Re: Shortage of train crews on Great Western Railway - ongoing discussion
15.5.2025 (Thursday) 02:49 - All running AOK
Posted by GBM at 07:12, 12th May 2025
Might not be possible due to driver hours and route knowledge. I do wonder how many passengers this would impact and whether a taxi might be a better option
Does route knowledge apply to bus drivers?   I can recall before the days of SatNav helping rail replacement bus drivers find the way.
Oh yes, route knowledge is imperative.
In training, it was always said "If you don't know a route, you don't drive it".
Invariably we did, but if anything happened, you were automatically at fault.
On rail replacement, drivers can be drafted in from many distant areas, and totally unfamiliar with local routes.
Posted by bobm at 20:08, 11th May 2025
It has not been unknown for a rail replacement bus to hit a low bridge so while not mandated it might be prudent to ensure drivers know the route before being thrown in to cover extra journeys.
Posted by grahame at 18:03, 11th May 2025
Posted by nickswift99 at 17:41, 11th May 2025
Posted by grahame at 09:04, 11th May 2025
Extend the bus to Westbury if the trains not running?   Or is that too much like common sense?
Posted by Timmer at 08:56, 11th May 2025
Cancellations to services between Westbury and Warminster
Due to a shortage of train crew between Westbury and Warminster fewer trains are able to run on all lines.
Train services running through these stations will be cancelled. Disruption is expected until the end of the day.
We are sorry for the disruption to your journey today. Due to a shortage of train crew, we won't be able to run as many trains between Westbury and Warminster as we would like. Planned engineering works are taking place between Warminster and Southampton Central so we already have rail replacement buses running between these stations. We may not be able to run trains to Warminster to meet with the rail replacement buses.
The best way to complete your journey if you're travelling between South Wales / Bristol / Bath and Southampton Central is to take the next available train to Reading. You can then change there for services towards Southampton Central or towards South Wales / Bristol / Bath depending on which direction you're travelling in. Don't worry, your tickets will be accepted at no extra cost on these routes.
To travel between Reading and Southampton Central, you will need to either use direct Cross Country services or GWR services between Reading and Basingstoke and then South Western Railway services between Basingstoke and Southampton Central. Your tickets will also be accepted on these services at no extra cost.
If you are travelling between South Wales / Bristol / Bath and Portsmouth, you should also travel via Reading. If you're travelling from South Wales / Bristol / Bath towards Portsmouth, you should take the first available train to Reading. You should then change at Reading for trains to Guildford. You should then change again at Guildford for South Western Railway services towards Portsmouth. If travelling in the other direction, you should take the first available South Western Railway service to Guildford and change there for trains towards Reading. You should then change at Reading for trains towards South Wales / Bristol / Bath. Don't worry, your tickets will be accepted at no extra cost on these routes.
Posted by a-driver at 11:59, 29th April 2025
Asking in context - isn't that a Sunday issue?  On Monday to Friday - 21:04 off Paddington to Plymouth making all three of these calls, and also later travel to Westbury available with a Swindon change (21:31 off Paddington) and even later via Bath Spa.
Not sure what you mean by a Sunday issue. Are you thinking about there being less demand because it’s a Sunday?
A few years ago, I’d have said yes. Now a lot more people travel on Sundays and later in the evening.
It stops at these stations Monday to Fridays, why not on Sundays?
To really answer that you would need to know how often that service runs on a Sunday's via the B&H
Posted by grahame at 07:31, 28th April 2025
Exactly my point - just clarifying where the 9 O'clock (ish) stops the rest of the week.
Posted by Timmer at 07:12, 28th April 2025
Posted by grahame at 06:51, 28th April 2025
And all the intermediate stops to Plymouth?
The 2100 Paddington to Exeter made extra stops to cover stations between Reading and Taunton:
21:00 London Paddington to Exeter St Davids due 23:11 will be diverted between Pewsey and Castle Cary.
It will call additionally at Newbury, Pewsey, Westbury and Castle Cary.
It will be delayed due to the diversion and is expected to be 12 minutes late.
This is due to the train making extra stops because a train was cancelled.
I have often wondered why this train doesn’t stop at these stations anyway to give Pewsey, Westbury and Castle Cary a later train from London. 2000 does seem a little early these days.
Posted by Timmer at 21:54, 27th April 2025
Posted by ChrisB at 20:31, 27th April 2025
Posted by Mark A at 20:17, 27th April 2025
Indeed, it stayed cancelled and the National Rail site is suggesting the sleeper.
Posted by TaplowGreen at 15:55, 27th April 2025
This sort of cancellation/reinstatement** dance, when it involves the last train of the day, must do a disproportionate amount of damage to the confidence that intending travellers hold in the railway as a travel mode.
**Not yet reinstated, but let's see.
Now completely cancelled
 ..............cosy on the sleeper then?
Posted by Timmer at 10:55, 27th April 2025
Posted by Mark A at 10:34, 27th April 2025
Posted by Timmer at 10:20, 27th April 2025
And the most useless train of the day award goes to:
20:00 London Paddington to Plymouth due 23:35 will be terminated at Reading.
It will no longer call at Newbury, Pewsey, Westbury, Castle Cary, Taunton, Tiverton Parkway, Exeter St Davids, Dawlish, Teignmouth, Newton Abbot, Totnes and Plymouth.
Let’s hope it gets reinstated as it’s the last train of the day from London to a lot of the above stations including Plymouth.
Posted by Timmer at 20:12, 13th April 2025
And perhaps as a consequence.....what a pleasant experience this will be......
12:02 London Paddington to Penzance due 17:05
Facilities on the 12:02 London Paddington to Penzance due 17:05.
Service full and standing from London Paddington.
The good news was that the 14.02 was fully reinstated all the way to Penzance which is just as well as the 12.32, 14.32 and 16.32 semi fasts were all canned with the 13.02, 15.02 and 17.02 making additional stops to cover for the cancelled trains.
Posted by TaplowGreen at 14:00, 13th April 2025
Two next to useless trains unless you’re fortunate enough to be travelling to/from Reading!
14:02 London Paddington to Penzance due 19:05
14:02 London Paddington to Penzance due 19:05 will be terminated at Reading.
It will no longer call at Taunton, Tiverton Parkway, Exeter St Davids, Newton Abbot, Totnes, Plymouth, Liskeard, Bodmin Parkway, Par, St Austell, Truro, Redruth, Camborne, St Erth and Penzance.
17:32 Exeter St Davids to London Paddington due 20:40
17:32 Exeter St Davids to London Paddington due 20:40 will be started from Reading.
It will no longer call at Exeter St Davids, Taunton, Bridgwater, Highbridge & Burnham, Weston-Super-Mare, Worle, Yatton, Nailsea & Backwell, Bristol Temple Meads, Bath Spa, Chippenham, Swindon and Didcot Parkway.
Posted by Timmer at 07:56, 13th April 2025
Posted by UstiImmigrunt at 17:20, 12th April 2025
A good BBQ occurs anytime of the year and in any weather
Posted by TaplowGreen at 16:36, 12th April 2025
Cancellations for tomorrow already being listed on JourneyCheck.
School holiday season I guess?
(Although the BBQ weather is coming to an end!)
Posted by TonyK at 16:16, 31st March 2025
There's always one rebel who follows the instructions...
Posted by UstiImmigrunt at 09:36, 31st March 2025
To explain the above comment, there was a brief time where in Swindon a controller could stop the tape recording. Keeping the piece of paper in your possession prevented the hindsight committee making accusations of missing calls or making additional stops causing delay minutes and as we all know the railway is now run on delay attribution.
A little story, Saturday afternoon many years ago I'm on the 1430 BTM Paddington. Sat in the front cab of my lovely HST when a member of platform staff asks if I sign the B+H. Yep. He says he'll return, something has just happened. A few minutes later he returns with not to call orders for Chippenham, Swindon and Didcot. Off we go but at Barf Spa the screens are showing Chippenham etc and the dispatcher says you're now calling. I require a Special Stop Order to countermand the not to call order. But in the few minutes it takes to write out the paperwork it has been decided to go via the B+H. So I rip up the SSO and tell the TM to do the same, I have the BTM issued not to call orders which is fine for me. During this time the passengers are off, on and back off. Left around 10 late, the Pompey has cleared off, an up WOE is held at Hawkridge for me, so it's greens all the way from Barf to Reading excent for the distant approaching Hawkridge. Some very aggressive driving, black box compliant (ish) 3 late Reading and RT Paddington. Paperwork kept for a few weeks just in case
Posted by UstiImmigrunt at 14:30, 30th March 2025
I was the awkward one who always insisted on the correct paperwork. Never got questioned.
Posted by IndustryInsider at 12:38, 30th March 2025
How are train crew notified of late amended station stops after they've started their shift?
As in, you book on at x o'clock with the station stops listed on your duty board for the day.
Then journeycheck throws in a few additional station stops 'because a train was cancelled'.
GWR need to tell all the crew, not just the driver!
They usually receive a signed form known as a 'Stop Order' or 'Not to Stop Order' from a member of station staff (which is also given to the Guard).  Occasionally this isn't possible in which case they act on verbal authority from the signaller or control (both are on recorded lines).
Posted by GBM at 12:08, 30th March 2025
Posted by UstiImmigrunt at 07:18, 24th March 2025
Another 3 HSS BTM drivers retired today... With full depot route knowledge that won't be replaced.
Since the introduction of the IETs and the GWR driver grade the company really has lost its way, the more HSS drivers that retire the more they are going to struggle to cover the work.
Route knowledge, productivity and flexibility are key, and they’re losing it quickly.
Zombie franchise now - why would GWR take on the cost and responsibility of recruitment and training when they know they only have a short time left in the driving seat? (so to speak!).
In the past driver training has been subsidised by DaFT. I remember complaints from those awaiting a course being told postponed due to no money from DaFT. Then suddenly you start next month, normally after a holiday has been booked.
Posted by ChrisB at 16:38, 23rd March 2025
Indeed - DfT not requiring the extra knowledge - and will suffer from it later, but they won't mind (until everything goes tits up, and then they'll launch another 'enquiry')
Posted by TaplowGreen at 15:57, 23rd March 2025
Posted by a-driver at 14:57, 23rd March 2025
Posted by UstiImmigrunt at 14:44, 23rd March 2025
Can't blame them for leaving, the money's awful!
I wouldn't worry thought, I'm sure GWR will have it covered - their workforce management abilities are legendary.
Drugs test for TaplowGreen please.
Around 100 years service between the three recent retirees.
Reason for edit, missed out a word.
Posted by grahame at 21:36, 22nd March 2025
Sorry - we cannot meet this request
22 Mar 2025, 20:36 - www.firstgreatwestern.info
If you think you should have received a real page - please contact me - graham/at/sn12/dot/net
Please copy and paste the description (above) in your email so I can resolve any problem.
Thank You.
Got aproper page on retrying
Thanks for letting me know, Chris.   This may happen occasionally when the receptionist finds it can't talk to the worker, and that did happen this evening because I rebooted the worker.
Posted by ChrisB at 20:38, 22nd March 2025
502
Response code number 502 ( Official description - " Bad Gateway " )
You have asked for /coffeeshop/index.php?topic=18719.new;topicseen
You have asked of (our server) www.firstgreatwestern.info [213.165.84.74] on port 443
You have asked from (client) 86.142.147.204
You have asked using the GET method and HTTP/1.1 protocol
Your browser is Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/134.0.0.0 Safari/537.36 Edg/134.0.0.0
You were referred here from https://email.bt.com/
You received response code 502 ( Bad Gateway ) at 20:36 on 22 Mar 25
Thank You.
Posted by TaplowGreen at 08:41, 22nd March 2025
Posted by UstiImmigrunt at 22:20, 21st March 2025
Posted by TaplowGreen at 11:09, 9th March 2025
Drivers prioritising the life over working overtime. You really can't blame them. Rugby @ 1500.
.....and to be fair, being a train driver puts you in the income bracket necessary to be able to afford Twickenham tickets these days!
Posted by ChrisB at 09:57, 9th March 2025
Posted by Timmer at 08:10, 9th March 2025
Not quite as many as last week, but another batch of cancelled/part cancelled trains again today, particularly out of Paddington around 4pm with three long distance trains in a row cancelled.
After many weeks of next to zero cancellations, are we seeing a slow return to how things were before Christmas?
Posted by UstiImmigrunt at 21:09, 2nd March 2025
I agree it's pathetic.
Now if only the money was paid up 20 years ago and Sundays were inside the working week. I would have liked that option.
Posted by TaplowGreen at 20:59, 2nd March 2025
1803,1903 & 2003 Paddington-Plymouth all cancelled due to crew shortage. I guess that just leaves the Sleeper?
2103 Exeter is shown as running. Also the above trains not showing on RealTime trains so cancelled well in advance?
Oh, that's alright then. Just a shame it gets to Exeter half an hour after the last service to Plymouth leaves
Posted by UstiImmigrunt at 20:46, 2nd March 2025
Posted by UstiImmigrunt at 20:35, 2nd March 2025
Railway pay is four weekly, 13 pay days a year so March or April is the freebie month. Also every few years there's a single week bank credit.
Posted by TaplowGreen at 20:34, 2nd March 2025
Posted by ChrisB at 16:18, 2nd March 2025
When was payday?  Sunny weather and a full wallet.....
Not until next Friday for most.
Would that be for staff paid 4-weekly or monthly?
Posted by grahame at 15:57, 2nd March 2025
I wonder whether "these days" most people are handilng their cash flow on plastic, and can quite cheerfully charge half term or weekend treats for the younger family members and pay in weeks to come or next month.
Posted by IndustryInsider at 14:50, 2nd March 2025
Posted by bobm at 14:49, 2nd March 2025
Posted by TaplowGreen at 12:28, 2nd March 2025
After a decent couple of months looking at the map today there's a fair number of full/part cancellations due to lack of train crew, longer distance services later in the day especially.  Hopefully we're not seeing GWR slipping back into their woeful Sunday performance.
Surely not everyone had tickets for Man City v Plymouth?
Posted by TonyK at 15:10, 25th February 2025
Thank you - that has answered one of my long-time unanswered but unasked questions that I've pondered for sometime!
In my case, it was entirely unpondered, but it's interesting to know.
Posted by ChrisB at 14:18, 20th February 2025
When it's a ten car then one of the customer hosts in the front set must be a lead host in case of an emergency. The TM is allowed to swap between sets for revenue duties as long as there is a lead host in both sets.
Posted by UstiImmigrunt at 12:56, 20th February 2025
Generally LTV trains are DOO, Driver Only Operation. Gatwick, Marlow and I think Basingstoke are driver and guard.
All West services are also driver and one guard.
A single IET outside of the LTV area requires a minimum of driver and guard. When catering is provided in theory it's 2 customer hosts per set, first class and trolley operator. When it's a ten car then one of the customer hosts in the front set must be a lead host in case of an emergency. The TM is allowed to swap between sets for revenue duties as long as there is a lead host in both sets.
Finally add all the wasteful travelling that takes place. In theory drivers just advise the TM or guard and sit down. The other grades are supposed to other assistance, pushing the trolley or checking tickets.
As a comparison on ČD any service with a restaurant car has a chef, waiter for the restaurant coach and another for taking a trolley through second class and offering an at seat service in first class. Nothing beats a goulash polévka then veal, lentils and vegetables and 33cl can of craft beer being served at your seat at a steady 90 MPH for about £12.
PS The ham and eggs breakfast is highly recommended.
Posted by IndustryInsider at 12:06, 20th February 2025
Out of interest how many staff are on an average service?
Difficult to give an average, though I would guess at around two.
Usually ranges from one (DOO services) to ten (Pullman services).
Posted by Phantom at 10:57, 20th February 2025
The reason I ask, I travelled from Paddington to Temple Meads last week on first class.
There was a hostesses for standard class, and another one for first class
Then there was a train Manager, but also another two staff checking tickets
I felt like I was on a plane for the number of staff
Posted by UstiImmigrunt at 20:36, 19th February 2025
Don't be surprised if there's a few cancellations between now and Monday morning due to a shortage of staff.
Half term?
Correct. Not much overtime being worked and maximum leave allocation used.
Posted by TaplowGreen at 20:28, 19th February 2025
Half term?
Posted by UstiImmigrunt at 19:55, 19th February 2025
Posted by LiskeardRich at 17:59, 12th January 2025
A lack of shunter at long rock was the issue this morning.
The 2 car unit used on the Paddington as far as Truro was stabled in the station overnight- no shunter required this morning. It was utilised in service instead of running empty in the running space of the IET
Posted by UstiImmigrunt at 15:46, 12th January 2025
The hiatus of cancellations and short running of services due to train crew shortages after three weekends of nigh on 100% of services running has sadly come to an end today.
What have we learned from these past weeks? That GWR really DO have enough train crew to run the timetabled service…IF the price is right.
On Sundays, yes.
Also the rest of the week if correctly diagrammed.
Or for example...
https://www.realtimetrains.co.uk/service/gb-nr:G45596/2025-01-12/detailed
The TM to work it was on 1L32. That was stuck outside waiting a platform. Not for the first time a Mexican stand off at Swindon!
Posted by Timmer at 09:15, 12th January 2025
1A80 0815 Penzance to London Paddington
08:15 Penzance to London Paddington due 13:29
08:15 Penzance to London Paddington due 13:29 will be terminated at Truro.
And it's a two car unit.
Guessing it will go on to the Falmouth branch
Will be restarted at Plymouth.
Posted by GBM at 08:38, 12th January 2025
Cancellations to services between Penzance and Plymouth
Due to a shortage of on train staff between Penzance and Plymouth fewer trains are able to run on all lines.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 11:00 12/01.
We apologise for the disruption to your journey today. Due to a shortage of staff at Long Rock depot, fewer trains are available to operate our services on the Cornish Main line.
We are expecting the normal timetable to resume at approximately 10:50.
Posted by Timmer at 07:41, 12th January 2025
Posted by Timmer at 06:57, 12th January 2025
Posted by TaplowGreen at 20:06, 26th December 2024
.......well, after two days without a single full or part cancellation due to staff shortages, they're starting to roll in thick and fast for Friday 27........
Posted by TaplowGreen at 06:26, 23rd December 2024
The Dft I assume you mean? GWR won't be paying
The taxpayer I assume you mean?
Posted by ChrisB at 21:25, 22nd December 2024
Posted by a-driver at 21:23, 22nd December 2024
................what a difference double time makes to the desire to spend time with one's family!
….. but previously there were people saying drivers don’t want the overtime because they’ve had a huge pay rise!!!!
Flash enough cash...
I wonder though…..financially, what is better for GWR?
A mass of cancellations, replacement coaches, taxis, accommodation and delay repay OR raising the rate of pay and covering the jobs.
Posted by JayMac at 17:37, 22nd December 2024
Posted by bobm at 15:21, 22nd December 2024
As predicted a much better service on GWR today with, as far as I know, only cancellations to Barnstaple and Okehampton due to the forecast of high winds.
However there a number of long distance services with either no or reduced catering.  At least these are advertised on Journeycheck so affected passengers can make alternative arrangements.
Posted by a-driver at 12:33, 22nd December 2024
Secretary of State confirms that the pay rise has made matters worse.....
https://www.lbc.co.uk/news/christmas-travel-pay-rise-transport-secretary-heidi-alexander/
….. or is it just a poor excuse covering for a issue of their own making.
Raise the rest day payment during the week and the result should have been obvious, more so, as that mistake has been made before.
Posted by Bob_Blakey at 09:52, 22nd December 2024
All the employment on-costs that apply to staff - final salary pension, employment taxes, additional depot space, that sort of thing - it all adds up. Overtime just attracts a small amount of additional NI.
But a reliance on overtime and/or rest day working demonstrably prevents GWR from running a half-way decent service leading to the public using other forms of transport, or not travelling at all, and a consequential significant loss of revenue.
Posted by old original at 08:14, 22nd December 2024
but the higher basic pay may encourage more people to try and join the railways, if the companies are allowed to employ them.
Posted by TaplowGreen at 21:40, 21st December 2024
Posted by ChrisB at 17:12, 20th December 2024
A way of paying off the overspend of that pay over Christmas (holidays & presents)
Posted by a-driver at 17:10, 20th December 2024
Posted by UstiImmigrunt at 17:00, 20th December 2024
Then normal no service resumed on January 5th.
Posted by TaplowGreen at 16:49, 20th December 2024
Posted by a-driver at 11:44, 20th December 2024
Okay. I'm dealing with politicians here so... If
I will wait with bated breath!
Not entirely sure just where you got that quote from, a-driver
The post that you quote is actually this one - and those words you quote don't appear!
 #2565 #2566 and #2568….. but I’m no good with quotes!
Posted by a-driver at 11:33, 20th December 2024
Some good news on the Sunday front this morning…..
The DfT have now given GWR approval to restart formal conversations with the trade unions to find a solution.
Yet a further indication on who has been blocking a resolution.
Posted by ChrisB at 11:02, 20th December 2024
I completely fail to understand how the ongoing reliance on overtime and/or rest day working can be a better financial option than a fully contracted workforce given that this morning, on Talk, Simon Calder, who I think is generally regarded as knowing his subject, stated that the (daily) additional payments were £250-£300 for some on-train staff such as TMs and £600 for drivers.
Posted by ray951 at 11:01, 20th December 2024
According to the Oxford Clarion: https://bsky.app/profile/oxfordclarion.bsky.social/post/3ldq7suc7hc2n
"A last-minute pay deal has averted collapse of GWR’s service this Sunday (22nd) and next (29th), but widespread cancellations are still expected.
GWR has agreed to pay drivers and guards double rate.
The company does not have enough staff to run a full Sunday service without overtime."
Posted by ChrisB at 10:58, 20th December 2024
Just a note to say that, even if there's no proof in the public domain, you can't claim that it doesn't exist. Confidentiality clauses exist in most commercial contracts.
Posted by Bob_Blakey at 09:10, 20th December 2024
Posted by Chris from Nailsea at 19:16, 19th December 2024
May I step in here, quietly, as an Administrator, simply to thank all of you contributing to this rather 'lively debate', for keeping it polite?
Thank you. CfN.
Posted by a-driver at 19:06, 19th December 2024
Where's the mention in that 2022 business plan about recruitment? The point I've been making. You've highlighted the 'Seven Day Railway' part of the business plan. That's about GWR providing costing to the DfT for existing staff having their contracts changed to include Sundays.
No. Those costings GWR provided to the DfT included the exact number and cost of additional drivers required.... and that is, and still remains the stumbling block.  The DfT opting to cover Sunday's on overtime with a commitment to work Sunday's.
Every driver is rostered Sunday's, but can obviously make themselves unavailable if they choose.  You take those rostered Sunday's, you work out what that equates to over the course of the year and you add that to the basic salary.  That becomes pensionable etc.  It's relatively easy to sort. The issue is the extra number of drivers required which is what the DfT refuses to agree to.
A commitment to work Sunday's does not work.  There are issues with it.  If you are contracted to work Monday to Saturday, you can only apply for leave on those days.  You can not apply for leave on a Sunday.  Therefore, for example, f you book yourself a Saturday to Saturday holiday but you are rostered to work that Sunday, you can't get out of it.
It's getting somewhat tiresome to keep repeating that the driver shortage issue goes back over a decade with FGW/GWR failing to address it. Cancellations due to driver shortages occur on every day of the week.
It is indeed extremely tiresome.
FGW's/GWR's driver shortage problems did not suddenly pop into existence when the DfT awarded them the direct contract in 2022. This thread alone is evidence of that. And other threads on a similar theme predate the start of this one in 2017.
Instead of recruiting since 2012 FGW/GWR were happy to take the cheaper option of paying overtime to their existing drivers, relying on goodwill. That just stored up problems for the future - an aging driver pool, losing the goodwill, industrial action...
You haven't got a shortage of drivers, in fact, they're over established at many depots.  The issue is not all the drivers sign all the routes and/or traction.  That issues stems from the huge number of new drivers they have recruited over the last 10-15years.  If you were based at Paddington depot 10-12 years ago and walked in the mess room tomorrow, you wouldn't recognise any faces such is the turnover of staff.
You train new drivers right up until they can become productive and then you let them loose on the mainline.  This gives them time to settle in, find their feet, grow in confidence etc.  You don't overload them with all the routes in one hit. That's not the way to retain key information.
Not only have they recruited a significant number of new drivers over the last 10-15 years, but you've had the IET's come into service and 387's.  You've had the Turbo's move West, 158's move West and Castle sets.  That's all new traction training and handling hours.
Covid then came along and everything came to a halt. Which things resumed, some instructors weren't comfortable having others in the cab and gave up the role so new instructors had to be recruited and trained.  There's still a backlog of training outstanding and there's still a large number of wanna-be train drivers in the talent pool awaiting start dates so it's an ever improving situation, rest day working is, from what I hear, certainly reducing.  However, July 2025 see's the pay rise reflected in final salary pensions so you could see an exodus then, and if that involves old BR staff, they only have to provide minimal notice.
Sunday's will always remain an issue until the DfT agrees to a solution.  Either a rise in Sunday's rates or bringing Sunday's into the working week.  The ball is in the DfT's court.  The DfT have agreed increased payments for 22nd (albeit to late) and the 29th so we shall see the outcome of that shortly.
Posted by John D at 15:54, 19th December 2024
You clearly haven't read it.
I have. Don't presume to tell me what I have and haven't done.
But do please help me out if I've missed something in the business plan about DfT control of hiring of staff. I've attached the document to aid you.
I can also attache previous franchise agreements and service level commitments if you'd like. I've read those from start to finish too. I continue to await PROOF that the DfT are, and have in the past, been dictating to GWR whether they can or can't hire sufficient staff to meet their obligations to provide the timetabled service.
These agreements and contracts generally get looked at by highly paid lawyers, only a muppet would agree to a business requirement that requires 50,000 hours annually of train crew (or whatever the figure is) and then agree to a staffing level that only covers about three quarters of the requirement.
You shouldn't work on assumption that because staff would work 60 hour weeks 100 years ago, then they will still so in mid 2020s when pay is higher and work-life balance expectation is completely different. Although GWR management don't seem to get this as I have seen the history argument (it used to be ok) used recently.
Posted by JayMac at 15:50, 19th December 2024
]if so directed by the Secretary of State
So, a company that you believe has total control of operations, a free reign to do as it pleases..... for some reason..... has to submit a detailed and costed proposal to the Secretary of State to have Sunday's in the working week.  And that proposal can only be implemented if so directed by the Secretary of State.  To me, that sounds very much like the DfT have total control.
I'd very much like to know from your MP why the proposal wasn't agreed by the Secretary of State.
When!
Posted by grahame at 14:23, 19th December 2024
Good article, worth a read;
https://www.independent.co.uk/travel/news-and-advice/uk-railways-sunday-overtime-trains-b2666301.html
Indeed very much worth a read ... there is some specific mention of GWR therein:
Small changes are underway, such as Great Western Railway transferring newly recruited drivers to contracts that included a commitment for Sunday working in 2018.
However, “without a further trade union deal this will take some time to work through [the] whole driver population,” it admitted, adding that “in line with most of the rail industry we do rely on paid overtime.”
The train company added that this is not a case of not having enough staff, but rather that employers’ contracts contain terms and conditions that mean GWR are “reliant on a number of colleagues volunteering to work overtime to cover our timetable on Sundays”.
We have a complex situation which manifests itself in different ways that have somewhat diverged in different franchises / contracts, and even they within the contract.  Northern drivers to the east of the Pennines and different to Northern drivers west of the Pennines, and on GWR it depends on which part you came from in 2006 or in the decade thereafter, or are a recent recruit.   Then on top of the complex situation you have the (to me) grey interface between First (as GWR) and HMG (as DfT) where I feel that whoever is asked there's a degree of "not my choice, mate".
Posted by a-driver at 12:42, 19th December 2024
Equally, you can't claim it DOES exist.
Meanwhile, my MP is putting the question to the rail minister. When I have that response I will of course share it here.
When!
Business plan dated 14 June 2022.  Page 28.
https://assets.publishing.service.gov.uk/media/65eadac062ff48ff7487b253/first-greater-western-limited-2022-business-plan-commitments-2022-to-2023.pdf
The extract is as follows:.
Train Crew - Seven Day Railway
4.1 4.2 The Operator will use all reasonable endeavours to increase the number of drivers with a Sunday working
commitment.
The Operator will by no later than 9 December 2022 submit an indicative costed proposal to the Secretary of State
to include Sundays in the working week for drivers during the Contract Term, and the Operator shall ensure that
such costed proposal:
(a) specifies clear and deliverable outputs and the steps required to implement such outputs;b) identifies relevant risks and potential mitigations;
(c) identifies options for delivery of outputs (including options for introduction of Sundays in the working
week for drivers from such different points during the Contract Term as the Secretary of State may
direct); and
(d) identifies all estimated potential costs including of any proposed options,
and shall do so in a manner consistent with the potential incorporation of such proposals in the draft Business Plan
to be submitted to the Secretary of State by no later than 15 December 2022 so that they are capable of being taken
forward through the annual Business Plan process set out at paragraph 3 of Chapter 7.7 (Business Plan) of the
Contract if so directed by the Secretary of State.
It is acknowledged that the Secretary of State may, in accordance with paragraph 3 (Annual Business Plan Process)
of Chapter 7.7 (Business Plan) of the Contract, propose the applicability of a business plan commitment equivalent
to paragraph 4.1 in future Contract Years.
Posted by JayMac at 11:40, 19th December 2024
Posted by ChrisB at 11:39, 19th December 2024
Posted by JayMac at 11:32, 19th December 2024
Posted by TaplowGreen at 10:06, 19th December 2024
......guess it goes to show how much train drivers basic pay has increased since privatisation, certainly in comparison with similar jobs such as coach/bus drivers.
Overtime now no longer needed or wanted, and the policy of TOCs relying on it to sustain weekend services rather than employing sufficient staff to do so has firmly bitten them in the arse.
Posted by UstiImmigrunt at 09:18, 19th December 2024
The same with train crew.
Driver link 10 at Canton 1993 and 94 had 3 Sundays in 16 weeks along with 2 days marked xxx. The xxx meant first priority at any volunteer Sundays irrespective of the Sunday count and subject to Hidden along with route and traction knowledge. And there were plenty of experts who would check who had the short notice Sundays and if a mistake was made a claim for loss of earnings would be made.
Also it wasn't unknown to swap the fortnight summer leave if a booked Sunday feel in the middle. This was because a driver was always not available for the middle Sunday of a fortnights' block leave.
Posted by Witham Bobby at 08:59, 19th December 2024
I remember from working on the railways upwards of 40 years ago how most staff wanted to work on Sundays.  There would actually be major fallings-out sometimes, between colleagues or between staff and their roster clerk, if an expected Sunday turn didn't find its way onto the roster.  Many with families depended on the extra money.  The standard 40-hours' pay was no great shakes, back then
It was overtime (with a hefty premium) back then.  So it's a bit disingenuous of Mr Wheelan to claim that the present working arrangements for Sundays are the result of privatisation
Posted by TaplowGreen at 07:06, 19th December 2024
Posted by a-driver at 11:11, 18th December 2024
I assume you've also read the business plan?
Yes. Nothing in that about DfT control over the hiring and training of staff.
Posted by JayMac at 11:08, 18th December 2024
Posted by JayMac at 11:05, 18th December 2024
Buses of Somerset staff shortages have been ongoing for several months.
It's all the DfT's fault of course.
Posted by bradshaw at 10:14, 18th December 2024
It is not just GWR, Buses of Somerset, also part of First Group,  have been having problems over the past few days
  Yeovil Services Disruption: We are sorry to report, that due to ongoing issues with driver sickness and a shortage of buses, there will be disruption to various services throughout the day. We will notify you as soon as we know what we can or can't run.
(From X)
