| Re: Newquay Line - services, incidents and improvements (merged posts) Posted by TaplowGreen at 11:39, 17th August 2026 | ![]() ![]() ![]() |
Cancellations to services between Par and Newquay
Due to a fault on this train between Par and Newquay fewer train
s are able to run on the line.
Train services running to and from these stations may be cancelled. Disruption is expected until the end of the day.
A general shortage of trains in Cornwall has resulted in a reduced service on the Par to Newquay line today.
As a result the service is running roughly every two hours, as opposed to the planned hourly operation.
On the hours where there is no train service, a limited taxi service is running, which GWR customers can use at no extra cost. These will depart Par at the time the train would have done.
We apologise for the inconvenience today.
| Re: Newquay Line - services, incidents and improvements (merged posts) Posted by REVUpminster at 09:11, 17th August 2026 | ![]() ![]() ![]() |
175003 is doing 2C05 and 006 the training run and that seems to be it.
2 Paignton trains and 1 Barnstaple (busy train) short-formed and 3 150s released doing 175 diagrams.
| Re: Newquay Line - services, incidents and improvements (merged posts) Posted by TaplowGreen at 07:37, 17th August 2026 | ![]() ![]() ![]() |
It's a pity a few more of his trains aren't on the line.
| Re: Newquay Line - services, incidents and improvements (merged posts) Posted by REVUpminster at 07:26, 17th August 2026 | ![]() ![]() ![]() |
One of the problems you have as a train operator is that when you raise the level of s service and then something goes wrong, you have further to fall.
How many class 175 units running in passenger service at the moment? A data feed / report from Cornwall the other day says "175003 was the only member of the class in service on Sat 15th." and that's out of - what - over 20 units?
175003 was the only one out at the weekend doing Newquay but seemed to fail yesterday with a train crew issue. Air conditioning? something else?07:07 Par to Newquay due 07:58
08:22 Newquay to Par due 09:10
09:16 Par to Newquay due 09:59
10:28 Newquay to Par due 11:11
11:21 Par to Newquay due 12:09
12:17 Newquay to Par due 13:00
13:16 Par to Newquay due 14:03
14:27 Newquay to Par due 15:11
15:15 Par to Newquay due 16:13
16:18 Newquay to Par due 17:01
17:17 Par to Newquay due 18:05
18:22 Newquay to Par due 19:10
19:16 Par to Newquay due 19:59
20:28 Newquay to Par due 21:17
20:28 Newquay to Par due 21:17 will be cancelled.
003 has been one of the more successful units.
GWR has 16 units, some for nearly two years and I don't know to what degree the 16 trains have been cannibalised to get the four or five trains currently running.
Something must come out of Wolverton this week; it would be the fourth attempt since 23 June! Mark Hopgood said in the Radio Cornwall interview, the next trains from Wolverton will be ready to roll. There are nine at Wolverton. If they are ready to roll it would make a big dent in availability. His credibility is on the line.
| Re: Newquay Line - services, incidents and improvements (merged posts) Posted by grahame at 06:13, 17th August 2026 | ![]() ![]() ![]() |
| Re: Newquay Line - services, incidents and improvements (merged posts) Posted by GBM at 14:16, 24th February 2026 | ![]() ![]() ![]() |
DISRUPTION TUESDAY 24 FEB 2026
175002 seems to have sat down at Goonbarrow Junction since 1200 - then showing a 43 minute late running
https://www.realtimetrains.co.uk/service/gb-nr:V89020/2026-02-24/detailed#allox_id=2
A check on RTT shows nothing at either Par, St Blazey or Newquay that would cause "congestion"
Due to congestion between Par and Newquay the line is blocked.
Train services running to and from these stations may be cancelled. Disruption is expected until 15:00 24/02.
Due to congestion on the line between Par and Newquay the return service at 12:16 from Par will not operate as well as the return at 13:24.
5Z21 0622 Plymouth to NewquayTrain services running to and from these stations may be cancelled. Disruption is expected until 15:00 24/02.
| Re: Newquay Line - services, incidents and improvements (merged posts) Posted by Witham Bobby at 11:41, 24th February 2026 | ![]() ![]() ![]() |
| Re: Newquay Line - services, incidents and improvements (merged posts) Posted by Chris from Nailsea at 21:35, 1st February 2026 | ![]() ![]() ![]() |
Not specific to the railways, but it does show how bad the weather conditions can be, down in Newquay, and their effect on the structure of the coast - from the BBC:
Walker escaped cliff collapse 'by seconds'
A man has told how he and four others escaped a cliff collapse on the Newquay coast after a huge section of cliff crashed down in front of them without warning.
Kieron English, 20, had been exploring the area with his friend Rian Walker on Saturday afternoon when the path suddenly vanished.
The pair, three other walkers and two dogs were stuck "with no way of getting out" and were rescued by a lifeboat crew. "A couple of seconds before and we could have all lost our lives," said English.
English, who has lived in the seaside town for only three months, said he had asked his brother, who used to live there, for ideas on places with good sea views and his brother suggested trying a spot near the Fly Cellars. English said they heard a noise "like a high pitched squeal".
"Next thing we know, the whole cliff collapsed in front of us," he said.
Three separate groups ended up stranded together on a concrete pad with no safe way out. The tide was too high to attempt swimming and the cliff was too unstable to climb. English said: "A couple of seconds before and we could have lost all our lives."
Coastguards said the section of coastpath was impassable and "the public are requested to avoid the area for the time being".
It comes as recent yellow weather warnings and two named storms battered the South West earlier this week and caused disruption.
A yellow rain warning is also in place from 12:00 on Monday to 09:00 on Tuesday.
| Re: Newquay trains cancelled because of flooding Posted by Chris from Nailsea at 19:22, 25th January 2026 | ![]() ![]() ![]() |
Perhaps you could do a quick dive down there, to have a look around for us?
| Re: Newquay trains cancelled because of flooding Posted by bradshaw at 19:15, 25th January 2026 | ![]() ![]() ![]() |
Is this another example of a river scour? There is a bridge just to the south east of Roche station.
| Re: Newquay trains cancelled because of flooding Posted by grahame at 18:26, 25th January 2026 | ![]() ![]() ![]() |
Due to flooding between Par and Newquay:
Train services running to and from these stations have been cancelled. Disruption is expected until the end of the day.
Due to flooding in the Roche area, the line is currently closed.
We are working with Network Rail to be able to return to running our normal timetable as soon as possible, however this will now not be until Tuesday 27th January at the earliest. Road transport will operate in lieu of the train service for the remainder of the day, and has also been confirmed for Monday 26th January.
| Newquay trains cancelled because of flooding Posted by Witham Bobby at 13:08, 9th December 2025 | ![]() ![]() ![]() |
12:16 Par to Newquay due 13:04 will be cancelled.
This is due to flooding.
Last Updated:09/12/2025 09:31
etc
| Newquay train, St Blazey photo Posted by Mark A at 14:39, 3rd January 2025 | ![]() ![]() ![]() |
The link's to Facebook. The photo is from one Craig Munday. There cannot be many places where a passenger service calls at a manual signal box at the platform of a disused station in order to pick up a (virtual?) token for onward travel and the photographer was lucky enough to encounter exceptional weather conditions and lighting.
https://www.facebook.com/photo/?fbid=10162847613639769&set=gm.1361702471907741&idorvanity=384010423010289
| Re: Newquay Line - Summary of services from December 2020 Posted by Chris from Nailsea at 23:08, 30th May 2024 | ![]() ![]() ![]() |
Oh. Yet again, I've got a Melksham answer wrong.
| Re: Newquay Line - Summary of services from December 2020 Posted by grahame at 22:36, 30th May 2024 | ![]() ![]() ![]() |
Melksham. Just to 'bump' this topic, which I've only now (metaphorically) stumbled across.
No - http://new.passenger.chat/map/stationmap.php?tlc=SCT
| Re: Newquay Line - Summary of services from December 2020 Posted by Chris from Nailsea at 18:40, 30th May 2024 | ![]() ![]() ![]() |
And here from elsewhere is a "control" example of a desperate case.
| Par Newquay delays Posted by GBM at 14:06, 17th January 2024 | ![]() ![]() ![]() |
Delays to services between Par and Newquay
Following a points failure between Par and Newquay the line has now reopened.
Train services running to and from these stations are returning to normal. Disruption is expected until 15:00 17/01.
| Newquay Branch enquiry. Posted by RailCornwall at 20:17, 30th May 2023 | ![]() ![]() ![]() |
Travelled from Par to Newquay today on one of the two car services that are normal on the line, not a 5 car IET. Because of, we all know what, this was my first journey on the line since 2019 at least, probably 2018. The trip was very comfortable. One thing did surprise though, after Roche the line speed seemed faster than I seemed to remember. I am aware of new track laying, at several locations, in the intervening period since my last trip. My question is, is this 'line speed increase' the case or is it a figment of my imagination?
| Re: Landslip Newquay-Par Posted by IndustryInsider at 20:54, 28th June 2021 | ![]() ![]() ![]() |
A tree on the side of an embankment came down and left cracks in said embankment. Nothing too serious though, and after a proper examination the line has opened with a 20mph EROS.
| Landslip Newquay-Par Posted by GWR 158 at 20:15, 28th June 2021 | ![]() ![]() ![]() |
GWR Journeycheck has reported there is a landslip on the Newquay to Par line. Doesn't sound too major as only 1 train has been shown cancelled.
19:22 Newquay to Par due 20:11
19:22 Newquay to Par due 20:11 will be cancelled.
This is due to a landslip.
| Re: Newquay a place to avoid from WEDNESDAY 11 august 2021? Posted by Kernowman at 00:34, 9th May 2021 | ![]() ![]() ![]() |
From the CrossCountry Trains website:
'Our new timetable commences on Sunday 16 May. We are continuing to operate a special timetable on some routes to keep services running throughout the coronavirus pandemic.
With the continuing need to run fewer but longer trains for the foreseeable future, this year we will not be operating the summer weekend train services to and from Newquay. Or the enhanced Saturday service to and from Paignton.'
Also nowadays CrossCountry services to Penzance have been cut by around two thirds compared to pre-Covid levels.
| Re: Newquay a place to avoid from WEDNESDAY 11 august 2021? Posted by stuving at 16:04, 3rd May 2021 | ![]() ![]() ![]() |
There are some through trains in RTT from late June, not always the same ones and not on all days of the week to start with. Maybe they are still thinking aloud on a computer about them.
| Re: Newquay a place to avoid from WEDNESDAY 11 august 2021? Posted by grahame at 15:54, 3rd May 2021 | ![]() ![]() ![]() |
London to Newquay directs not showing in the new timetable
https://www.gwr.com/~/media/gwr/pdfs/plan-journey/timetables/2021/may/k3-0521.pdf?la=en
Perhaps they will extend a Plymouth service for a few days to cover it?
If not - well I guess people will just go by road instead.
It looks very curious in the timetable (above) though - with two summer services each way running non-stop between Par and Newquay where the services after mid September call at all stations. And one of them (at least) does not offer a London connection at Par - a brief look at Real Time Trains suggests two changes to get to London off the morning express from Newquay. Surely I have read this wrong?
| Re: Newquay a place to avoid from WEDNESDAY 11 august 2021? Posted by TaplowGreen at 15:40, 3rd May 2021 | ![]() ![]() ![]() |
| Re: Newquay a place to avoid from WEDNESDAY 11 august 2021? Posted by Timmer at 22:19, 2nd May 2021 | ![]() ![]() ![]() |
| Re: Newquay a place to avoid from WEDNESDAY 11 august 2021? Posted by grahame at 18:28, 30th April 2021 | ![]() ![]() ![]() |
I presume the direct Paddington to Newquay services will be in operation?
Planned for this summer ... so it should be. But London surfboards via Salisbury again?
| Re: Newquay a place to avoid from WEDNESDAY 11 august 2021? Posted by infoman at 18:17, 30th April 2021 | ![]() ![]() ![]() |
| Re: Newquay a place to avoid from WEDNESDAY 11 august 2021? Posted by TaplowGreen at 17:05, 30th April 2021 | ![]() ![]() ![]() |
The board masters event WIIL go ahead from
Wednesday 11th August 2021 till Sunday 15th August 2021
Just a heads up if any one was thinking of visiting Newquay on those days/dates.
Given the chaos of previous years, it's certainly worth avoiding attempting to get there by train.
| Newquay a place to avoid from WEDNESDAY 11 august 2021? Posted by infoman at 16:29, 30th April 2021 | ![]() ![]() ![]() |
| Re: Par to Newquay line closed Posted by grahame at 22:09, 25th February 2021 | ![]() ![]() ![]() |
Its a lot quicker to run the bus from St Austell to Newquay than from Par and it gives better onward connections on to the mainline. I also suspect most local travellers go on to St Austell anyway as there is hardly much to detain them in Par! ( with apologies to Parisians).
I saw the initial comment and thought "sensible for passengers to Newquay - but doesn't that make it a long way round for passengers from Par to Luxulyan, for example?". I suspect my thoughts were a classic example of looking from my armchair in far, far away. Luxulyan passengers may be rare as hen's teeth at the moment when you look at normal numbers, and the added distance really isn't that much when you look at the geographic layout
| Re: Par to Newquay line closed Posted by Jamsdad at 20:19, 25th February 2021 | ![]() ![]() ![]() |
| Re: Par to Newquay line closed Posted by LiskeardRich at 00:18, 25th February 2021 | ![]() ![]() ![]() |
due to flooding.
Due to heavy rain flooding the railway at Roche the line is blocked. Disruption is expected until 12:00 20/02.
Train services between Par and Newquay will be cancelled.
Rail replacement coaches have been arranged to run in place of the train service. These will run between St Austell and Newquay (in both directions). Customers at Par should take the next available train to St Austell for onward transport.
Please check station signs and wait for replacement road transport at the designated stop. The replacement road transport may run later than the advertised train times owing to the local road conditions, the additional time taken by road between stations and the time required for loading and unloading at each stop.
If you are travelling from an unstaffed station please use the Customer Help Point or contact National Rail Enquiries on 03457 484 950 detailing the total number of passengers travelling, and your intended destination.
Wasn’t quite a coach. Roselyn coaches ran the replacement service with an Optare Solo.
Which begs the question why not run it from Par as per the train. Their depot is almost next to Par station!
| Re: Par to Newquay line closed Posted by grahame at 08:37, 20th February 2021 | ![]() ![]() ![]() |
due to flooding.
| Par to Newquay line closed Posted by infoman at 08:02, 20th February 2021 | ![]() ![]() ![]() |
due to flooding.
| Re: Newquay Line - from today, a proper day return service available for all. Posted by infoman at 09:38, 17th December 2020 | ![]() ![]() ![]() |
Ref fraddon retail park,could passengers travel by train to St Columb Road and then catch the bus?
Just a thought.
A final thought that the first train out of Newquay
1) The station has a departure board display and
2) real time information,so we don't see the train being shown as "on time" til 07:11 and then "delayed"
| Re: Newquay Line - from today, a proper day return service available for all. Posted by LiskeardRich at 21:15, 16th December 2020 | ![]() ![]() ![]() |
Be interesting to see what the loadings on the early morning bus departures(06:00am ish) will be.
Having previously worked the 0630 ish Newquay to Truro bus, before the tender went to another operator, it used to carry reasonable numbers to work at the fraddon retail park which is still some distance to nearest station, and Truro. Truro is around 70 mins average on the bus, so I?d say the bus still has favourable timings to Truro from Newquay
| Re: Newquay Line - from today, a proper day return service available for all. Posted by grahame at 15:08, 14th December 2020 | ![]() ![]() ![]() |
Until December 2020 timetable on the LEFT, from December 2020 on the RIGHT:
Brilliant news ...
[snip]
A suggestion in my simple world, why not have a non stop service from Par? to Newquay to start the days workings.
[snip]
With assurance of reliability and longevity, the early inbound train may build up a commuter flow of people coming from the villages along the way to work in the leisure business in Newquay ... calling (as required) is what I would have suggested from the comfort of my distant armchair in the Far East (a.k.a. Wiltshire). I was distinctly cynical about our early train at 05:33 which started last December - happy to admit I was wrong in worrying and it's done much better than I would have guessed.
| Re: Newquay Line - from today, a proper day return service available for all. Posted by bobm at 15:00, 14th December 2020 | ![]() ![]() ![]() |
The Newquay branch is usually worked by crews based at Par depot.
The first service on the branch is now the 06:00 from Par which reaches Newquay at 06:52 and then returns at 07:12.
It looks like the unit stables at Par overnight having working on the Looe Valley line the previous evening.
| Re: Newquay Line - from today, a proper day return service available for all. Posted by infoman at 14:28, 14th December 2020 | ![]() ![]() ![]() |
Brilliant news considering that the first train out was approx 10:00am ish
As you have to purchase your ticket to travel before you sit down.
Just wondering where the train crew and unit come from.
A suggestion in my simple world, why not have a non stop servive from Par? to Newquay to start the days workings.
| Re: Newquay Line - from today, a proper day return service available for all. Posted by bobm at 13:18, 14th December 2020 | ![]() ![]() ![]() |
Earliest arrival into Plymouth was after 12 - you can now get to Paddington by that time.
| Re: Newquay Line - from today, a proper day return service available for all. Posted by LiskeardRich at 13:14, 14th December 2020 | ![]() ![]() ![]() |
If I?m not mistaken the earliest arrival to Plymouth or Truro was previously late morning. Useless for commuting
| Newquay Line - from today, a proper day return service available for all. Posted by grahame at 09:16, 14th December 2020 | ![]() ![]() ![]() |
Mentioned in several places elsewhere on the forum, but worthy of its own thread - as from this morning, extra services on the Newquay to Par line transform the service from a visitor's railway into a service that can be used for regular conventional commutes and days out, with the addition of two morning services. The line itself (and services) are summarised in the sticky thread at http://www.passenger.chat/24259
https://twitter.com/JanePlymouth/status/1338382626042892289
The importance of this is massive - a whole day in Plymouth is now practical by train not just an afternoon, as is travel into Newquay for the day from the places along the line - none with large passenger numbers yet, but an opportunity offered. Wishing all the best to GWR and the Community Rail team in the area in getting this line back into the fabric of routine community travel.
| Re: Newquay Line - Summary of services from December 2020 Posted by grahame at 09:20, 23rd November 2020 | ![]() ![]() ![]() |
I'm not disputing the potential passenger flows, what I am saying is the bus is currently faster because the branch is so slow. Get a faster Newquay service preferably running straight in to St Austell and passenger numbers would rise.
I do hear you on that flow; I was saying "look at other potential flows too".
There are similarities here from my own home town. The most common journey from Melksham is to Bath, and that involves a change and dogleg by train, but we have direct buses - indeed, advise for people headed to Bath is "catch the bus". However, we have done quite well with the other direction(s) which do not go to or via Bath, and also with flows that pass through Bath by train on their way beyond. Moving the service up to a level that remains poor (every 2 hours, like the Newquay branch becomes) but is useable for day return trips now has moved passenger numbers up by more than an order of magnitude; I wish the Newquay service well and can understand how it has significant potential.
| Re: Newquay Line - Summary of services from December 2020 Posted by Jamsdad at 23:44, 22nd November 2020 | ![]() ![]() ![]() |
| Re: Newquay Line - Summary of services from December 2020 Posted by grahame at 22:50, 22nd November 2020 | ![]() ![]() ![]() |
Good to see a better service but I am not sure there is much regular commuter trafffic. The line is painfully slow and the bus service from Newquay to St Austell is quicker. This is why the re-routing of the service via Burngullow makes so much sense.
I think you may be surprised at some of the other traffic that might develop. I note that passenger journey numbers at Newquay have been around 100,000 per annum but the five intermediate stations aren't unused totalling 20,000 journeys per annum. Not many, perhaps, but no useful commuter services so starting from a "useless" point. They may each be quite small communities at the moment, but the coming of a rail service one step better than useless will help them and help the railway. And how about commutes into Newquay especially for summer jobs. Then you have people headed for Liskeard and Plymouth for the day ...
Here are three of the close station catchments to give you an idea ...
| Re: Newquay Line - Summary of services from December 2020 Posted by Jamsdad at 19:26, 22nd November 2020 | ![]() ![]() ![]() |
| Re: Newquay Line - Summary of services from December 2020 Posted by bobm at 18:35, 22nd November 2020 | ![]() ![]() ![]() |
It does look logical although if it is to provide a commuter service back from Newquay there is an element of risk introducing at this time.
Mondays excepted it connects with the down sleeper. (On Mondays it needs a change at Plymouth). It also connects with the first stopper up from Penzance.
| Newquay Line - Summary of services from December 2020 Posted by grahame at 18:00, 22nd November 2020 | ![]() ![]() ![]() |
Par to Newquay - the Atlantic Coast Line
Connections from London, Exeter, Plymouth, Liskeard and Bodmin Road
Connections from Penzance, Truro and St Austell
Noting that from mid December, there are two extra round trips on Mondays to Fridays on the Newquay branch.
Arrivals into Newquay have been:
10:13, 13:05, 15:08, 17:07, 19:15 and 21:21
and they become:
06:52, 09:10, 11:02, 13:05, 15:08, 17:07, 19:15 and 21:21
Return trains to Par have been:
10:23, 13:10, 15:10, 17:19, 19:22 and 21:28 until mid December
and they become:
07:12, 09:17, 11:12, 13:10, 15:10, 17:19, 19:22 and 21:26
Seven round trips on Saturdays (no change - 06:52 to 20:22 off Par)
Three round trips on Sundays (no change - 10:05 to 16:15 off Par)
Summer see through services from London daily, and from The North on Saturdays.
All services except summer through service call on request at all intermediated stations
To someone who's not all that familiar with the line, this seems to be a very logical filling of the most enormous crater in services that appears to have left a previous service totally unfit for "9 to 5" commuters to either end of the line. Having said which, I know an earlier round trip as tried for a period a few years back, but then taken off.
From December ... 07:12 off Newquay, 07:41 Bugle, 08:13 St Austell and 08:30 Truro. (Bugle being the busiest intermediate station). Return from Truro at 17:54, St Autell at 18:10 and getting to Bugle at 18:39 and Newquay at 19:15. Makes huge sense in moving todays a "mid-Cornwall Metro" starting with a peak train.
Par. Connecting services to Plymouth and beyond, and to Penzance
overview - local map - wider map
St Blazey - operational point
Luxulyan
Passing loop at Goonbarrow; limit of freight operation.
Bugle
Roche
St Columb Road
Quintrill Downs
Newquay - Single platform / no sidings just a buffer stop.
| Par to Newquay special trip Posted by infoman at 18:56, 9th May 2019 | ![]() ![]() ![]() |
Children and Mature persons on a special train from Par to Newquay.
Not sure which day although it was broadcast on 9 May on BBC Spotlight
Can be seen again on the i-player thingy towards the end of the local News
Be quick as the local News is only available for 24 hours
| Re: Train hits tree 29/11/2018 Newquay branch Posted by Cornish bobby at 18:18, 5th December 2018 | ![]() ![]() ![]() |
Anyone know the extent of the damage to the unit (a 150/2 I understand) and whether it will be OOU for any length of time?
It was 150247 which received extensive cab and bodyside damage. It returned to Par and later Exeter being driven from the undamaged end. It also has wheelflats. A few days ago it was still at Exeter waiting onward movement to Bristol.
| Re: Train hits tree 29/11/2018 Newquay branch Posted by TJ at 21:44, 29th November 2018 | ![]() ![]() ![]() |
| Train hits tree 29/11/2018 Newquay branch Posted by Witham Bobby at 12:01, 29th November 2018 | ![]() ![]() ![]() |
Due to a tree blocking the railway between Par and Newquay the line is blocked.
Train services running to and from these stations will be cancelled. Disruption is expected until the end of the day.
This morning a train travelling to Newquay struck a tree in the Roche area, this caused damaged to the train which has meant it has had to return to the depot for repairs.
For the rest of today road transport will be provided between St Austell and Newquay. Please see station signage for the rail replacement pick up locations. This road transport may run later than advertised train times. ... [snip] ...
An update will follow within the next 2 hours.
Last Updated:29/11/2018 11:09
Anyone who's travelled on the Newquay branch in recent years could, sadly, have predicted this. Vegetation not very well managed. Summer 2017 my last visit it was like travelling down a tree tunnel in several places.
| Newquay Line - services, incidents and improvements (merged posts) Posted by martyjon at 07:31, 7th May 2018 | ![]() ![]() ![]() |
I will be interested if the Newquay line is nothing less than cosy today with a single car 153 operating today according to JourneyCheck.
