Cornish delays
19.4.2025 (Saturday) 20:18 - All running AOK
Re: Cornish delays
Posted by GBM at 22:44, 18th April 2025
2P27 arrived at Plymouth 74 minutes late with 1Z99 waiting for it.
2M77 arrived Plymouth 59 minutes late; left 57 minutes late.
5P90 arrived 59 late; still sat at platform.
1Z99 seems to have departed back to Laira without 2P27 (5P27).
5P27 departed for Laira 22h37.
2P29 arrived 26 late.
5P86 arrived 24 late.
Re: Cornish delays
Posted by GBM at 21:53, 18th April 2025
2P27 1850 Penzance to Plymouth (HST) WAS reported as delayed at St Germans due to a safety inspection of this train.
Please clarify - do the train crew inspect the outside and inside; or what!
It has been sat at (or just passed) St Germans since 20h30.
2M77 1915 Penzance to Bristol Temple Meads (5 car IET) seems to have driven up to 2P27 (or near it), but has been sat there since 21h28.
5P90 2041 Par to Exeter Tmd (2 car unit) sat at Liskeard since 21h30.
2P29 2015 Penzance to Plymouth (9 car IET) sat at Bodmin since 21h30.
5P86 2039 Penzance to Laira T.& R.S.M.D. (9 car IET) sat outside Lostwithiel since 21h31.
Re: Cornish delays
Posted by GBM at 09:36, 17th March 2025
Due to a points failure between Plymouth and Penzance the line towards Penzance is blocked.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 09:30 17/03.
A set of points at the Royal Albert bridge at Plymouth have failed. Network Rail colleagues are on site investigating.
As a consequence services from Plymouth to Penzance will be disrupted, however services towards Plymouth, Exeter, Bristol Temple Meads and London Paddington will run.
05:03 Penzance to London Paddington due 09:56
05:03 Penzance to London Paddington due 09:56 will no longer call at Taunton.
It has been delayed between Liskeard and Saltash and is now 30 minutes late.
1A73 0503 Penzance to London Paddington is now non stop between Exeter and Reading.
A rarity surely?
Re: Cornish delays
Posted by ChrisB at 07:00, 3rd March 2025
That is one page?…..
Re: Cornish delays
Posted by GBM at 06:30, 3rd March 2025
Travellers travelling the day would just check journeycheck to see if their chosen train is running/fully formed, etc.
Then have to check the engineering page for engineering works as well?
It would be helpful if engineering works appeared on the daily journeycheck page as well.
Re: Cornish delays
Posted by ChrisB at 20:07, 2nd March 2025
Not sure where you are accessing Journeycheck?
Check 'Improvement Works' on this page?
There's an 'Improvement Works' tab at top left too that gives date choices if you want info for other days
Re: Cornish delays
Posted by GBM at 09:51, 2nd March 2025
So in addition to checking journeycheck before a trip, passengers also need to check a seperate page journeycheck engineering!
Sure the engineering works should be on the normal journeycheck page....
Re: Cornish delays
Posted by Timmer at 09:34, 2nd March 2025
A quick check on RTT shows bus services running between Plymouth and St Austell this morning.
No direct trains between Plymouth and Penzance.
Nothing on journeycheck.
It is listed on the GWR Engineering work page:
https://www.gwr.com/travel-information/travel-updates/planned-engineering
Track renewal work will impact all train services to/from Cornwall.
GWR trains will run between Plymouth and London Paddington, plus CrossCountry train services will run between Plymouth and Birmingham New Street or beyond.
Limited train services will operate between Plymouth and Liskeard.
Trains will run between Par and Penzance, plus on the Looe, Newquay, Falmouth Docks and St Ives branch lines in Cornwall.
Replacement buses are planned between:
Plymouth and St Austell (non-stop)
Liskeard and St Austell
Re: Cornish delays
Posted by GBM at 08:19, 2nd March 2025
Re: Cornish delays
Posted by GBM at 08:10, 2nd March 2025
https://www.crosscountrytrains.co.uk/travel-updates-information/service-updates/birmingham-to-bristol-and-the-west-country
Engineering Work: Between Liskeard and Par
Planned engineering work will take place between Liskeard and Par from 00:01, Sunday 02 March 2025 to 23:59, Sunday 02 March 2025.
All lines will be closed.
All services will be terminating at Plymouth.
No CrossCountry trains will run between Plymouth and Penzance.
Passengers should use GWR services to complete your journey.
All lines will be closed?
Nothing showing on GWR journeycheck, so GWR running normally, just CrossCountry not running.
Odd?
Re: Cornish delays
Posted by GBM at 13:42, 18th February 2025
Delays to services between Plymouth and Penzance
Due to animals on the railway between Bodmin Parkway and Lostwithiel all lines are blocked. Disruption is expected until 14:30 18/02.
Train services between Plymouth and Penzance may be delayed.
We are sorry for the delay to your journey.
Re: Cornish delays
Posted by grahame at 14:28, 10th February 2025
Had to spend quite a while using the search function to find this topic in the forum.
No results found!
Next search found threads from 2020 and earlier, but not this topic.
Had to go into my posts section and scroll through.......
Please let me know the search terms you used and which search function - the one in the top bar after "Home, Help ..." or Deep Search?
Two emails with attachments sent.
Thank you ... and an answer / explanation - doing it in public since this is of general interest.
Our search tools are - if you like - a very basic form of AI and for "intelligence" have a rather low IQ and a frustrating pedanticism ... they search the bodies of public threads, the extractable text from .pdf documents and station names.
1. In the case of "Cornish delays" the words aren't mentioned as a pair anywhere in the thread - just in the subject line - so you drew a blank.  The fact that I have now mentioned them means that this tread and post will be found in the future. clearly a design shortcoming - because at times some of our member don't repeat the words of the subject in their threads - something I have been aware of for a time and I have just applied a patch so it searches both. I hope I have not caused a problem applying the law of unintended consequences.
2. Where a search uses a pseudonym the search is only on the word you put in - so look for "Cornish delays" and our system is not bright enough to look for "Cornwall delays' and will certainly not offer you  "Western Peninsular delays". If you put in a single word which does not match, it WILL offer you close spellings - "did you mean".   Put in "Sinday" and it will suggest Sunday, even if you were searching for a naughty overnight destination with the girlfriend.
3. If you put a space between word in the search we look for the words consequetively.  If you put an "*" between two words it will look for both words in the post / document and in that order, but not necessarily together
Our receptionist server is more powerful than our worker that does all the searching at present, and there is scope for enhancement - the sort of code I enjoy writing.  All sorts of consideration for - well - some point in the future
Re: Cornish delays
Posted by The Tall Controller at 13:05, 10th February 2025
St Erth signal box can be 'switched out' which basically transfers the Penzance-St Erth and St Erth-Roskear sections into a Penzance-Roskear section. In the process of switching out, the signaller at St Erth has to clear all signals to allow a clear route through the station in either direction.
Re: Cornish delays
Posted by GBM at 10:31, 10th February 2025
Question please.
If the box is not operative, how do trains run through if all signals are set to danger.
The driver can't call the closed signal box, so who has signalling control/authorisation?
Thank you
Re: Cornish delays
Posted by GBM at 10:29, 10th February 2025
Delays to services between Penzance and Plymouth
Due to signalling staff being taken ill at St Erth fewer trains are able to run on all lines. Disruption is expected until 20:00 10/02.
Train services between Penzance and Plymouth may be delayed.
BUT
Cancellations to services between St Erth and St Ives
Following signalling staff being taken ill between St Erth and St Ives the line will be reopened shortly.
Train services running to and from these stations are returning to normal but some services have been cancelled. Disruption is expected until 11:30 10/02.
Re: Cornish delays
Posted by GBM at 10:28, 10th February 2025
No results found!
Re: Cornish delays
Posted by grahame at 08:23, 10th February 2025
No results found!
Re: Cornish delays
Posted by GBM at 08:04, 10th February 2025
No results found!
Re: Cornish delays
Posted by GBM at 08:01, 10th February 2025
Due to signalling staff being taken ill at St Erth fewer trains are able to run on all lines. Disruption is expected until 10:00 10/02.
Due to Network Rail signalling staff being taken ill at St Erth, trains may be delayed in the St Erth area, as the other local signallers will need to send/receive trains one at a time through the affected area.
Please check your journey.
Due to signalling staff being taken ill between St Erth and St Ives the line is closed.
Train services running to and from these stations will be cancelled. Disruption is expected until 12:00 10/02.
Re: Cornish delays
Posted by RailCornwall at 22:24, 14th December 2024
National Grid are still fixing issues across Cornwall (and seemingly their whole distribution area) residual from last weekend, around 6,000 properties being cut off today NE of Redruth not being unusual. Unsurprising considering the number of issues they've had to deal with following the storm, I am expecting these to continue up to Christmas as I've heard of many 'make do and get power back on' rather than 'complete the repair and fully test for resilience' repairs being implemented in the days following. This resilience work is being undertaken now.
Re: Cornish delays
Posted by ellendune at 08:41, 14th December 2024
I wonder if this power failure was due to renewables, wind and solar, only providing 6% of electricity on the 13th.
Daily Telegraph reporting gas was supplying 72.5%, Nuclear 10%, wood burning 6.6%, wind 5.8%, solar nil and the rest from interconnecter cables..
If it had been there would have been major disruption on the grid not just a small part of Cornwall.
Perhaps a permanent standby generator would be a better option than having to source one during a failure of supply to what appears to be a location of considerable importance to the railway in Cornwall?
Given modern battery technology perhaps even a large standby battery. Standby generators are notoriously unreliable (as machines don't like standing idle).
Re: Cornish delays
Posted by REVUpminster at 07:34, 14th December 2024
Re: Cornish delays
Posted by Witham Bobby at 11:48, 12th December 2024
Following failure of the electricity supply earlier today between Penzance and Truro all lines are now open. Disruption is expected until 12:00 12/12.
Train services between Plymouth and Penzance are returning to normal but some services may still be delayed.
Due to an earlier power cut affecting the signalling power supply, trains were unable to run this morning.
A generator has been arranged and power has been restored to the signalling system allowing train services to run.
Re: Cornish delays
Posted by old original at 08:00, 12th December 2024
Query - Why is the Falmouth branch at a standstill when the power failure is at Roskear?
The two 150 units are stabled at Penzance overnight.
Re: Cornish delays
Posted by GBM at 07:18, 12th December 2024
0503. 0605, 0710 Penzance to Paddington cancelled, as is/was everything else in between so far.
Re: Cornish delays
Posted by GBM at 07:09, 12th December 2024
Cancellations to services between Plymouth and Penzance
Due to failure of the electricity supply between Penzance and Truro all lines are blocked. Disruption is expected until 08:00 12/12.
Train services between Plymouth and Penzance will be cancelled or revised. Hayle, Redruth and Camborne will not be served.
No trains will run between Truro and Penzance until further notice.
We have asked for local bus ticket acceptance and requested replacement road transport but neither is in place as at 06:30.
During this disruption if you wish to use local buses as an alternative means of transport and the local bus is not accepting GWR tickets please purchase a ticket on the bus, keep it and send it, together with your train ticket, to us to claim for a refund.
Following a failure of the electicity supply at Roskear the line is blocked between Truro and Penzance including the Falmouth branch
If you require further information please speak to our staff at the station or on the train, use the Customer Help Point, tweet us @GWRHelp or call National Rail Enquiries on 03457 484 950.
Re: Cornish delays
Posted by REVUpminster at 09:33, 14th October 2024
St Ives is usually 2 cars once the holiday season is deemed over.
Re: Cornish delays
Posted by GBM at 09:17, 14th October 2024
08:45 Falmouth Docks to Truro due 09:12
08:45 Falmouth Docks to Truro due 09:12 will be cancelled.
09:05 Looe to Liskeard due 09:34
09:05 Looe to Liskeard due 09:34 will be cancelled.
18:23 Par to Newquay due 19:13
18:23 Par to Newquay due 19:13 will be cancelled.
St Ives branch down to 2 cars (usually 4)
Re: Cornish delays
Posted by Sleepy at 20:03, 13th October 2024
  Given the amount of mainline cancellations this afternoon your probably correct - no spare driver available to bring fresh stock to Par.
Re: Cornish delays
Posted by Trowres at 14:33, 13th October 2024
Unfortunately the train that was planned to be used for our Par to Newquay service has broken down and has had to be taken out of service. Furthermore, a spare is not available. No trains are running along the route today.
The cancellation information for individual trains on the route is giving shortage of train crew as the reason. A mistake, or shorthand for nobody available to drive a spare train to Par from wherever it might be stabled?
Re: Cornish delays
Posted by GBM at 11:16, 13th October 2024
Cancellations to services between Par and Newquay
Due to a fault on this train between Par and Newquay fewer trains are able to run.
Train services running to and from these stations have been cancelled. Disruption is expected until the end of the day.
Roda transport is covering the 13:35 departure, with return at 14:25 from Newquay. We are still trying to source transport for the rest of the day.
Re: Cornish delays
Posted by GBM at 04:03, 2nd September 2024
05:57 Liskeard to Looe due 06:27
02/09/24 05:57 Liskeard to Looe due 06:27 will be cancelled.
And the return run.
But help is on its way
06:19 Par to Plymouth due 07:21
02/09/24 06:19 Par to Plymouth due 07:21 will be terminated at Liskeard.
It will no longer call at Menheniot, St Germans, Saltash, St Budeaux Ferry Road, Keyham, Dockyard, Devonport and Plymouth.
Re: Cornish delays
Posted by GBM at 08:00, 1st September 2024
Due to a shortage of train crew between Par and Newquay:
Train services running to and from these stations may be cancelled. Disruption is expected until the end of the day.
Owing to a shortage of crew we are unable to run most of our train services between Par and Newquay today. Only the 12:08 and 15:05 will run between Par and Newquay, and only the 13:35 and 17:22 will run between Newquay and Par.
Replacement road transport has been requested to run in place of the cancelled services, however this is not yet confirmed.
Also
Cancellations to services between Liskeard and Looe
Due to a shortage of train crew between Liskeard and Looe:
Owing to a shortage of crew we are unable to run train services between Liskeard and Looe today.
Replacement Taxi Services are operating between Liskeard and Looe via Sandplace in both directions. The taxi companies are Yeo's Taxis and Taxi Services Plymouth. Before getting in any taxi vehicle please check with the driver that they are working on behalf of GWR, the driver should not ask for payment. Check the stations Onward Travel Information poster and wait for the replacement road transport at the designated stop.
Both posts also appear in Shortage of train crew and Liskeard - Looe problems.
Re: Cornish delays
Posted by GBM at 07:58, 1st September 2024
Also
Re: Cornish delays
Posted by Witham Bobby at 10:47, 17th July 2024
11:15 Penzance to Newquay due 13:11 will no longer call at Hayle, Camborne and Redruth.
Last Updated:17/07/2024 10:18
Wednesday
IYKYK
Re: Cornish delays
Posted by GBM at 07:18, 6th July 2024
Well, GWR genuinely can blame Network Rail for this one!
Rumour has it that vegetation caused a coach brake to come on and cause a flat.
As it did with the steam charter out of Plymouth recently.
Re: Cornish delays
Posted by eightonedee at 10:54, 4th July 2024
Re: Cornish delays
Posted by GBM at 09:38, 4th July 2024
With thanks to Jim Hancock who took and posted these shots of the failed "freight".
https://www.facebook.com/photo/?fbid=2299829693686843&set=pcb.1235222647889058
Ah, I can't copy and paste!
There was a post a while ago about setting up a profile on another site and linking across, or somehow transferring pictures on to here.
Need to look.
Re: Cornish delays
Posted by a-driver at 09:26, 3rd July 2024
Looking at OpenTrainTimes, the faulty freight is stuck on the up line.
Would have thought single line working could be achieved around St Austell as that appears to be di directionally signalled.
I’m not sure that it is.  Rumour has it, they ran out of money so it wasn’t fully installed/commissioned.
Re: Cornish delays
Posted by RailCornwall at 08:54, 3rd July 2024
The removal over the years of virtual passing loops in Cornwall really does show itself up with incidents like this. All main station platforms(*) should ideally be fully bi-directional, four crossings each, and as a result virtually every path between should be so to.
(*) Excluding
Hayle (group with St Erth)
Menheniot and St Germans (group together)
Dockyard and Devonport (group together)
Re: Cornish delays
Posted by GBM at 07:55, 3rd July 2024
Re: Cornish delays
Posted by GBM at 07:51, 3rd July 2024
3Q52 2129 Exeter Riverside N.Y. to Penzance seems to have sat down at Burngullow Junction.
Been sat on the main line since 0238.
Cancellations to services between Par and Truro
Due to a broken down train between Par and Truro all lines are blocked.
Train services running through these stations will be cancelled, delayed or suspended between Par and Truro. St Austell will not be served. Disruption is expected until 09:00 03/07.
We're sorry for the delay to your journey this morning.
A freight train has broken down between between St Austell and Par blocking all lines.
We plan to operate a train service between Penzance and Truro and between Par and Plymouth. Services that run between Cornwall and London Paddington will terminate at and start from Plymouth. St Austell is currently not served by train services.
We have tried to source replacement road transport, however there is a lack of availability in the area, and we are only able to provide a limited service, in both directions, between Par, St Austell and Truro.
While we are unable to run trains, you may use your ticket, at no extra cost, on the following local bus routes:
First Kernow routes:
U1/U1A between Truro station and Falmouth Docks.
U2 between Falmouth and Redruth
T1 between Penzance and Truro.
T2 between St Ives and Truro.
Last Updated:03/07/2024 07:48
Local radio saying taxi's are being used between Truro and Par, but nothing on journeycheck.
More delays at Liskeard - but not for the usual reasons ;-)
Posted by Chris from Nailsea at 19:52, 25th June 2024
Royal Mail says sorry for delays caused by seagulls
Residents in a town in Cornwall have received a letter from Royal Mail apologising for late mail - explaining that its delivery workers were being hampered by dive-bombing seagulls.
Royal Mail said those living in the affected zone in Liskeard could choose to wait until the birds were not aggressively protecting their young, or nominate a new address.
One Liskeard resident described it as "deadly" to go outside when the birds were nesting.
BBC article continues.
Re: Cornish delays
Posted by GBM at 15:36, 19th June 2024
Just one Falmouth branch unit running for a few hours it seems.
Nothing departed from Penzance between 1315 and 1531.
Re: Cornish delays
Posted by GBM at 14:55, 19th June 2024
2F82 1445 Truro to Falmouth Docks (Still sitting at platform 1) had to take passengers from two Plymouth - Penzance trains, plus those from the Paddington - Penzance.
Left 9 minutes down
Re: Cornish delays
Posted by GBM at 14:27, 19th June 2024
Interesting.
2C68 1142 Plymouth to Penzance was 84 late leaving St Pinnock Junction, now arriving Truro on platform 3 (the up platform), as the next Falmouth branch departure sits at platform 2 (down main).
The cancelled branch working at platform 1 probably with crew delayed by one of the delayed services.
Re: Cornish delays
Posted by GBM at 14:14, 19th June 2024
Cancellations to services between Liskeard and Penzance
Following a points failure between Liskeard and Penzance the line towards Penzance has now reopened.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 15:00 19/06.
We're please to advise the 08:03 London Paddington to Penzance service is now on the move. We will now begin to clear the back log of trains trying to make their way down towards Penzance and Newquay.
1C72 0803 London Paddington to Penzance 102 minutes down leaving St Pinnock Junction
Re: Cornish delays
Posted by GBM at 09:25, 16th June 2024
Alterations to services between Penzance and Plymouth
Due to a fault with barriers at a level crossing disruption is expected until 09:45 16/06.
AND
Alterations to services between Truro and Falmouth Docks via Penryn
Guessing the Longrock level crossing has a problem.
BUT
08:50 Truro to Falmouth Docks due 09:13
08:50 Truro to Falmouth Docks due 09:13 will be cancelled.
This is due to a power cut at the station.
08:15 Penzance to London Paddington due 13:21
08:15 Penzance to London Paddington due 13:21 will be starting late from Penzance.
Power cut at Penzance, or Truro?
The Truro and St Ives branch trains all come from Penzance, so all running late.
Truro one approximately 67 late at Camborne.
St Ives 17 late.
First Paddington departure 57 late at St Erth.
Re: Cornish delays
Posted by IndustryInsider at 15:12, 27th April 2024
: GBM
The days of 'spare' crew sitting around 'just in case' must have ceased years ago.
Still plenty of spares sitting around on occasions.  Depends on time of day, time of year, day of week, and the nearest depot as to how likely you might be able to get cover.
If you have short notice sickness then if there is no spare available it becomes very tricky.  You might get lucky and have someone that agrees to stay on, but that’s rare - especially with the current ongoing dispute.
Re: Cornish delays
Posted by GBM at 13:03, 27th April 2024
General question (rather than line specific).
13:52 St Erth to St Ives due 14:03
13:52 St Erth to St Ives due 14:03 will be cancelled.
This is due to the train guard being taken ill.
(Return run also cancelled).
Guess the guard was at the end of their shift as no other services affected.
Where do GWR find replacement crew if someone goes sick whilst on duty?
Re: Cornish delays
Posted by bobm at 11:19, 25th April 2024
They do indeed use the bay but also a part of the down line (in each direction) when coming on and off the branch.   Fitting four of these an hour among late running trains may be tricky.
Re: Cornish delays
Posted by GBM at 10:46, 25th April 2024
Delays to services at Truro
Due to a fault with barriers at a level crossing at Truro trains have to run at reduced speed.
Train services running through this station may be delayed by up to 25 minutes. Disruption is expected until 11:15 25/04.
Apologies to customers, owing to a fault with level crossing barriers at Truro trains have to run at a reduced speed on both lines through the area.
Then
10:15 Truro to Falmouth Docks due 10:39
10:15 Truro to Falmouth Docks due 10:39 has been cancelled.
This is due to a fault with barriers at a level crossing.
((Return service run also cancelled)).
Odd one this?
The level crossing is on the main lines and is causing 25+ minutes delay - guess they're instructed to pass at 5mph.
The branch shouldn't be affected by the crossing, as the two trains on that branch use the bay platform at the other end of the station.
Re: Cornish delays
Posted by GBM at 07:19, 23rd April 2024
Due to a points failure between Liskeard and Bodmin Parkway all lines are blocked. Disruption is expected until 07:45 23/04.
Train services between Penzance and Plymouth are returning to normal but some services may still be delayed.
Re: Cornish delays
Posted by GBM at 10:28, 17th April 2024
Problems today in Cornwall.
Pz to London delayed by a train in front with a fault.
Signalling problems causing delays and short terminations.
Track problem causing delays.
Apart from the above........
Cornish delays
Posted by GBM at 08:14, 14th March 2024
Due to a broken down train at Liskeard the line is blocked. Disruption is expected until 08:45 14/03.
2C02 0638 Plymouth to Penzance (HST)
Arrived Liskeard only 2 minutes down at 07:06, but just underway at 08:07.
2C03 0712 Plymouth to Penzance (9 car IET) sat at St Germans from 07:28 to now (08:08
Also on the up line
06:05 Penzance to London Paddington due 11:29
06:05 Penzance to London Paddington due 11:29 is being delayed between Saltash and Devonport.
This is due to the emergency services dealing with an incident.
1A76 0605 Penzance to London Paddington (9 car IET).
Held at Saltash since 07:52, with 1S43 0628 Penzance to Edinburgh behind it at St Germans.
