autumn, year in, year out.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 05:37, 14th October 2025  |   ![]() ![]() ![]()  |
19:53 London Paddington to Hereford due 22:57 will be terminated at Oxford.
Last Updated:13/10/2025 20:56
Tuesday October 14
This is due to a broken down train.
Last Updated:14/10/2025 02:00
And in bad news for tomorrow morning:
Last Updated:14/10/2025 06:00
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 21:52, 13th October 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 17:02, 13th October 2025  |   ![]() ![]() ![]()  |
And following the cancellation of the 14:53 Paddington to Worcester Foregate Street:
15:23 London Paddington to Worcester Foregate Street due 17:47 will be terminated at Reading.
It will no longer call at Didcot Parkway, Oxford, Hanborough, Charlbury, Kingham, Moreton-In-Marsh, Honeybourne, Evesham, Pershore, Worcestershire Parkway Hl, Worcester Shrub Hill and Worcester Foregate Street.
It is being delayed at London Paddington.
Today, the 15:23 is formed of the back half of a ten-car Carmarthen - Paddington journey, due in at 15:12 but today +20.
The 15:23 departed +30, after 1W31 15:52 London Paddington to Great Malvern (18:26).
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 16:36, 13th October 2025  |   ![]() ![]() ![]()  |
Another day, another shambles
| Re: North Cotswold line delays and cancellations - 2025 Posted by charles_uk at 16:27, 13th October 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 15:26, 13th October 2025  |   ![]() ![]() ![]()  |
14:53 London Paddington to Worcester Foregate Street due 17:04 will be cancelled.
Last Updated:13/10/2025 14:05
17:26 Worcester Foregate Street to London Paddington due 19:52 will be cancelled.
If passengers on the Worcester road aren't knocked by staff shortage, it's a broken down train or a signalling failure. One thing after another. Day after day.
Not a service to be relied upon, and I feel sorry for those (my son-in-law included) who have to
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 07:39, 13th October 2025  |   ![]() ![]() ![]()  |
Monday October 13
Later:
Last Updated:13/10/2025 02:00
Additional 05:23 Hereford to London Paddington due 08:24 will be diverted between Worcester Shrub Hill and Reading.
Left on time, but +15 by Shrub Hill, arrived +21.This is due to a broken down train.
13:30 : Conflicting information on train length from JourneyCheck and RTT.
JourneyCheck has
Facilities on the 12:52 London Paddington to Worcester Foregate Street due 15:00.
Facilities on the 15:18 Worcester Foregate Street to London Paddington due 17:29.
Facilities on the 17:57 London Paddington to Worcester Foregate Street due 20:11.
Facilities on the 20:56 Worcester Foregate Street to London Paddington due 23:40.
Last Updated:13/10/2025 04:00
Meanwhile, RTT has all four journeys being operated by 18-car trains.
14:45:
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 23:12, 12th October 2025  |   ![]() ![]() ![]()  |
Sunday October 12
...was going well until
1W08 18:45 London Paddington to Hereford (21:54) : departed +24, held Evesham (+51), delayed Pershore (+64), arrived +63.
But the consequences are ambiguous:
13/10/25 05:23 Hereford to London Paddington due 08:24 will be cancelled.
Last Updated:12/10/2025 22:35
Mon, 13 October 05:23 Hereford to London Paddington due 08:24
An additional train service has been planned to operate as shown 13/10/25 05:23 Hereford to London Paddington due 08:24.
Last Updated:12/10/2025 23:02
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 14:03, 11th October 2025  |   ![]() ![]() ![]()  |
Saturday October 11
1W01 0950 London Paddington to Hereford (12:43) : held Oxford (+21) and Ledbury (+42), arrived +41.
13:20 Hereford to London Paddington due 16:22 will be starting late from Hereford.
Last Updated:11/10/2025 12:57
Departed +22, arrived +12.This is due to a fault on this train.
In the late afternoon, there was a trespass incident between Didcot and Oxford:
1P33 17:00 Great Malvern to London Paddington (19:24) : cancelled after Oxford
1P35 17:48 Great Malvern to London Paddington (20:23) : delayed after Oxford, arrived +35.
1W35 17:52 London Paddington to Worcester Foregate St (20:10) : held Didcot North Jn (+55), arrived Shrub Hill +64 and cancelled thereafter.
1W37 18:52 London Paddington to Great Malvern (21:13) : operated via Stroud.
1W39 19:52 London Paddington to Great Malvern (22:23) : started from Oxford (+19), arrived +21.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 12:48, 10th October 2025  |   ![]() ![]() ![]()  |
15:52 London Paddington to Great Malvern due 18:26 will be terminated at Worcester Shrub Hill.
Last Updated:10/10/2025 12:03
1W33 16:58 London Paddington to Great Malvern : delayed before Oxford (+13), held Shrub Hill (+29), arrived +26.
17:57 London Paddington to Worcester Foregate Street due 20:11 will be cancelled.
Last Updated:10/10/2025 14:05
1W45 22:51 London Paddington to Worcestershire Parkway (01:06) : cancelled, as described above
Stock ran ECS from Paddington to Shrub Hill.
19:02 Great Malvern to London Paddington due 21:26 will be cancelled.
Stock ran ECS from Shrub Hill to Paddington.This is due to a shortage of train crew.
20:56 Worcester Foregate Street to London Paddington due 23:29 will be cancelled.
Last Updated:10/10/2025 14:06
21:30 : updated
Saturday Oct 11 : note added about 1W45 ECS journey.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 10:27, 10th October 2025  |   ![]() ![]() ![]()  |
22:51 London Paddington to Worcestershire Parkway Hl due 01:06 will be cancelled.
We're sorry for the disruption to your journey.
A coach (Brooks Coach Hire) has been arranged leaving Oxford at 00:55 calling at Hanborough (01:08), Charlbury (01:26), Kingham (01:45), Moreton-in-Marsh (02:02), Honeybourne (02:31), Evesham (02:52), Pershore (03:08) and Worcestershire Parkway (03:09 arrival).
If you're travelling from London Paddington or Reading, please join the 23:14 from London Paddington to Oxford calling at Reading at 00:07 then change for the bus at Oxford.
Road transport pick up/drop off points can be found on the Information poster at stations or online at nre.co.uk/stations.
Last Updated:10/10/2025 10:16
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 14:34, 9th October 2025  |   ![]() ![]() ![]()  |
Something broke down in Worcester at a critical moment this morning, with serious knock-on effects over the single track from Shrub Hill through Foregate St to Henwick.
WMT's 11:40 Foregate Street to Stratford : started from Shrub Hill (P1 11:47) +18 "due to a problem with the traction equipment (MD)".
GWR's 10:53 Foregate St to Bristol Temple Meads : departed +20, departed Shrub Hill +51, arrived Bristol Parkway +54 and cancelled thereafter.
1P26 10:59 Great Malvern to London Paddington (13:25) : due Foregate St 11:11-11:12, held Henwick (+22), Foregate St (+39), arrived Reading +53 and cancelled thereafter.
11:58 Great Malvern to London Paddington due 14:23 will be started from Worcester Shrub Hill.
It will no longer call at Great Malvern, Malvern Link and Worcester Foregate Street.
Reservations for Coach D in Coach K.
Last Updated:09/10/2025 11:48
1W17 08:52 London Paddington to Great Malvern (11:14) : due Foregate St 11:02-11:03, cancelled after Worcester Shrub Hill.
1W01 09:52 London Paddington to Hereford (12:46) : held Shrub Hill (+14), arrived +21.
13:50 London Paddington to Great Malvern due 16:15 will be started from Reading.
It will no longer call at London Paddington.
Last Updated:09/10/2025 11:59
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 06:57, 9th October 2025  |   ![]() ![]() ![]()  |
Thursday October 9
A nice complementary pair this morning:
Facilities on the 08:18 Worcester Shrub Hill to London Paddington due 10:25.
Last Updated:09/10/2025 04:03
Facilities on the 08:52 London Paddington to Great Malvern due 11:14.
Last Updated:09/10/2025 04:04
... which means the excuse about "trains needing repair" is rather silly.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 04:52, 8th October 2025  |   ![]() ![]() ![]()  |
21:53 London Paddington to Worcester Shrub Hill due 00:01 will be cancelled.
so, presumably tomorrow's 06:43 Worcester Shrub Hill to Paddington service will also be a cancellation.
And Tuesday's 1W05 19:53 London Paddington to Hereford was short-formed with a five-car set, leading to
Facilities on the 05:23 Hereford to London Paddington due 08:24.
Last Updated:08/10/2025 03:58
05:50 : The 06:43 will be operated by the (nine-car) set from last night's 1W36 18:57 London Paddington to Great Malvern (21:18). This set normally runs back to Stoke Gifford, but couldn't get there on Tuesday night on account of the oiver-running Gloucester engineering work, so it spent the night at Shrub Hill.
| Re: North Cotswold line delays and cancellations - 2025 Posted by grahame at 03:52, 8th October 2025  |   ![]() ![]() ![]()  |
On Realtime Trains it says
This service is cancelled.
This service was cancelled due to the planned train being replaced with a slower train (MS).
https://www.realtimetrains.co.uk/service/gb-nr:P08654/2025-10-07/detailed
That’s not an excuse/reason I’ve seen used before.
https://wiki.openraildata.com/index.php/Darwin:Cancellation_reason_codes_and_text
https://wiki.openraildata.com/index.php/Delay_Attribution_Guide
MS officially reads
"Planned underpowered or shortformed service and or vehicle, incl. exam set swaps"
and I suspect that the descriptions are recoded out of rail jargon by real time trains
| Re: North Cotswold line delays and cancellations - 2025 Posted by 1st fan at 00:06, 8th October 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by charles_uk at 20:40, 7th October 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by Richard Fairhurst at 17:02, 6th October 2025  |   ![]() ![]() ![]()  |
Yes, Mrs F (who was hoping to use at least one of those trains to get to work) was a bit less tactful at 6.45 this morning…
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 10:41, 6th October 2025  |   ![]() ![]() ![]()  |
0523 from Hereford, 0643 from Shrub Hill and 0700 from Shrub Hill all cancelled this morning. Not good.
Tactful understatement.| Re: North Cotswold line delays and cancellations - 2025 Posted by Richard Fairhurst at 07:20, 6th October 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by ChrisB at 21:35, 5th October 2025  |   ![]() ![]() ![]()  |
Overcrowding, as its short-formed?
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 21:34, 5th October 2025  |   ![]() ![]() ![]()  |
20:47 London Paddington to Worcester Shrub Hill due 23:04 is being delayed at London Paddington.
This is due to a problem currently under investigation.
Last Updated:05/10/2025 20:56
| Re: North Cotswold line delays and cancellations - 2025 Posted by charles_uk at 21:16, 5th October 2025  |   ![]() ![]() ![]()  |
06/10/25 05:23 Hereford to London Paddington due 08:24 will be cancelled.
This is due to a fault with the signalling system.
I notice that tonight's 2047 Paddington to Worcester Shrub Hill is an unadvertised 5 car short-form (800023). This seems to be the stock which forms Monday's 0643 Worcester Shrub Hill to Paddington service. This is normally pretty snug well before Oxford when it's a short-form. Given the cancellation of the previous service, things could be very cosy!
However JourneyCheck is now reporting:
20:47 London Paddington to Worcester Shrub Hill due 23:04 has been cancelled.
so what impact that'll have on tomorrow's service remains to be seen.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Trowres at 20:53, 5th October 2025  |   ![]() ![]() ![]()  |
Fault with the signalling system?
RTT suggests that the reason is "signalbox not open". Would that be Ledbury?
There's a noticeable lack of alternative options given on Journeycheck. I had a look to see what was happening to Hereford to Birmingham services.
Interestingly, the 21:00 Hereford-Birmingham has been removed from the WTT for 5th October and replaced by a Great-Malvern to Birmingham service. [Source: RTT]
National Rail Journey Planner lists the 21:00 Hereford-Birmingham as cancelled and fails to provide any alternative journey options when asked.
However, the TIGER display for Hereford, as a footnote to the 21:00 Cancelled line, shows a 21:10 bus to Great Malvern. No arrival time at GMV so can't tell if it connects with anything.
So, at a guess:
a) a signalbox - Malvern Wells?, without a signalman
b) Services from Hereford being removed from the TT for 5th October suggests the line was not meant to be open, for some reason.
c) Not all changes required were correctly applied.
The electronic information provided falls short (as it often does).
Anybody able to offer an explanation for what happened that doesn't require guesswork?
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 15:30, 5th October 2025  |   ![]() ![]() ![]()  |
13:58 Great Malvern to London Paddington due 16:36 is being delayed at Worcester Shrub Hill.
This is due to train crew being delayed by service disruption.
Last Updated:05/10/2025 14:19
20:46 Great Malvern to London Paddington due 23:40 will be started from Worcester Foregate Street.
Last Updated:05/10/2025 08:14
| Re: North Cotswold line delays and cancellations - 2025 Posted by charles_uk at 14:50, 5th October 2025  |   ![]() ![]() ![]()  |
17:47 London Paddington to Great Malvern due 20:15 will be terminated at Worcester Foregate Street.
It will no longer call at Malvern Link and Great Malvern.
18:47 London Paddington to Hereford due 21:54 will be cancelled.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 16:49, 3rd October 2025  |   ![]() ![]() ![]()  |
Now the return working of 1W02, which is 1P05 1518 off Hereford to Padd, is 19 mins late over Norton Jcn, having left Hereford 12 mins late
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 16:16, 3rd October 2025  |   ![]() ![]() ![]()  |
1W02 11:52 Paddington to Hereford is heading to Hereford today, as I type this.  It's not been turned-back short
On time leaving Oxford. Almost quarter of an hour late at Worcester Shrub Hill, and it's going to be best part of half an hour late by the time it gets to Hereford
Not unusual for it to be cancelled for some of the westernmost part of this journey. When it's not cancelled or part-cancelled, the likelihood is that it's going to be late at Hereford
Arrived Hereford +25.On time leaving Oxford. Almost quarter of an hour late at Worcester Shrub Hill, and it's going to be best part of half an hour late by the time it gets to Hereford
1W25 12:52 London Paddington to Foregate St (15:00) : held Reading (+28). Honeybourne +31. Arrived Evesham +56, Shrub Hill +58 and cancelled thereafter "due to an issue with the train crew (TG)" according to RTT.
13:50 London Paddington to Great Malvern due 16:15 will be terminated at Worcester Shrub Hill.
It will no longer call at Reading, Worcester Foregate Street, Malvern Link and Great Malvern.
It has been delayed at London Paddington and is now 25 minutes late.
Last Updated:03/10/2025 14:40
RTT reports a stop at Reading.It will no longer call at Reading, Worcester Foregate Street, Malvern Link and Great Malvern.
15:18 Worcester Foregate Street to London Paddington due 17:29 will be started from Worcester Shrub Hill.
Last Updated:03/10/2025 13:31
Departed Shrub Hill +47.This is due to train crew being delayed.
16:32 Great Malvern to London Paddington due 19:29 will be started from Worcester Shrub Hill.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 14:56, 3rd October 2025  |   ![]() ![]() ![]()  |
1W02 1152 Paddington to Hereford is heading to Hereford today, as I type this. It's not been turned-back short
| Re: North Cotswold line delays and cancellations - 2025 Posted by Richard Fairhurst at 23:01, 2nd October 2025  |   ![]() ![]() ![]()  |
"Short run" in both senses, because it was five carriages rather than nine. Looked like it was about to get very cosy at Oxford on its return journey.
(I caught the same train both from Oxford to Charlbury at 1.10pm-ish and then from Charlbury to Oxford at 5.12pm for, well, reasons.)
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 13:59, 2nd October 2025  |   ![]() ![]() ![]()  |
11:52 London Paddington to Hereford due 14:44 will be terminated at Great Malvern.
It will no longer call at Colwall, Ledbury and Hereford.
It is being delayed between Reading and Oxford and is now expected to be 31 minutes late.
Last Updated:02/10/2025 12:52
It will no longer call at Hereford, Ledbury and Colwall.
I reckon this service is probably the most likely to be short run across the entire GW network
Cancelled beyond Great Malvern today. Not by any means a rare event
| Re: North Cotswold line delays and cancellations - 2025 Posted by Mark A at 10:05, 2nd October 2025  |   ![]() ![]() ![]()  |
Missing a single stop counts as a cancellation for the people intending to board or alight there, it has to be said.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 09:56, 2nd October 2025  |   ![]() ![]() ![]()  |
RTT reports !W15 0750 Paddington - Great Malvern is cancelled today. No reason given, but it's honest that most people who wanted to use the train will not be able to do that
Journey Check, however, pretends that the service is still running. Just not running quite as scheduled
07:50 London Paddington to Great Malvern due 10:14 will be started from Worcester Shrub Hill.
It will no longer call at London Paddington, Reading, Oxford, Hanborough, Charlbury, Kingham, Moreton-In-Marsh, Honeybourne, Evesham, Pershore and Worcestershire Parkway Hl.
Last Updated:02/10/2025 04:43
Operating a service over seven miles out of a planned 120 counts as close to a cancellation as makes no difference, in my book
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 15:09, 30th September 2025  |   ![]() ![]() ![]()  |
Swan Disruption
Cancellations to services between Great Malvern and Hereford
Due to a train hitting an obstruction on the line earlier today between Great Malvern and Hereford fewer trains are able to run.
Train services running through these stations may be cancelled. Disruption is expected until 16:00 30/09.
A train was damaged from a swan being on the line, which has called delays to other train services. This in turn means that the train to Hereford is running very late so will be terminated at Great Malvern to enable the return service to run on time back to London Paddington
GWR arranged for the damaged train to be moved to the maintanace depot
Need to be careful with them swans. They'll break your arm, you know
| Re: North Cotswold line delays and cancellations - 2025 Posted by Richard Fairhurst at 13:05, 30th September 2025  |   ![]() ![]() ![]()  |
Mrs F (who was planning to catch that, and ended up on the next service) confirms that it indeed did!
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 12:15, 30th September 2025  |   ![]() ![]() ![]()  |
According to RTT, today's 1P02 0523 Hereford to Paddington:
This service was cancelled due to a problem with the traction equipment (MD).
Must have resulted in the next working being a bit crowded
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 15:56, 26th September 2025  |   ![]() ![]() ![]()  |
Friday September 26
1W21 1053 London Paddington to Worcester Shrub Hill (13:01) : departed +14, arrived +24.
1W02 1152 London Paddington to Hereford : held Evesham (+23) for 1P30, arrived Great Malvern +30 and cancelled thereafter.
1W25 1252 London Paddington to Worcester Foregate St (15:00) : arrived Shrub Hill +15 and cancelled thereafter.
1P30 1316 Worcester Shrub Hill to London Paddington : departed +15, arrived +32.
This is due to a speed restriction over defective track.
Last Updated:26/09/2025 15:05
This is due to congestion.
Last Updated:26/09/2025 14:20
| Re: North Cotswold line delays and cancellations - 2025 Posted by Richard Fairhurst at 09:57, 26th September 2025  |   ![]() ![]() ![]()  |
It was also short-formed (5 carriages vs 9) so got very cosy at Oxford!
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 14:46, 25th September 2025  |   ![]() ![]() ![]()  |
Thursday September 25
It has been delayed at London Paddington and is now 19 minutes late.
Last Updated:25/09/2025 14:06
Departed Paddington +19, held Shrub Hill (+30) and Foregate St (+40), arrived Great Malvern +48.It has been delayed at London Paddington and is now 19 minutes late.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Mark A at 12:04, 24th September 2025  |   ![]() ![]() ![]()  |
Thanks, both. A pdf on how this all works answered my next question - how does the signaller know that everything has has been successfully positioned. (Answer, position-detection, and interlocking of that with the signalling...)
https://www.thepwi.org/wp-content/uploads/2022/10/Journal-2022_10-Vol140-Pt4_Back-to-basics-Points-Part-1-of-2.pdf
| Re: North Cotswold line delays and cancellations - 2025 Posted by Oxonhutch at 11:24, 24th September 2025  |   ![]() ![]() ![]()  |
350 yards sounds like a monster - and yes, I can imagine that every installation would require a different knack to shift it successfully - and perhaps different depending on the time of day, sun, shade, weather.
On a heritage line that I work, one distant set of mechanical points are more easily changed in wet weather, rather than dry, when the initial momentum imparted can carry them over their travel. Likewise one cross-over near to the 'box can be an absolute brute in certain weather/temperature.
Princes Risborough North has a Westinghouse point hand-wound generator but it isn't connected to any points. Two large incandescent bulbs provide the necessary resistance and a demonstration of the resultant power generated by human effort.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 10:14, 24th September 2025  |   ![]() ![]() ![]()  |
Getting completely off topic now, but the worst ones to move weren't always the most remote from the lever frame
The trailing crossover between the mains at Witham (No 33 from memory) was only a few yards from the 'box but was a really heavy pull, and even heavier to put back normal
| Re: North Cotswold line delays and cancellations - 2025 Posted by Mark A at 09:18, 24th September 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 09:15, 24th September 2025  |   ![]() ![]() ![]()  |
Mechanical boxes that had power-worked points and locks (the maximum distance for rodding-run signalman power was 350 yds) would have a "hurdy gurdy".  A generator worked by winding a handle on the side of a huge cast steel casing.  These took an age and much cranking to swing points over.  Horrible things
Do any of these survive, either at a heritage railway or in a museum?
I'm not sure. Where there was mains power, these hand cranked generators (a Westinghouse Brake & Signal Co product) were used as backups for mains failure. They may still exist in some places on the big railway. I wonder if there's one at Blue Anchor or Williton on the WSR? Both have had mechanically worked points converted from rodding run to motor in more recent years. Longer rodding runs are heavy to shift, and can cause maintenance and adjustment issues. There's a definite knack to swinging the lever, and it's different for every point/lock
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 08:09, 24th September 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 07:54, 24th September 2025  |   ![]() ![]() ![]()  |
Tuesday September 24
And after yesterday, Tuesday was (thank goodness) uneventful.
Wednesday September 25
07:13 Great Malvern to London Paddington due 09:42 will be started from Worcester Shrub Hill.
Last Updated:24/09/2025 06:12
"Train crew being delayed" at 07:13? The first journey for this unit is from Stoke Gifford (depart 04:40) to Great Malvern to start in service.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 06:09, 23rd September 2025  |   ![]() ![]() ![]()  |
Final scores for Monday September 22:
1P11 05:16 Worcester Shrub Hill to London Paddington (07:24) : OK
1P02 05:23 Hereford to London Paddington (08:24) : cancelled throughout due to Sunday's electrical problem
1P16 06:43 Worcester Shrub Hill to London Paddington (08:44) : departed on time, held Norton (+57), delayed between there and Evesham (+83), arrived +92.
2E80 07:00 Worcester Shrub Hill to Didcot Parkway (08:46) : cancelled throughout.
1P18 07:13 Great Malvern to London Paddington (09:42) : held Foregate St (+23) and Shrub Hill (+39), operated via Stroud, arrived +32.
1P20 08:18 Worcester Shrub Hill to London Paddington (10:25) : operated via Stroud, arrived +12.
1P22 08:56 Great Malvern to London Paddington (11:27) : started from Moreton.
1P24 09:56 Great Malvern to London Paddington (12:23) : started from Oxford.
1P26 10:59 Great Malvern to London Paddington (13:25) : started from Oxford.
1P28 11:58 Great Malvern to London Paddington (14:23) : cancelled throughout.
1P30 13:16 Shrub Hill to London Paddington (15:22) : cancelled throughout.
1P04 13:18 Hereford to London Paddington (16:24) : started from Oxford, arrived +20.
1P34 15:18 Foregate St to London Paddington (17:29) : cancelled throughout. Ran ECS from Oxford (+27), arrived +30.
1P05 15:18 Hereford to Paddington (18:29) : started from Oxford (+27), arrived +20.
1P38 16:32 Great Malvern to London Paddington (19:29) : started from Foregate St (+11), held Charlbury (+24), arrived +24.
1P39 17:26 Foregate St to London Paddington (19:52) : started from Oxford (+17), arrived +19.
1P40 18:02 Foregate Street to London Paddington (20:29) : started from Shrub Hill (+8), held Norton (+15), arrived +5.
2E16 18:51 Evesham to Oxford (19:50) : cancelled throughout.
1P42 19:02 Great Malvern to London Paddington (21:26) : OK
1P44 19:45 Great Malvern to London Paddington (22:24) : started from Shrub Hill, held Norton (+6), saved 8 at Charlbury
1P46 20:56 Worcester Foregate Street to London Paddington (23:29) : cancelled throughout "due to a broken down train".
1P06 22:00 Hereford to London Paddington (01:17) : OK
First Worcester - Oxford after the disruption was 1P38, 16:46 from Foregate St (+11).
2E77 05:10 Oxford to Worcester Shrub Hill (06:15) : OK
1W11 05:53 London Paddington to Great Malvern (08:38) : cancelled after Moreton-in-Marsh
1W13 06:52 London Paddington to Great Malvern (09:29) : cancelled after Oxford
1W15 07:50 London Paddington to Great Malvern (10:14) : cancelled after Oxford
1W17 08:52 London Paddington to Great Malvern (11:14) : cancelled after Moreton-in-Marsh
1W01 09:52 London Paddington to Hereford (12:46) : cancelled after Oxford
1W21 10:53 London Paddington to Worcester Shrub Hill (13:01) : cancelled after Moreton-in-Marsh
1W02 11:52 London Paddington to Hereford (14:44) : cancelled after Oxford
1W25 12:52 London Paddington to Worcester Foregate Street (15:00) : cancelled after Oxford
1W27 13:50 London Paddington to Great Malvern (16:15) : cancelled after Oxford
1W29 14:53 London Paddington to Foregate Street (17:04) : cancelled throughout.
1W30 15:23 London Paddington to Foregate Street (17:47) : held Oxford (+26), arrived Shrub Hill +31 and cancelled thereafter.
1W31 15:52 London Paddington to Great Malvern (18:26) : delayed before Oxford (+28), held Wolvercote (+32), saved 13 at Evesham, arrived +29.
2E14 17:04 Didcot to Evesham (18:23) : departed +30, arrived Oxford +34 and cancelled thereafter.
1W33 16:58 London Paddington to Great Malvern (19:25) : departed +12, Oxford +21, Evesham +37, arrived Shrub Hill +39 and cancelled thereafter
1W03 17:34 London Paddington to Hereford (20:25) : held Wolvercote (+17) and Evesham (+40), arrived +47.
1W34 17:57 London Paddington to Worcester Foregate Street (20:11) : cancelled throughout "due to a broken down train"
1W36 18:57 London Paddington to Great Malvern (21:18) : OK
1W05 19:53 London Paddington to Hereford (22:57) : OK
1W41 20:52 London Paddington to Great Malvern (23:13) : OK
1W43 21:53 London Paddington to Worcester Shrub Hill (00:01) : OK
1W45 22:51 London Paddington to Worcestershire Parkway (01:06) : OK
First Oxford - Worcester train (after the 05:16) was 1W30, scheduled 16:22, actual 16:48.
| Re: North Cotswold line delays and cancellations - 2025 Posted by ray951 at 20:07, 22nd September 2025  |   ![]() ![]() ![]()  |
I agree it was a shambles.
The 1523 Paddington to Worcester Foregate Street sat at Oxford for 26 minutes and at the same time the 1518 Worcester Foregate Street to Paddington, which was due to start from Oxford at 1631 sat there for about 20 minutes which means platform 3 and 4 where both occupied at the same time causing massive delays to all other services.
I notice that it says the 1518 was cancelled due to a 'Safety Inspection on this train' that is interesting because the driver announced that it was cancelled due to no Train Manager. Looking at RealTimeTrains it seems to have had no problem then working empty to Paddington and onto Penzance. Given you can run an IET as DOO from Oxford to Paddington I don't understand why it was cancelled?
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 17:06, 22nd September 2025  |   ![]() ![]() ![]()  |
15:18 Worcester Foregate Street to London Paddington due 17:29 has been cancelled.
This is due to a safety inspection on a train.
Last Updated:22/09/2025 16:52
Last Updated:22/09/2025 14:26
Last Updated:22/09/2025 14:27
Quite the shambles, isn't it?
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 16:19, 22nd September 2025  |   ![]() ![]() ![]()  |
Positive news (though some of it is ambiguous):
 Cancellations to services between Moreton-In-Marsh and Worcestershire Parkway Ll
Following a safety inspection of the track between Moreton-In-Marsh and Worcestershire Parkway Ll all lines will be reopened shortly.
Train services running through these stations will be cancelled. Disruption is expected until the end of the day.
Due to a safety inspection of the track, we are currently unable to run any trains between Moreton-in-Marsh and Worcestershire Parkway.
Last Updated:22/09/2025 14:48
14:55 Moreton-In-Marsh to Oxford due 15:35
An additional train service has been planned to operate as shown 14:55 Moreton-In-Marsh to Oxford due 15:35.
Last Updated:22/09/2025 14:51
13:50 London Paddington to Great Malvern due 16:15 will be delayed at Oxford.
This is due to a safety inspection of the track earlier today.
Last Updated:22/09/2025 14:42
14:53 London Paddington to Worcester Foregate Street due 17:04 will be started from Oxford.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 14:07, 22nd September 2025  |   ![]() ![]() ![]()  |
First thing this morning we had 1P11 05:16 Worcester Shrub Hill to London Paddington travel eastbound OK, and 2E77 0510 Oxford to Worcester Shrub Hill (the positioning journey for the halts train) travel westbound OK.
The halts train, 2E80 0700 Worcester Shrub Hill to Didcot Parkway, was cancelled "due to a problem with signalling equipment (J3)".
The unit has been trapped at Shrub Hill, but ran back to Oxford, departing at 11:06. It took an hour (11:17-12:18) between Norton and Evesham. But arrived at Oxford at 13:05.
JourneyCheck is now reporting disruption until the end of the day:
Due to a safety inspection of the track between Moreton-In-Marsh and Worcestershire Parkway Ll all lines are blocked.
| Re: North Cotswold line delays and cancellations - 2025 Posted by ChrisB at 12:28, 22nd September 2025  |   ![]() ![]() ![]()  |
Now until 1600.....how long does it take?? Find a fuse?
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 12:25, 22nd September 2025  |   ![]() ![]() ![]()  |
Nothing between Moreton in Marsh and Worcester because of a track inspection, 22/09/2025 ...
Train services running through these stations will be cancelled. Disruption is expected until 14:00 22/09.
Rail replacement transport has been requested in the form of coaches. Coaches will shuttle between Moreton-in-Marsh and Worcester Shrub Hill until further notice.
Last Updated:22/09/2025 12:12
| Re: North Cotswold line delays and cancellations - 2025 Posted by Witham Bobby at 08:59, 22nd September 2025  |   ![]() ![]() ![]()  |
There was a powercut in Moreton overnight which I guess might have affected the signalbox in some way? But don't they have generators on stand-by?
There certainly wasn't a standby generator there back when I last worked the 'box in 1974. But things have changed a bit since then, not least the CCTV supervised level crossings at Blockley and Chipping Campden, and the re-doubling of the line to Evesham.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 07:32, 22nd September 2025  |   ![]() ![]() ![]()  |
Monday September 22
And after yesterday, "a fault with the signalling system" continues, though it's only flagged up on JourneyCheck's 'Line Updates' section at 08:19:
 Cancellations to services between Worcestershire Parkway Ll and Moreton-In-Marsh
Due to a fault with the signalling system between Worcestershire Parkway Ll and Moreton-In-Marsh all lines are blocked.
Train services running through these stations may be cancelled. Disruption is expected until 10:00 22/09.
Due to a fault with the signalling system, we are currently unable to run any trains between Worcestershire Parkway and Moreton-in-Marsh.
Last Updated:22/09/2025 08:19
...which has now changed to a "safety inspection of the track":
Train services running through these stations will be cancelled. Disruption is expected until 13:00 22/09.
Last Updated:22/09/2025 09:47
This is due to failure of the electricity supply.
Last Updated:22/09/2025 00:34
06:43 Worcester Shrub Hill to London Paddington due 08:44 has been cancelled.
Last Updated:22/09/2025 07:27
But a bit later:
06:43 Worcester Shrub Hill to London Paddington due 08:44 has been reinstated.
It is being delayed at Worcester Shrub Hill.
Last Updated:22/09/2025 07:33
Departed Shrub Hill on time, held Norton (+57). Delayed between there and Evesham +83, arrived +92.It is being delayed at Worcester Shrub Hill.
07:00 Worcester Shrub Hill to Didcot Parkway due 08:46 has been cancelled.
Last Updated:22/09/2025 07:26
07:13 Great Malvern to London Paddington due 09:42 will be diverted between Worcester Shrub Hill and Reading.
It has been delayed between Worcester Foregate Street and Worcester Shrub Hill and is now 39 minutes late.
Last Updated:22/09/2025 08:17
Held Foregate St (+23) and Shrub Hill (+39). Via Stroud. Arrived +32.This is due to a fault with the signalling system.
08:18 Worcester Shrub Hill to London Paddington due 10:25 will be diverted between Worcester Shrub Hill and Reading.
Arrived +12.This is due to a fault with the signalling system.
08:56 Great Malvern to London Paddington due 11:27 will be started from Moreton-In-Marsh.
Last Updated:22/09/2025 07:16
Last Updated:22/09/2025 07:17
10:59 Great Malvern to London Paddington due 13:25 will be started from Oxford.
Last Updated:22/09/2025 08:30
11:58 Great Malvern to London Paddington due 14:23 will be started from Moreton-In-Marsh.
Last Updated:22/09/2025 09:13
13:16 Worcester Shrub Hill to London Paddington due 15:22 will be started from Moreton-In-Marsh.
This is due to a safety inspection of the track.
Last Updated:22/09/2025 10:35
13:18 Hereford to London Paddington due 16:24 will be started from Oxford.
Last Updated:22/09/2025 10:28
15:18 Hereford to London Paddington due 18:29 will be started from Oxford.
Last Updated:22/09/2025 09:25
05:53 London Paddington to Great Malvern due 08:38 will be terminated at Moreton-In-Marsh.
Last Updated:22/09/2025 07:14
07:50 London Paddington to Great Malvern due 10:14 will be terminated at Oxford.
08:52 London Paddington to Great Malvern due 11:14 will be terminated at Moreton-In-Marsh.
09:52 London Paddington to Hereford due 12:46 will be terminated at Oxford.
10:53 London Paddington to Worcester Shrub Hill due 13:01 will be terminated at Moreton-In-Marsh.
11:52 London Paddington to Hereford due 14:44 will be terminated at Oxford.
Edits:
08:30 : updates added.
09:15 : more updates added.
10:15 : more updates added.
12:15 : disruption expected until 14:00.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Chris from Nailsea at 22:01, 21st September 2025  |   ![]() ![]() ![]()  |
PBT? Post Brunel Technology. The railway always finds this tricky.
I shall add it to our Coffee Shop forum's 'abbreviations and acronyms' page, at https://www.firstgreatwestern.info/acronyms.html
 | Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 21:43, 21st September 2025  |   ![]() ![]() ![]()  |
JourneyCheck's 'line updates':
 Alterations to services between Great Malvern and Oxford via Worcester Shrub Hill
Following failure of the electricity supply between Oxford and Worcester Shrub Hill all lines have now reopened. Disruption is expected until the end of the day.
Train services between Great Malvern and Oxford via Worcester Shrub Hill and Moreton-In-Marsh may be delayed by up to 55 minutes or revised. Malvern Link, Great Malvern, Colwall, Ledbury, Hereford, London Paddington and Didcot Parkway will not be served.
A power failure affected the signalling resulting in trains have to run a reduced speed on the North Cotswold Line earlier. Trains can now run at full speed but there are residual delays.
We are having to terminate some trains short of their destination at Reading instead of Paddington and Worcester instead of Great Malvern. This is to ensure the next train runs on time.
Last Updated:21/09/2025 20:07
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 17:24, 21st September 2025  |   ![]() ![]() ![]()  |
There's a nice picture of this box at https://old.signalbox.org/gallery/w/moretoninmarsh.php, which tells me that the lever frame dates from 1911.
It's possible that the overnight power cut may have affected some of the new-fangled PBT electrical equipment. But the idea of this box having a standby generator may be very optimistic.
| Re: North Cotswold line delays and cancellations - 2025 Posted by ChrisB at 16:27, 21st September 2025  |   ![]() ![]() ![]()  |
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 06:32, 21st September 2025  |   ![]() ![]() ![]()  |
Sunday September 21
07:36 London Paddington to Great Malvern due 10:15 will be started from Reading and terminated at Oxford.
Last Updated:21/09/2025 06:18
An additional train service has been planned to operate as shown 10:00 Worcester Shrub Hill to Great Malvern due 10:15.
Last Updated:21/09/2025 06:23
This implies that a Sunday morning journey that lasts 2:39 has four different TMs, changing at Reading, Oxford and Shrub Hill.
Later (15:00), there are problems with the electricity supply:
13:13 Worcester Foregate Street to London Paddington due 15:26 will no longer call at Didcot Parkway and Reading.
It has been delayed between Evesham and Moreton-In-Marsh and is now 31 minutes late.
Last Updated:21/09/2025 14:39
Delayed between Evesham (+3) and Moreton (+27). Oxford +36. Arrived +40.It has been delayed between Evesham and Moreton-In-Marsh and is now 31 minutes late.
13:58 Great Malvern to London Paddington due 16:26 is being delayed between Worcester Shrub Hill and Charlbury.
Last Updated:21/09/2025 14:50
Held Shrub Hill (+14), delayed Evesham (+21) - Honeybourne (+30). Oxford +42, arrived Reading +37 and cancelled thereafter.This is due to failure of the electricity supply.
14:28 Hereford to London Paddington due 17:27 will be delayed between Worcester Shrub Hill and Charlbury.
Held Ledbury for 1W02 (+11) and Shrub Hill (+31). Charlbury +55. Arrived Reading +61 and cancelled thereafter.This is due to failure of the electricity supply.
16:58 Great Malvern to London Paddington due 19:27 will be started from Worcester Shrub Hill.
Last Updated:21/09/2025 16:03
Held Norton (+19), Charlbury (+44), delayed Oxford (+59), arrived +61.This is due to failure of the electricity supply.
17:30 Hereford to London Paddington due 20:27 will be delayed between Worcester Shrub Hill and Charlbury.
Last Updated:21/09/2025 17:55
No delay Shrub Hill - Charlbury. Held Charlbury (+28), arrived +35.This is due to failure of the electricity supply.
18:57 Great Malvern to London Paddington due 21:27 will be started from Worcester Shrub Hill.
It will be delayed between Worcester Shrub Hill and Charlbury.
19:58 Great Malvern to London Paddington due 22:27 will be delayed between Worcester Shrub Hill and Charlbury.
20:46 Great Malvern to London Paddington due 23:39 will be started from Worcester Shrub Hill.
Last Updated:21/09/2025 19:26
1W02 11:45 London Paddington to Hereford (15:04) : Delayed between Moreton (+11) and Honeybourne (+23), saved 13 at Great Malvern and 6 at Ledbury, arrived +10.
12:45 London Paddington to Hereford due 16:04 is being delayed between Charlbury and Worcester Shrub Hill.
Delayed between Charlbury (+13) and Ascott (+25). Evesham +38. Saved 16 at Ledbury, arrived +34.This is due to failure of the electricity supply.
13:45 London Paddington to Great Malvern due 16:16 will be delayed between Charlbury and Worcester Shrub Hill.
Held Wolvercote (+11), delayed Charlbury (+15) - Ascott (+28). Held Evesham (+61). Arrived Shrub Hill +63 and cancelled thereafter.This is due to failure of the electricity supply.
14:45 London Paddington to Great Malvern due 17:16 will be delayed between Charlbury and Worcester Shrub Hill.
Held Wolvercote (+14), arrived Shrub Hill +43 and cancelled thereafter.This is due to failure of the electricity supply.
15:45 London Paddington to Great Malvern due 18:16 will be terminated at Worcester Shrub Hill.
Departed +33, Oxford +47, arrived Shrub Hill +71 and cancelled thereafter.This is due to failure of the electricity supply.
16:45 London Paddington to Great Malvern due 19:16 will be started from Reading.
Departed Reading +47, arrived Shruib Hill +62 and cancelled thereafter.This is due to failure of the electricity supply.
17:45 London Paddington to Great Malvern due 20:15 will be delayed between Charlbury and Worcester Shrub Hill.
Held Oxford (+35) and Evesham (+55), arrived Shrub Hill +59 and cancelled thereafter.This is due to failure of the electricity supply.
18:45 London Paddington to Hereford due 21:54 has been cancelled.
Last Updated:21/09/2025 18:47
17:15 - more updates added.
18:15 - more updates added. The delays still haven't made it to JourneyCheck's 'Line Updates' section, which might give us an idea of when things will be restored.
21:55 - more updates added. The dalays have made it to JourneyCheck's 'Line Updates' section. "Disruption is expected until the end of the day."
Though the cancellation of the 18:45 from Paddington to Hereford means that tomorrow morning's 1P02 05:23 Hereford to London Paddington probably won't run.
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 21:28, 20th September 2025  |   ![]() ![]() ![]()  |
Saturday September 20
1W03 1650 London Paddington to Hereford : departed +23, arrived Great Malvern +25 and cancelled thereafter.
20:20 Hereford to London Paddington due 23:38 will be started from Great Malvern.
Last Updated:20/09/2025 19:04
| Re: North Cotswold line delays and cancellations - 2025 Posted by Worcester_Passenger at 15:29, 19th September 2025  |   ![]() ![]() ![]()  |
1W02 1152 London Paddington to Hereford : departed +13, Reading +30, arrived Worcester Shrub Hill +36 and cancelled thereafter.
15:18 Hereford to London Paddington due 18:29 will be started from Worcester Shrub Hill.
Last Updated:19/09/2025 12:59
