Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by TaplowGreen at 12:49, 23rd November 2024 |
Cancellations to services between Reading and Gatwick Airport
Due to a shortage of train crew between Reading and Gatwick Airport fewer trains are able to run on some lines.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until the end of the day
Due to train crew shortages throughout the day, a number of train services operating between Reading - Gatwick Airport (both directions) have been cancelled/ altered.
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by eightonedee at 18:08, 10th November 2024 |
According to Wikipedia, all GWR Turbos are rated at 90mph. Although since I retired two years ago I no longer travel the North Downs daily, generally around Reading and the Thames Valley I only see 165s (when I look/notice - to be fair, not often! I'm grateful that most of my journeys are on Electrostars). I think most 166s "went west", but no doubt more westerly based colleagues will confirm.
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by grahame at 14:48, 9th November 2024 |
Someone will have to explain to me why more trains needing repairs, means all trains have to run at reduced speed on all lines.
Are they all suddenly not certified for normal speed, it is not like they are substituting with a slower train.
I also don't like reference to all lines, is that all England, all UK, or simply a badly worded that route only.
It's badly worded - in fact awfully worded.
There are two classes of turbo trains - the 165 and the 166, and the top speed in 75 mph and 90 mph I believe, so - yes - it is quite possible that a trains timed for a 90 mph unit which needs repair (or is overdue maintenance and cannot be used until that happens) is getting replaced by one with a 75 mph limit. Perhaps others "in the know" can confirm this?
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by John D at 14:23, 9th November 2024 |
Cancellations to services between Gatwick Airport and Reading
Due to more trains than usual needing repairs at the same time between Gatwick Airport and Reading trains have to run at reduced speed on all lines.
Train services running to and from these stations may be cancelled. Disruption is expected until 19:00 08/11.
Apologies to customers, some of our trains have broken down and we don't have enough trains in our GWR fleet to operate a full service on the North Downs Line. Therefore some trains will be cancelled.
We obviously see the text in italic a fair bit, but I think that's the first time I've seen the part in bold. I reckon we could just use the bit in bold from now on as the part in italic is trotted out so much as to be implausible.Due to more trains than usual needing repairs at the same time between Gatwick Airport and Reading trains have to run at reduced speed on all lines.
Surely if it is due to we have flattened some wheels why not say so, or explain why they can't swap in some good ones (have insufficient spares) and although it happens every year, explain why never bought extra wheel lathe (having sufficient serviceable trains in not a priority), or whatever the reason is.
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by Fourbee at 09:15, 9th November 2024 |
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by TaplowGreen at 18:01, 8th November 2024 |
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by grahame at 08:20, 13th August 2024 |
Not good, but only one cancellation every three and a half hours in each direction, one in every seven. Presumably not enough Turbos or crews available.
Agreed.
One in seven passengers hits a cancellation, which puts them back 30 minutes, so the average passenger is delayed by 4.28 minutes.
Interesting to do the same calculation for my local line ...
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by eightonedee at 08:02, 13th August 2024 |
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by TaplowGreen at 07:47, 13th August 2024 |
Not looking like a great option today either - all cancelled;
07:20 Reading to Gatwick Airport due 08:55
09:00 Gatwick Airport to Reading due 10:28
10:54 Reading to Gatwick Airport due 12:25
12:29 Gatwick Airport to Reading due 13:57
14:24 Reading to Gatwick Airport due 15:55
15:59 Gatwick Airport to Reading due 17:28
17:49 Reading to Gatwick Airport due 19:25
19:29 Gatwick Airport to Reading due 20:57
21:36 Reading to Gatwick Airport due 23:12
23:22 Gatwick Airport to Reading due 00:43
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by bobm at 17:53, 2nd August 2024 |
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by bobm at 17:49, 2nd August 2024 |
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by TaplowGreen at 16:49, 2nd August 2024 |
According to this poster I saw at Swindon last week, you can catch a lovely IET from Reading to Gatwick.
I expect Broadgage will be on that one, we know how much he loves IETs - the ideal start for his annual fortnight partying in Benidorm, flying from Gatwick!
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by JayMac at 15:14, 2nd August 2024 |
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by TaplowGreen at 06:14, 2nd August 2024 |
Best take another route today...
Train services running to and from these stations may be cancelled. Disruption is expected until the end of the day.
Due to train and crew shortages some services between Reading to Gatwick Airport will be cancelled.
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by TaplowGreen at 14:38, 27th July 2024 |
All lines reopened shortly after your post.
Yes good to see that disruption doesn't seem to have lasted beyond the time advertised.
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by IndustryInsider at 13:44, 27th July 2024 |
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by TaplowGreen at 13:05, 27th July 2024 |
All trains cancelled. First full weekend of the summer holidays. What a great advert for the railway.
Due to a fault with the signalling system between Reading and Gatwick Airport all lines are blocked.
Train services running to and from these stations will be cancelled. Disruption is expected until 14:45 27/07.
We're sorry ALL TRAINS are CANCELLED on the North Downs Line until further notice due to multiple signal faults at Guildford.
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by grahame at 15:43, 5th July 2024 |
Exactly. Reliability on this line is terrible.
Really?
Although it's now over two years since I retired from being a commuter along this line, I've not noticed it being particularly prominent among all the news of problems.
Compared to Swindon - Westbury, or North Cotswolds, I expect it looks a paragon of reliability - although sadly those a very low bars to exceed.
Some data:
Over the last 6 months, Gomshall has been the 1464th best perrormig station - down 549 places with 4% cancellations. If a train is cancelled, the next one will be along in an hour, or 30 minutes if a stop order is added.
Over the last 6 months, Melksham has been the 1900th best performing station - up 98 places with 7% cancellations. If a train is cancelled, the next one will be along about 2 hours later.
Over the last 6 months, Evesham has been the 2560th best performing stations - down 73 places with 5% cancelled. If a train is cancelled, next one is typically an hour later.
The ranking is based not only on percentage cancelledm but also on delays. At Evesam, 55% are on time, at Melksham 71% are on time and at Gomshall 77% are on time.
Source on-time trains, with a midline station selected to ensure reasonable comparable data.
The North Downs line has slipped ... but cancellation are roughly half of what they are at my home station of Melksham and the wait when one does not run is only a quarter of the time if another train coming through is stopped instead. By all means be unhappy with the North Downs line and how it has slipped, but don't for a moment think you are now worse served than some of these other places ....
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by eightonedee at 14:45, 5th July 2024 |
Really?
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by TaplowGreen at 10:29, 5th July 2024 |
Might not be so good with the amount of crew shortages recently.
Re: Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by CyclingSid at 07:06, 5th July 2024 |
Advert - take the train to Gatwick. ALL the way from home to Gatwick!! Posted by grahame at 07:49, 4th July 2024 |
Now twice an hour from Reading. Fast (well, reasonably so) and not subject to this sort of problem ..
Holidaymakers say they have been left hundreds of pounds out of pocket after using two meet-and-greet car parking firms at Gatwick, the UK's second largest airport.
One passenger said she had to get a taxi nearly 150 miles home to Norfolk after Drive Park and Fly told her they could not find her car key when she arrived at the West Sussex airport.
Indeed take public transport ALL the way - don't park at stations either! http://www.passenger.chat/apcoa
We catch the local bus from outside our home - pity it does not go to the local station but it DOES go (daytime, Monday to Saturday) to Bath Spa Station, where a nice man (not being sexist, but I can't recall any ladies on the staff) helps us get the correct ticket, a lift takes us up to the platform, and we are even offered help boarding the train these days. Allowing plenty of time ... if it's Gatport (change at Reading), or Southampton (for the port) and it's a leaisurly and easy run. Or catch the A4 bus across the road into Bristol Airport.
For the absence of doubt, I fly very little these days - 24 counties in the first half of 2024, with just one flight whenI was time constrained. But I HAVE taken multiple people to Gatwick and helped with checkin procedures.
