| Re: Problems with IET trains from April 2021 Posted by Timmer at 07:55, 23rd November 2025 | ![]() ![]() ![]() |
I thought that an IET with only one engine was able to ascend inclines, though slowly.
After all, the electric version has only one engine, and can allegedly "limp home" on diesel power.
Regarding the ex 17.03: It did “limp home” but without any passengers. On how many engines I know not and if it even made it to Laira as RTT only shows times to Lipsom Junction. After all, the electric version has only one engine, and can allegedly "limp home" on diesel power.
https://www.realtimetrains.co.uk/service/gb-nr:31792/2025-11-22/detailed
The 18.03 terminated at Taunton with RTT reporting thst this was due to a problem with doors. This service was restarted at Exeter through to Penzance using the train that formed the 16.35 Paddington to Paignton service which terminated at Exeter.
| Re: Problems with IET trains from April 2021 Posted by grahame at 07:52, 23rd November 2025 | ![]() ![]() ![]() |
Question comes - do you WANT it to "limp home" or cut your losses and send it to the nearest depot? We have had reports here on occasions in the past of trains / locomotives taking an age and a half getting back from where they are in a crock siding (Castle Cary, Taunton in memory) to somewhere they can be fixed, much to the disruption of other services. I suspect you would not want "Limping Lulu"s filled with irate, delayed passengers trolling along through Devon with a string of other fitter IETs and Voyagers crawling teach signal behind amid also filled with delayed passengers.
| Re: Problems with IET trains from April 2021 Posted by broadgage at 23:26, 22nd November 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by Timmer at 19:23, 22nd November 2025 | ![]() ![]() ![]() |
Not good for those travelling down to Devon and Cornwall this evening with both the 17.03 and 18.03 Paddington to Penzance terminating well short of their final destination at Exeter and Taunton respectively. ‘Train fault’ reason given, one is losing time and probably wouldn’t make it up the south Devon banks.
| Re: Problems with IET trains from April 2021 Posted by plymothian at 08:53, 22nd November 2025 | ![]() ![]() ![]() |
Here's a very interesting, and frankly ludicrous and potentially dangerous development.
An IET ran out of fuel at Lipson Junction this week as it was running with isolated GUs, meaning the other available engines eventually shut down due to fuel starvation. Having no running GUs meant the train eventually shut down all services as the batteries ran out - lighting, toilets, PA, GSM-R, TMS etc.
Luckily, as it was near Laira depot, a rescue train could be sent out to tow it to Plymouth, but even still, this took 3 hours!
1C98 2104 London Paddington to Plymouth
https://www.realtimetrains.co.uk/service/gb-nr:P08345/2025-11-19/detailed#allox_id=0
| Re: Problems with IET trains from April 2021 Posted by GBM at 10:16, 19th November 2025 | ![]() ![]() ![]() |
Two 5 cars out today
07:10 Penzance to London Paddington due 12:29
Facilities on the 07:10 Penzance to London Paddington due 12:29.
Will be formed of 5 coaches instead of 10.
And
08:35 Plymouth to London Paddington due 12:05
08:35 Plymouth to London Paddington due 12:05 will no longer call at Newbury.
This is due to overcrowding as this train has fewer coaches than normal.
| Re: Problems with IET trains from April 2021 Posted by GBM at 07:28, 18th November 2025 | ![]() ![]() ![]() |
05:03 Penzance to London Paddington due 09:54
Facilities on the 05:03 Penzance to London Paddington due 09:54.
Another 5 car unit all the way to Paddington.
Very cozy
| Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 11:02, 17th November 2025 | ![]() ![]() ![]() |
..........and this'll be cosy too, especially as it's Friday.
18:36 London Paddington to Plymouth due 22:10
Facilities on the 18:36 London Paddington to Plymouth due 22:10.
Will be formed of 5 coaches instead of 9. There are no reservations on this service.
Correctly formed in the end...as usually seems to happen when there is so much notice given of an alteration to WoE services.
| Re: Problems with IET trains from April 2021 Posted by TaplowGreen at 08:31, 14th November 2025 | ![]() ![]() ![]() |
Will be formed of 5 coaches instead of 10. There are no reservations on this service.
5 all the way to Paddington (again).
| Re: Problems with IET trains from April 2021 Posted by GBM at 08:22, 14th November 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 07:49, 14th November 2025 | ![]() ![]() ![]() |
And the time of year with drivers driving defensively…though the IET fleet is easily the best at dealing with slippery conditions of the types of train I have driven over the years.
| Re: Problems with IET trains from April 2021 Posted by a-driver at 17:53, 13th November 2025 | ![]() ![]() ![]() |
Across the whole entire GWR IET fleet, there’s approximately 100 engines isolated. If they’re rectifying 3 a day, that’ll be over a months worth of worth excluding new failures. Add to that, the countless speed restrictions in place because of track defects and the picture is grim.
| Re: Problems with IET trains from April 2021 Posted by Witham Bobby at 09:46, 13th November 2025 | ![]() ![]() ![]() |
The Oxford Clarion has the reason for the awful performance on the North Cotswold....
A widespread engine fault on GWR’s fleet of intercity trains is causing overcrowding, late running and cancellations on London–Oxford services, and onwards into the Cotswolds. Fuel pumps are said to be “disintegrating”, leading to trains running slow with several engines out of service.
Over the last four weeks, only 60% of Oxford–Paddington services have run to time (or within 5 minutes). Some services have been particularly unpunctual: the 2035 from Oxford has been on time for just 15% of its scheduled runs, with the 1331 little better at 25%.
The engine failures mean that services booked for 9-coach trains are often run with just 5, with passengers being left on the platform at Oxford on occasion. A 9-coach train has 5 engines: GWR withdraws them from service if 3 of the 5 have failed.
From 800301 on RailUKforums:
Pretty much whole fleet replacement of fuel pumps and a full fuel system clean, they are getting about 3 done a day, it requires the whole Generator unit to be dropped from the train for the work to be done, they are getting more back into service but the work can only be done at certain locations.
They haven’t yet determined the cause but it’s being looked into, quite a few 9 car sets are running around on 3 out of 5 engines, if running on 2 it’s likely they will be pulled from service, where rail adhesion has been quite bad yesterday and today they have also been receiving Not to Call orders at certain stations or being held in other places so they are guaranteed a clear run up inclines to avoid getting stranded.
Hopefully it will be sorted soon
Edited to clarify quotes
| Re: Problems with IET trains from April 2021 Posted by ChrisB at 20:29, 12th November 2025 | ![]() ![]() ![]() |
Update on the units that have had crack repairs completed, and those still to do - courtesy of Richard Clinnick, on his socials recently -
800306 left Eastleigh today (Nov 6th), leaving classmate 800309 as the only set there.
...there have been 10x5-car 800/0s, 5x9-car 800/3s, 17x5-car 802/0 and 8x9-car 802/1s from the
@gwr
fleet treated, leaving 26 800/0s, 16 800/3s, 5 802/0s and 6 802/1s to go. Interestingly, maybe, more Eversholt-owned sets than Agilty sets have been for repairs...
@gwr
| Re: Problems with IET trains from April 2021 Posted by ChrisB at 19:13, 12th November 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by Wizard at 09:14, 7th September 2025 | ![]() ![]() ![]() |
And how many years is it since my now famous crystal ball predicted that the new trains "would in practice be mainly 5 car units"
Such views were widely criticised as being unduly negative.
To say they are ‘mainly five car units’ isn’t really correct. The odd service runs with five when it should be more but the majority of trains leaving London have nine or ten coaches, as planned.
| Re: Problems with IET trains from April 2021 Posted by grahame at 21:55, 6th September 2025 | ![]() ![]() ![]() |
Things may be getting better though.
The 18:00 Temple Meads to Paddington was just a five car, but by 19:00 the Temple Meads to Paddington was up to 9 cars, and the train arriving into Temple Meads fromn London was ten.
| Re: Problems with IET trains from April 2021 Posted by broadgage at 16:56, 6th September 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by Clan Line at 13:47, 6th September 2025 | ![]() ![]() ![]() |
They should have kept the HSTs ! not forever of course, but until the wretched IETs could work reliably enough to provide a full service.
Not sure if your statement could grammatically be classified as an oxymoron...............but it certainly seems to contradict itself. Will the IETs EVER provide a full, reliable service ?
They already seemed to be suffering from premature problems of old-age, long before the initial into service problems have been resolved.I recently spent several hours between Bath and Maindee Jct (mostly at BRI) and did notice, at the time, that the vast majority of IETs we saw/passed were only 5 car units. The only 9 car I can definitely remember seeing was outside WSB, heading towards BRI............as ECS !
| Re: Problems with IET trains from April 2021 Posted by broadgage at 05:00, 6th September 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by eightonedee at 22:28, 5th September 2025 | ![]() ![]() ![]() |
Have the Tanat Valley still got those Pacers to sell
? | Re: Problems with IET trains from April 2021 Posted by didcotdean at 20:59, 5th September 2025 | ![]() ![]() ![]() |
There has been a varying dog's dinner from day to day of allocations on diagrams this week, no doubt to utilise what is available.. As well as short-forming and cancellations there has also been long-forming of 10 vice 9 and 9 vice 5. Only the last is a real pleasant surprise.
| Re: Problems with IET trains from April 2021 Posted by broadgage at 20:02, 5th September 2025 | ![]() ![]() ![]() |
Has there EVER been a week when IETs have not been short formed due to faults ?
| Re: Problems with IET trains from April 2021 Posted by grahame at 10:06, 5th September 2025 | ![]() ![]() ![]() |
The Intercity Express Train (IET) fleet is currently experiencing a reduction in available units due to an increase in GU (Generator Unit) faults, which are under investigation by Hitachi. As a result, there will be a rise in short-formed and cancelled services while Hitachi develops an engineering solution. In the event of an incident this will impact service recovery due to the need to keep traction on certain diagrams.
Could this explain 3 x 165 on a Bristol (Temple Meads) to Reading train recently?
| Re: Problems with IET trains from April 2021 Posted by PhilWakely at 10:00, 5th September 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by ChrisB at 16:13, 24th August 2025 | ![]() ![]() ![]() |
Wonder how long it'll be before this 'problem' in RTT is raised again?
| Re: Problems with IET trains from April 2021 Posted by BBM at 10:02, 24th August 2025 | ![]() ![]() ![]() |
A nice problem to have -
1A84 1020 Penzance to London Paddington
Left Penzance as 5 cars.
9 added at Plymouth!
Showing 14 cars to London!
This is a well-known issue on RTT, there's a recent thread on Rail UK Forums which explains how it happens:
https://www.railforums.co.uk/threads/22-coach-pendolino.290852/
| Re: Problems with IET trains from April 2021 Posted by GBM at 08:59, 24th August 2025 | ![]() ![]() ![]() |
08:27 Plymouth to London Paddington due 11:59
Facilities on the 08:27 Plymouth to London Paddington due 11:59.
Will be formed of 8 coaches instead of 10.
One carriage locked out of use I wonder?
It then forms the 12:30 London Paddington to Bristol Temple Meads due 14:05
16:00 Bristol Temple Meads to London Paddington due 17:37
18:00 London Paddington to Plymouth due 21:31
Finally 5C25 2202 Plymouth to Laira T.& R.S.M.D.
| Re: Problems with IET trains from April 2021 Posted by grahame at 07:25, 24th August 2025 | ![]() ![]() ![]() |
Totally confused on this one,did 14 coaches actually make the journey from the west of England to Paddington?
If it did how was the train accommodated at Paddington?
I would be surprised if 14 carriages made Paddington. Maximum platformed is 12 IET carriages (but how would you do that?) in Platform 1, but a long lead out past the old parcels / mail platform without points might provide an exceptional ability to handle more?
From the sectional appendix PDF - here:
If that "26 chains" on the left is the distance to the first point, then physically 20 carriages of 26 metres could just fit in there.
| Re: Problems with IET trains from April 2021 Posted by infoman at 03:35, 24th August 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by stuving at 23:37, 22nd August 2025 | ![]() ![]() ![]() |
Reminded me of the 23-car lash up through Tonbridge
https://www.youtube.com/watch?v=jta4c9FMmCA
Is there a theoretical maximum of IETs that can be coupled together?
:https://www.youtube.com/watch?v=jta4c9FMmCA
Yes, as specified for passenger operation it's two units and 312 m - twelve vehicles. Given the unit lengths in existence that means only trains that actually operate now.
For ECS and rescue modes, twice that is allowed. That means any train operating now can rescue any other, but it does not have to haul anything longer than it is. Thus some theoretical possibilities such as 5+5+5+9 might be allowed as ECS, but not for rescue (i.e. with passengers on board the rescued train).
| Re: Problems with IET trains from April 2021 Posted by Fourbee at 20:21, 22nd August 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by ChrisB at 12:30, 22nd August 2025 | ![]() ![]() ![]() |
Carting those 9 out of use I think
| Re: Problems with IET trains from April 2021 Posted by GBM at 12:27, 22nd August 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by Witham Bobby at 12:25, 22nd August 2025 | ![]() ![]() ![]() |
Sooo, first gen DMU heating... how'd it work?
If you want to know more, the Railcar Society website has a useful WR guide to DMU heaters:
https://www.railcar.co.uk/documentation/
Scroll down the page a little to find it
A manual for the Smiths heaters can be found by scrolling a little further
Now I'm down a rabbit hole:
https://preserved.railcar.co.uk/documentation/tsu-89-99-heaters.pdf
[Edit: to add information]
| Re: Problems with IET trains from April 2021 Posted by Witham Bobby at 12:16, 22nd August 2025 | ![]() ![]() ![]() |
AI generated answer:
First generation diesel multiple units (DMUs) on British Railways were primarily fitted from new with Smiths combustion heaters, although a few were initially equipped with a similar type manufactured by Dragonair, which were later replaced by the Smiths version due to recurring problems.
These heaters operated by burning fuel to generate heat, with the fan end of the heater being colour coded to indicate the unit's heat output; the warmer 50,000 BTU units, differing only in their fuel pumps, were typically fitted to vehicles carrying a single heater, such as Class 108s.
Vehicles with two heaters generally required one of each hand, as the glow plug needed to be positioned on the side facing outwards for ease of access.
The heaters were controlled through a system that included a flame detection thermostat and were integrated into the vehicle's control system.
In 1977, British Rail determined that electrical faults and heater reliability could be improved by electrically insulating the heaters from the vehicle body, achieved by using rubber pads on mounting straps, rubber tubing in the fuel pipe, and insulating bushes made of GRP at both ends of the heater to prevent metal-to-metal contact.
AI-generated answer. Please verify critical facts.
It's AI generated, but corresponds well with my recollection of the heaters on the Park Royal sets we had on the WSR in the mid/late 1970s
| Re: Problems with IET trains from April 2021 Posted by Mark A at 12:08, 22nd August 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by Witham Bobby at 09:36, 22nd August 2025 | ![]() ![]() ![]() |
A fault on the train, but it can run through to Paddington empty?
Door fault? Aircon intake fault - filling passenger cabin with diesel exhaust?
Oh, happy memories of first generation DMU heating!
That kerosene and sulphur smell that took your breath away!
| Re: Problems with IET trains from April 2021 Posted by Ralph Ayres at 09:20, 22nd August 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by grahame at 13:45, 21st August 2025 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by GBM at 13:41, 21st August 2025 | ![]() ![]() ![]() |
Eh?
12:15 Penzance to London Paddington due 17:31
12:15 Penzance to London Paddington due 17:31 has been cancelled.
Customers making journeys within Devon and Somerset can travel with Cross Country's Edinburgh service as far as Taunton, which departs Plymouth at 14:27.
RTT at Penzance shows -
1A88 1215 Penzance to London Paddington This service is cancelled.
This service was cancelled due to a problem with the traction equipment (MD).
AND
5A88 1215 Penzance to London Paddington
Empty Coaching Stock
| Re: Problems with IET trains from April 2021 Posted by ChrisB at 19:52, 23rd April 2025 | ![]() ![]() ![]() |
Another update from Richard Clinnick. This has been going on so long that he's now on his 3rd job since the start, and is now editor, Modern Railways...
So far treated - 7 5car 800/0s, 3 9car 800/3s, 12 5car 802/0s and 6 802/1s
800013 & 802017 currently at Eastleigh
In total, there are 93 IETs, 57 owned by Agility. Of those, 28 5car 800/0s and 18 9car 800/3s still need to be treated That leaves 36 IETs owned by Eversholt of which 9 5car 802/0s and 7 9car 802/1s have yet to be treated
[if these figures don't add up, they're Richard's not mine!]
| Re: Problems with IET trains from April 2021 Posted by ChrisB at 20:34, 6th March 2025 | ![]() ![]() ![]() |
Richard Clinnick (editor, Modern Railways) tweeted a fleet update on GWRs IETs with the cracking problem still ongoing....
Just 38 IETs from the fleets of GWR and LNER have been through Eastleigh works for repairs so far. 800110 has been through twice! Currently there are 800013, 800110 & 802102.
Still to go from GWR -
800002-012/014-016/019-021/023/025/027/029-036/301-302/304-308/311-321
802004-006/009/013/014/017/018/020/022/101/103-106/109/110/112/113
plus another 33 sets from LNER.
So many years yet.....
| Re: Problems with IET trains from April 2021 Posted by grahame at 14:14, 6th March 2025 | ![]() ![]() ![]() |
Debate cars vs coaches! (I seem to remember we did have that debate a while ago).
https://www.firstgreatwestern.info/coffeeshop/index.php?topic=27903 - and we included "carriages" but not "vehicles".
| Re: Problems with IET trains from April 2021 Posted by GBM at 13:17, 6th March 2025 | ![]() ![]() ![]() |
I've noticed 'recently/a while ago' that there were a few 5 car units doing the rounds(more trains than usual, etc).
However, it is now more common to see 5 cars from Penzance to Paddington with no additional cars at Plymouth.
It is easy to say West Country services must be 9 or 10 cars at all times, but that means perhaps Bristol/Wales/Hereford lose out.
Whilst Hitachi might well be working quietly behind the scenes, I'm surprised that the 5 car issues have not been sorted at all.
The IET's are 5 car/coaches units, or a 9 car/coach formation anyway.
| Re: Problems with IET trains from April 2021 Posted by bradshaw at 08:09, 6th June 2024 | ![]() ![]() ![]() |
The Paignton service has been reinstated starting from Taunton, using a 3 car unit, according to Journey Check.
Running as 3C70 ecs from Bristol according to Traksy
| Re: Problems with IET trains from April 2021 Posted by Timmer at 07:11, 6th June 2024 | ![]() ![]() ![]() |
08:03 London Paddington to Penzance due 13:07
08:03 London Paddington to Penzance due 13:07 will call additionally at Castle Cary.
Just wondering why a problem will give an additional station stop?
I've seen it on other trips since IET's started.
I would say likely to do with the 07:03 being cancelled:08:03 London Paddington to Penzance due 13:07 will call additionally at Castle Cary.
07:03 London Paddington to Paignton due 10:16 will be cancelled.
| Re: Problems with IET trains from April 2021 Posted by GBM at 07:06, 6th June 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 19:42, 26th February 2024 | ![]() ![]() ![]() |
At least you refrained from suggesting steam engine haulage on this particular occasion I suppose.
| Re: Problems with IET trains from April 2021 Posted by broadgage at 16:05, 26th February 2024 | ![]() ![]() ![]() |
Thank you for the explanation
Yes I agree with you on Broadgauge's piece of false propaganda.
Yes I agree with you on Broadgauge's piece of false propaganda. I simply suggested possible sources of alternative rolling stock IF significant numbers of IETs are withdrawn. I see no propaganda in such a post.
| Re: Problems with IET trains from April 2021 Posted by GWR 158 at 15:38, 26th February 2024 | ![]() ![]() ![]() |
Thanks for the information, it will be interesting to hear of any plans
| Re: Problems with IET trains from April 2021 Posted by grahame at 15:18, 26th February 2024 | ![]() ![]() ![]() |
Oh now, now folks
I do know of some rolling stock plans - but in them the IETs are very much here to stay. And there's an update briefing later this week that I'll be attending and I will report back if there's different news.
| Re: Problems with IET trains from April 2021 Posted by GWR 158 at 14:54, 26th February 2024 | ![]() ![]() ![]() |
Yes I agree with you on Broadgauge's piece of false propaganda. | Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 14:52, 26th February 2024 | ![]() ![]() ![]() |
All i wanted was further information, there is no need to be rude.
I was replying to Broadgage who had made the previous post, and, unfortunately, had rather hijacked your original question with his own unique brand of propaganda.
| Re: Problems with IET trains from April 2021 Posted by GWR 158 at 14:45, 26th February 2024 | ![]() ![]() ![]() |
Sounds like a great idea to me. Perhaps it will allow GWR to operate that service to Fantasy Island at long last so we can come visit you.
| Re: Problems with IET trains from April 2021 Posted by GWR 158 at 14:43, 26th February 2024 | ![]() ![]() ![]() |
Then again this is just a rumour isn’t it.
Indeed. Perhaps GWR 158 can tell us from where he heard the rumour?
I certainly can, I heard it from a friend. I highly doubted this would be true anyway, I just wanted further information to see whether anyone has heard anything similar.
| Re: Problems with IET trains from April 2021 Posted by TonyK at 13:13, 26th February 2024 | ![]() ![]() ![]() |
Hi all,
I heard a rumour recently that suggested GWR are planning to withdraw IET sets permanently due to rusting/corroding bolts. Does anybody have more information on this? Or is it untrue
I've had a look at RTT for my local station (Tiverton Parkway) and only four of the GWR trains stopping or passing through today are not 80x types. 3 are 158s doing positional stuff I suppose. The other outlier is the only loco hauled service of the day, the sleeper, which was part-cancelled and began at Reading instead of Paddington. That would be a lot to replace. Given that they are largely running to time, I very much doubt that will happen.
| Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 12:41, 26th February 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by REVUpminster at 12:09, 26th February 2024 | ![]() ![]() ![]() |
They are never going to get rid of the 800s. With all the variants there are 262 sets from the 395 Javelin to Aurora 810s
| Re: Problems with IET trains from April 2021 Posted by 1st fan at 11:40, 26th February 2024 | ![]() ![]() ![]() |
Surely Hitachi are on the hook for these trains and a failure to provide sufficient sets a day costs them a few quid. I know they’re not responsible for the ‘lovely’ carriage interiors but you would think they’d make sure the exteriors were fine and mechanically sound.
| Re: Problems with IET trains from April 2021 Posted by nickswift99 at 09:24, 26th February 2024 | ![]() ![]() ![]() |
Where are the replacement 93 trainsets coming from?
(other than the Strategic Reserve in Box Tunnel, obviously)
I think I have now realised why Network Rail have not remedied the persistent issues with flooding in various parts of the network. I contend that they are covert water troughs designed to support the Strategic Reserve.
| Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 09:11, 26th February 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by broadgage at 23:26, 25th February 2024 | ![]() ![]() ![]() |
Hopefully not every unit will need immediate withdrawal, some might be be allowed to run for months yet.
Some spare stock s available, the ex-TPE stock has already been suggested, and there are still some surviving HSTs stored. mainline passed stock from heritage lines is another possibility. Not adequate but a lot better than nothing.
Building loco hauled coaches is well understood and relatively quick.
The special bi-mode locomotives/power cars would take longer, but in the short term existing diesel locos would be better than nothing.
| Re: Problems with IET trains from April 2021 Posted by Richard Fairhurst at 21:04, 25th February 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by broadgage at 13:36, 25th February 2024 | ![]() ![]() ![]() |
Build some more HSTs !
Not of course an exact copy of a near 50 year old design, but something similar in design.
A BIMODE power car or locomotive at each end, no more underfloorbus gin palace engines.
Total train length similar to a 5+5 car IET.
Buffet car, padded seats, tables, luggage space etc.
I had a vague, yet somehow certain feeling that one would come along!
And what exactly is wrong with calling for proper trains to replace IETs ? With the features listed above, and also fixed formation. No flexible train length as flexible means shorter.
Before the wretched things were even introduced it was clear that they represented a backward step in comfort and facilities They have now been in service for some years and poor build quality and unreliability are major problems.
| Re: Problems with IET trains from April 2021 Posted by TaplowGreen at 20:36, 24th February 2024 | ![]() ![]() ![]() |
Not of course an exact copy of a near 50 year od design, but something simiar in design.
| Re: Problems with IET trains from April 2021 Posted by broadgage at 19:24, 24th February 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by a-driver at 19:01, 24th February 2024 | ![]() ![]() ![]() |
There’s loads of rumours surrounding IETs!
Most, if not all, concern their withdrawal. We can only hope one, just one, turns out to be true.
| Re: Problems with IET trains from April 2021 Posted by GWR 158 at 17:45, 24th February 2024 | ![]() ![]() ![]() |
No it didn't thankfully
| Re: Problems with IET trains from April 2021 Posted by TaplowGreen at 17:10, 24th February 2024 | ![]() ![]() ![]() |
Hi all,
.............rumour didn't come from a certain Port quaffing member of this esteemed forum by any chance?
| Re: Problems with IET trains from April 2021 Posted by GWR 158 at 15:10, 24th February 2024 | ![]() ![]() ![]() |
Hi all,
| Re: Problems with IET trains from April 2021 Posted by chuffed at 09:57, 5th February 2024 | ![]() ![]() ![]() |
In the early days of the project, many promises were made about the quality and reliability of these new trains.
In the early days of the project, many promises were made about the quality and reliability of these new ..............roads/hospitals/libraries/sports centres/airports/aircraft carriers/armoured cars/mail deliveries/bank availabilities/flood prevention schemes/electric cars/supermarket cashiers/Boeing 737s/etc/etc................this could be a whole new thread in itself for an election year
| Re: Problems with IET trains from April 2021 Posted by broadgage at 06:05, 4th February 2024 | ![]() ![]() ![]() |
Suggest merging this thread with the main "problems with IETs" thread.
| Re: Problems with IET trains from April 2021 Posted by Clan Line at 13:09, 3rd February 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by broadgage at 12:25, 3rd February 2024 | ![]() ![]() ![]() |
Sadly as with so many things these day, IET built to a price ,not to a standard.
I thought that the price was relatively high, one criticism of the project was the substantial cost of the trains. IET=Incredibly Expensive Trains ! According to some critics.
| Re: Problems with IET trains from April 2021 Posted by TaplowGreen at 08:50, 3rd February 2024 | ![]() ![]() ![]() |
We need something more robust, successful and enduring - like the APT perhaps?
| Re: Problems with IET trains from April 2021 Posted by Western Pathfinder at 08:43, 3rd February 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by broadgage at 07:28, 3rd February 2024 | ![]() ![]() ![]() |
Regarding the LNER twitter thread, someone's remarked that water ingress at the windows is causing issues as it's able to travel to where it can cause galvanic corrosion. LNER's trains run in a somewhat salt-rich environment, and GWR's even more so, and this cannot help either.
Ah, but don't forget, both Hitachi and GWR have assured us that their IETs are 'Dawlish proof'
But only if not allowed to run in the worst conditions, an IET confined to the depot should survive Dawlish just fine.
| Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 19:07, 2nd February 2024 | ![]() ![]() ![]() |
Whatever happens it’s down to Hitachi to sort out as part of the maintenance contract.
Just like they are quietly doing with the cracks issue that people were getting excited about.
| Re: Problems with IET trains from April 2021 Posted by FarWestJohn at 18:40, 2nd February 2024 | ![]() ![]() ![]() |
And that is just the parts you can see!!
| Re: Problems with IET trains from April 2021 Posted by PhilWakely at 17:21, 2nd February 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by bobm at 16:17, 2nd February 2024 | ![]() ![]() ![]() |
It will be that salt ridden sea air on the Northumberland coast.....
| Re: Problems with IET trains from April 2021 Posted by broadgage at 16:15, 2nd February 2024 | ![]() ![]() ![]() |
Aluminium is very vulnerable to corrosion especially if in contact with steel.
Did someone use steel fixings at the factory?, or subsequently during maintenance, either is a rather basic error.
Even different grades of aluminium alloy are liable to corrosion if used in contact with each other.
Electrical leakage currents through aluminium structures can also accelerate corrosion. DC is worst.
| Re: Problems with IET trains from April 2021 Posted by Mark A at 14:46, 2nd February 2024 | ![]() ![]() ![]() |
There's a Twitter thread running on the subject of visible corrosion involving LNER's IEPs, which put me in mind of a photo from December (hopefully visible below) showing either a failure in the surface coating or corrosion around a GWR IEP window. It's reasonable to wonder if these trains are going to have 'A problem'.
| Re: Problems with IET trains from April 2021 Posted by BBM at 13:47, 2nd February 2024 | ![]() ![]() ![]() |
Industry expert Gareth Dennis has posted on X some quite alarming photos of corrosion on LNER Azumas:
https://twitter.com/GarethDennis/status/1753413827067097297
| Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 11:18, 29th January 2024 | ![]() ![]() ![]() |
According to this, Unite accepted the pay offer:-
https://www.cityam.com/400-rmt-workers-at-hitachi-to-strike-on-saturday-until-1-february/
Thanks for that. Might explain the confusion.
| Re: Problems with IET trains from April 2021 Posted by broadgage at 10:40, 29th January 2024 | ![]() ![]() ![]() |
Stickers have finally started appearing on the trolley/urn store in the middle of the IETs. Passengers have been confusing them for toilets since they were introduced!
How many crew can you get in a crew storage area ? what type of crew are stored there? how long can they be stored for? and has this been agreed with the Unions?
Two full sized crew, or three small ones.
Catering crew, mainly, possibly hitachi fitters
Two hours at a time, without being let out for exercise.
Strike bruvvers !
| Re: Problems with IET trains from April 2021 Posted by ray951 at 08:39, 29th January 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by Southernman at 23:55, 28th January 2024 | ![]() ![]() ![]() |
A Hitachi Rail spokesperson said: “We are disappointed at RMT’s decision to carry out industrial action.
“We believe the combination of last year’s pay increase, and this year’s pay proposal, is fair and highly competitive in the current economic environment. As demonstrated by Unite members accepting the same offer this week and ending their planned industrial action.
| Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 22:37, 28th January 2024 | ![]() ![]() ![]() |
That dispute is only in Hitachi LNER depots, not GWR.
Not according to the official press release from UNITE:
https://www.unitetheunion.org/news-events/news/2024/january/national-strike-by-hitachi-rail-workers-over-pay
| Re: Problems with IET trains from April 2021 Posted by grahame at 21:22, 28th January 2024 | ![]() ![]() ![]() |
The short forms are all down to the withdrawal of the Castle sets & IETs▸ being transferred westwards to cover.
Also covering the shortage of other DMUs. Last Wednesday one of the Bristol-Worcester workings was being covered by a 5 car IET.
There are 17 class 153 in store. One wonders if too early - I know the need for disabled loos these days but really wonder if 2 x 158 trains could run as 1 x 158 + 2 x 153. Of course, whilst one wonders, one expects there's a very good reason why castles and 153s (and the 6 stored 156s) could be be used.
| Re: Problems with IET trains from April 2021 Posted by ChrisB at 21:18, 28th January 2024 | ![]() ![]() ![]() |
yes, indeed.
| Re: Problems with IET trains from April 2021 Posted by TonyN at 20:52, 28th January 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by ChrisB at 20:35, 28th January 2024 | ![]() ![]() ![]() |
Another poor customer experience for those aboard the 1635 Paddington to Plymouth 5 vice 10 and absolutely rammed according to my wife who’s on the train. First declassified. Not listed on JC as being short formed.
Could well be linked to the Hitachi maintenance staff industrial action which started yesterday and runs until Friday.
The short forms are all down to the withdrawal of the Castle sets & IETs being transferred westwards to cover.
| Re: Problems with IET trains from April 2021 Posted by Timmer at 17:26, 28th January 2024 | ![]() ![]() ![]() |
I expect you will be told to be grateful they managed to find 5!
Or that it even ran at all. Next Sunday it won’t be.| Re: Problems with IET trains from April 2021 Posted by Timmer at 17:24, 28th January 2024 | ![]() ![]() ![]() |
Journey check has now been updated to include the 1635:
16:35 London Paddington to Plymouth due 20:04
Facilities on the 16:35 London Paddington to Plymouth due 20:04.
Will be formed of 5 coaches instead of 9. Service full and standing from Reading.
I can assure the person writing this that the train was full and standing when it left Paddington.Facilities on the 16:35 London Paddington to Plymouth due 20:04.
| Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 17:21, 28th January 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by TaplowGreen at 16:56, 28th January 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by IndustryInsider at 16:53, 28th January 2024 | ![]() ![]() ![]() |
| Re: Problems with IET trains from April 2021 Posted by Timmer at 16:39, 28th January 2024 | ![]() ![]() ![]() |
