Re: Go-Op Cooperative - proposals for additional rail services (merged posts)
As at 24th November 2024 03:51 GMT
Posted by Phantom at 13:08, 19th November 2024
Hopefully finally a decent service to get to the cricket in Taunton when travelling from Weston
EDIT: On seeing they are single carriage trains and then reading this, I am not holding my breath "It will compete with Great Western Railway (GWR), a public service operator. Go-op plans to start in December 2025 at the earliest, and must do so no later than December 2026 in order to use the capacity ORR has granted."
Posted by grahame at 08:25, 19th November 2024
From https://grahamellis.uk/blog1418.html
But there are so many ifs in there it worries me.
If we believe it's possible on the timescale (and Go-op does have a history of missed deadlines - the service will be at least a dozen years late) we should all be working together. GWR. ORR. NR. GBR. DfT. WC. TWCRP. WWRUG. MTUG. FoCS. TWSW. FOCs. Passenger Focus. Western Gateway SnTB. MTC, MWPC and other local councils. and of course Go-op.
* - yes, I can fill in all those initials and I have a working relatinship with many of them
* - the possible train service does take account of single line occupancy
* - freight operation and main line paths and platforms need to be considered
* - same time every hour would need more trains or a passing loop or onward services
* - the possible train service adds just a single extra train going up and down
* - the extra passenger numbers will make a Melkshan rail linked local bus blindingly obvious
* - extra traffic will justify even more a human presence at Melksham station
* - note also massive extra through traffic from Chippenham to Trowbridge and beyond
* - projections based on current population - probably should be higher
Illustration - Melksham Station with and without a train
Posted by grahame at 12:08, 16th November 2024
I am asked what my opinion is on the granting of a license to operate trains, subject to certain conditions being met - "You must do this then you can".
Prime in "what's my view" is "what works for the passenger and wannabe passenger" and that's a close relative of "what's good for the area and it's economy" and should have a good relationship with "what works for a sustainable environment". Go-op, FGW, GWR, GBR, FirstBus, Faresaver, Stagecoach, BusesofSwindon, FromeBus, GoAhead, National Express and Seend Community Bus are all, or have been in my personal memory, or will be operators of public passenger services in the Melksham community area.  And which one of that dozen names actually operates the service you are on is of little interest, surveys tell us, to most people.
It's very interesting that what I am asked is for an opinion and an explanation and not an unadulterated expression of joy, isn't it?
Let's look forward at two possibilities, and I'm taking the Melksham Passengeresque view
The optimistic view
As from the December 2025 timetable, the train service seven days a week to Swindon will run at 2 trains every 2 hours in each direction. Realistically, it will not be possible to go clock-face and maintain connections along the way at this point, and I would anticipate the two trains being something like ... 12:30, 13:10, 14:30, 15:10 northbound and 12:10, 13:30, 14:10, 15:30 southbound which allows a freight path through Melksham at :50 in every hour.  The alternate trains at :30 connect from and to the Portsmouth Harbour service at Westbury, and the :10 service southbound every 2 hours carries on to Frome and Taunton. Please note peak and school time tuning to be applied such as the 15:30 I mentioned remaining at 15:40.
The ORR document mentions class 153 trains which are single carriages, and with accessible loos in them the seating capacity is limited.  However, TfW who have done the work (and I suspect these are the train that Go-op will use as they retire) have also retained 9 (classed 153-9) without a loo and I would look forward to seeing Go-op running two carriage trains (and needing to for capacity) quite soon.
As from the December 2026 timetable, with a Penryn / Dovey Junction / Bad Doberan style station at Melksham, it will become clock-face at :30 in both directions and that will allow 2 freight paths each way in the hour. With freight able to pass each other at Melksham so that's up from one to four freights per hour, and there's extra flexibility with them able to follow each other at tighter headway if nothing is coming the other way.
A further (community supported) service of a Town Bus vehicle connecting with the trains at xx:30 - arriving the station at xx:22 from Berryfield, Hampton West, Bowerhill Business, Pathfinder Way, Melksham East Relief Road stops, Sandridge Road and the Town Centre, and leaving at xx:38 back along the same route.
The Pessimistic view
Nothing starts beyond Taunton - Westbury in December 2025, but perhaps two or three of trains in the middle of the day extend to Swindon at some point in the following year. They run 20 minutes ahead of, or behind, the GWR / GBR service in the same direction so there are still 100 minute gaps in the service.  The DfT sees "duplication" as it did with the Bristol to London (Waterloo) via Westbury and Bristol to Brighton (via Westbury) services, and withdraws the TransWilts shuttle leaving just the 07:21 and 20:22 northbound, and 06:32 and 19:19 southbound on the national operation, and perhaps Go-op northbound services at 09:30, 12:30 and 15:30, southbound at 10:30, 13:30 and 16:30.
A business run on off-peak trains only would be hard to sustain I would suspect that the model I have just described would make it hard to break even, especially if things like mutual ticket acceptance was not in place and the train run by both companies shared the unreliability problems we see today, and I can see the Go-op experiment has a significant risk of failing, leaving Melksham back as it was in 2010 - just two trains each way per day, and the joke of "two trains - too early and too late to be of any practical use to most people" once again.
Both extreme possibilities ... and my crystal ball is prismatic and may be distorting what I see.
I would love to see the optimistic view fall into place and I am prepared and happy to support that as best I can.  I hope all other parties are too. I look carefully at who the decision makers are in each organisation, and what their motivation is, and what track record they have. "What turns them on" and  "Why are they doing this?"
Posted by eightonedee at 23:39, 15th November 2024
That seems to be a concern of ORR, too.
To quote the decision letter-
44.    Go-op’s limited rail experience and novel (in the rail sector) commercial model meant we considered it necessary to gather a reasonable degree of further evidence on Go-op’s ability to use the capacity in its application.
 45.    Following our assessment of Go-op’s operational plans and business model, we have concluded that the ongoing viability of these services is less clearly established than previous open access proposals approved by ORR. The resultant risks mean that we will be setting strict conditions precedent around Go-op’s ability to use the rights.
46. These conditions precedent will include a requirement to evidence, to ORR’s satisfaction and within 12 months of the contract being entered into: • the necessary finance to start operations; • the necessary finance to fund £1.5m of level crossing enhancements in advance of operations commencing; and • that the necessary rolling stock has been secured.
47. We will discuss the exact terms of the contract with the parties following publication of this decision letter. We recognise that the completion of level crossing enhancements is reliant on Network Rail, which has responsibilities as a competent infrastructure manager under its licence.
So this is only a conditional approval, and those conditions have to be met. I think the headline on the ORR press release is therefore somewhat misleading. I see from Go-op's website that a fund-raising campaign has been started to raise £2m. But as well as £1.5m of works, there's the costs of leasing the rolling stock, making arrangements to lease premises for storage and maintenance, set up the on-line infrastructure, the professional fees for negotiating the agreements with Network Rail and the Rosco (the latter will I imagine seek some kind of guarantee or security for their financial exposure), getting insurance and so on.
I can't help feeling that it would have been more efficient if there GWR could be persuaded (and allowed!) to acquire another (say) six trains on lease, recruit the additional staff and run additional trains along at least some of the route - say Taunton to Westbury and strengthening the Westbury-Swindon service.
Posted by Chris from Nailsea at 20:44, 15th November 2024
My ongoing concern is over the financial reality of this proposal.
I really do wish them all the best with their bid - but can they actually produce the funds, up front, to start it?
Posted by a-driver at 20:32, 15th November 2024
I can’t see how this can even work, unless you’re planning some lengthy dwell times at some stations like Westbury, Frome and Taunton to fit around the existing timetable. You’ve also got a huge 10-mile signal section between Castle Cary and Somerton. To squeeze anything through is going to prove problematic…. and 153’s. Not the quickest unit off the mark and with a top speed of 75mph.
Posted by Chris from Nailsea at 20:02, 15th November 2024
Yes.  It's set out on page 6 of those 14 pages, in paragraphs 32 to 34:
32. Network Rail has assessed the potential increase in risk at each level crossing that
would be affected by the proposed Go-op services. It identified that there were eight level
crossings where the increase in risk was identified as being beyond that which Network
Rail considered tolerable. Network Rail confirmed there were no improvements already
planned or underway. For these eight level crossings, Network Rail has identified solutions
to reduce the risk and has stated these should be in place before operations start.
33. Network Rail has estimated the total cost of improvements at these eight level
crossings is £1.5m (as of March 2024). The estimates are based on similar improvements
previously carried out on Western route. It has not undertaken site-specific assessments
for delivering the works at this stage. Go-op has said that the costs provided by Network
Rail are consistent with its budget as part of its investment strategy.
34. To support operational viability and safety at level crossings ORR will include
conditions within the track access contract requiring appropriate rolling stock to be secured
and the level crossing risk mitigations to be implemented in advance of the start of
operations. If these conditions are not met, the access rights will lapse.
Posted by ChrisB at 19:29, 15th November 2024
Do we know how many level crossings have work needed on them as required by ORR
Posted by anthony215 at 16:59, 15th November 2024
Personal post - I am noting the grant and thinking.
It will be a delight if the outcome is an appropriately enhanced train service linking Swindon, Chippenham, Melksham, Trowbridge, Westbury and Frome.  And the onward service to Taunton will be magic for people headed west as current connection from the TransWilts to there are "pants".
But ... I need to define "appropriately enhanced" and I can see various risks of it not reaching that definition.  I congratulate Alex Laurie on the approval and I will certainly be in touch to help make sure that all the parties involved work together so that it does come out appropriate.  He and his team have correctly identified, in my view, a market that the franchise / contract has failed to address and the abstraction data in the ORR letter confirms that.    And people would be initially delighted with class 153 carriages.   Much more for me to follow up on to define those really wooly words "appropriately enhanced".
Go-op will not have to do much to the 153s as tfw have done a great job refurbishing them
Posted by grahame at 16:21, 15th November 2024
Posted by bradshaw at 15:40, 15th November 2024
Note the rider ORR have added
As part of ORR’s decision, Go-op must provide evidence to ORR of the necessary finance to start operations, fund level crossing enhancements, and that the necessary rolling stock has been secured. ORR’s decision requires Go-op to do this without delay, and no later than November 2025.
Posted by Chris from Nailsea at 15:06, 15th November 2024
Thanks for posting, within a couple of minutes of each other, ReWind and RichardB: I've just merged posts into this existing topic.
Posted by RichardB at 15:00, 15th November 2024
Posted by ReWind at 14:58, 15th November 2024
Some positive news for the Wiltshire & Somerset constituents amongst us.  The ORR have approved new train services between Swindon - Taunton & Weston Super Mare.  Initially I assumed these would be via Bristol but reading the press release suggest these may run via Melksham & Westbury instead;
https://www.orr.gov.uk/search-news/regulator-approves-new-go-op-train-service-between-swindon-taunton-and-weston-super
Apologies if there were a more suitable sub thread to put this news in, instead.
Not sure what traction is lined up for this though.
Posted by anthony215 at 20:35, 19th December 2023
Probably 350/2's then I suspect as porternrook trying to get some fitted with batteries
Posted by RichardB at 23:40, 18th December 2023
Up to date list of Go-op's Directors   https://go-op.coop/go-ops-directors/
Posted by bradshaw at 12:21, 18th December 2023
Update on Go Op at Somerton
https://www.somersetlive.co.uk/news/somerset-news/somerton-station-uks-first-battery-8979178.amp
Posted by TonyK at 17:04, 13th December 2023
Are tickets on sale yet?
Posted by rogerpatenall at 12:19, 11th December 2023
A gentle corner - more a bend, like a coiled spring.
Posted by broadgage at 01:31, 11th December 2023
It all sounds splendid, but so did all the previous plans.
Perhaps it will actually happen this time ?
Posted by IndustryInsider at 16:36, 10th December 2023
Just around the corner then.
Posted by grahame at 16:29, 10th December 2023
An update on Facebook (here)
Co-incidentally, I wrote about the need for additional service between Westbury and Swindon just this weekend , and provided they were reliable and ticketing was such that people could use the next service no matter who was operating it, it'll be fine by the local community.   See http://www.passenger.chat/28245 - and should the northbound service carry on to Oxford, crossing an incoming southbound in the shown paths - why not.
Posted by grahame at 06:19, 15th May 2023
https://go-op.coop/our-planned-services/
In the autumn of 2022 a regular operational pattern was agreed that increases service levels, maintains punctuality and reliability, and helps passengers to plan journeys confidently. In many cases this will mean that they can switch from car to rail, with consequential reductions in congestion and pollution.
This significant overhaul of timetables in the Westbury area is expected to be introduced in May 2023 for GWR services, but Go-op has been obliged to delay its start to June 2024 to allow for improvements to level crossing safety. This will affect some existing services, as well as allowing Go-op’s services to be progressively introduced.
Our proposal for 2024
This shows the route that we plan to operate from the summer of 2024 on.
The core of the service between Taunton and Westbury is shown in purple. This will see six or more trains a day, improving the service levels in growing market towns.
They will also provide much needed connections for services to and from Yeovil, Salisbury and Exeter.
In addition, some services will be extended to Swindon; and we will also enhance travel up the Somerset coast with some extra trains between Taunton and Weston Super Mare.
Posted by grahame at 19:48, 24th February 2023
The responses are worth a look-see. GWR object on several grounds, which do include the timetable suggested.
As I read it, they object not only on various technical grounds but on the whole idea ...
This application it is believed is for ...
[snip]
GWR objects to all these aspirations.
GWR are right in having detailed and capacity concerns.
The application utilises the route through Melksham. This can be congested as it incorporates single line and is used by freight services. GWR has not always been able to expand its service on the route because of this.
A little disingenuous of you, GWR!   There have been a handful of situations where extra trains would not fit on the single line.  However, there have been many more circumstances where line capacity has been available, but there has been no train available, no crew available, no funding available and ongoing to thi s day, GWR is failing to run trains not due to capacity issues on the line, but lack of crew.
There are practical things to be learned during times of diversion:
24 trains in 24 hours last week (Friday 17th)
24 trains in 12 hours this morning (Friday 24th) ... 24 expected in the 24 hours
So I make it that in normal times a further half dozen each way might fit
Posted by grahame at 13:18, 27th December 2022
[snip]
I share some of the concerns expresses in the responses, and answers from Cross Country (for example) are well measured.  GWR seems to have looked for every possible reason to object, and in my view has weakened its case and its moral standing by so doing.
Posted by ChrisB at 12:24, 27th December 2022
The application & responses are now on the ORR website under section 17 applications
https://www.orr.gov.uk/rail-guidance-compliance/network-access/regulated-networks/network-rail/current-applications
There is also a draft contract on that ORR page.
Posted by paul7575 at 16:13, 3rd November 2022
No application on the ORRs website.  I'm.watching to see if hopefully grand unions application is successful
Apparently it’s on the NR track access application page. (However I haven’t checked myself.)
Posted by anthony215 at 02:59, 3rd November 2022
Posted by RichardB at 21:33, 2nd November 2022
From Ethos-PR, posted 17th October
First Co-operatively Owned Rail Service On Track
An ambitious move to launch the UK’s first co-operatively managed rail service has moved a step closer as Go-op hands in a formal application to run services in the South West of England.
Go-op has applied to the Office of Rail and Road to run services between Taunton and Westbury, starting in 2023. This will see ten departures a day, improving the service levels in growing market towns, such as Frome and Melksham.
and later in the article
“A debate about private versus nationalised rail system misses out the benefits that a co-operatively owned train business can bring,” says Alex Lawrie. “We are confident that we can bring together the benefits of a community and worker focus to create a sound commercial operating model.”
I - and Melksham - will welcome additional services on what has only moved up from a useless to an infrequent (and still below appropriate) service over the years.  However, Go-op has been in the planning for so long that we'll believe it only when we see the first trains arrive. With a new and different operational model, I remain unconvinced that the business and case is robust for the long term; I hope that concern is mis-founded. The route / flows certainly are excellent ones for significant service improvement - the Go-op team are right in that analysis.
and before a wheel turns, there is the small task of raising a target of £1.1m from investors.........
Posted by grahame at 11:47, 2nd November 2022
Posted by broadgage at 02:08, 4th September 2022
Yes, I might complain about the trains being only 5 coaches long, unless this was demonstrably sufficient even at Christmas, Easter, Butlins days, and bank holiday weekends.
However a 5 car train from London to Minehead and return is a GREAT IMPROVEMENT over no trains and is therefore to be welcomed. And if overcrowded could hopefully be replaced with a full length train.
I might also complain about the hard seats and other negative aspects of the IETs, but again an inferior train is still a great improvement over no train and is still to be welcomed.
Posted by grahame at 18:28, 3rd September 2022
I admire their persistence, and am satisfied that public demand exists for a year round train service from Minehead to at least Taunton and preferably further afield.
There is demand ... with traffic across intermediate places too and let me see how some of those might string together.
-> Minehead to Taunton (new service)
-> Taunton to Frome (new service)
-> Frome via Westbury (improved service)
-> Westbury to Swindon (much better service)
-> Swindon to Oxford (new service)
-> Oxford to Bletchley (new service)
-> Bletchley to Bedford (better service)
Been the same for years - but there are differences since the Go-op stuff started.  Even the daily train from Frome to Taunton has been scrapped. Westbury to Swindon has increased from 2 to 9 each way per day then back down to 8, passenger numbers up 25 fold but still 2.5 hour gaps.    Swindon to Oxford is a lottery with connections at Didcot not always being connections and since Go-op started we have been promised, then denied electric trains to Oxford by GWR. Oxford to Bicester is another line that has been shut, reopened, built up and the line is being re-extended as far as Bletchley ....
Of course, there are all sorts of other ideas that could be floated.  The hourly  semi-fast from Paddington to Newbury and all stations to Taunton could extend to Minehead, passed at Taunton by the Penzance express.   But I expect someone would grumble about hard seats and the trains being only 5 carriages so not proper trains.  Probably need to ease the platform at Watchet, but I think there were similar concerns at Narbeth that were quickly fixed.
Posted by broadgage at 07:17, 2nd September 2022
Whilst the climate crisis is now last years news, concerns about petrol prices and road congestion remain. The existing bus service from Taunton to Minehead provides an acceptable service at off peak times but is almost unusable at busy times.
Actual progress is very limited.
Posted by grahame at 05:24, 2nd September 2022
I admire their persistance. But, sorry, I share the concern that even after a decade this remains unlikely to come off. I also remind members how other new service proposals have been mocked, and yet have been achieved.
When I look at Go-op, I am reminded of Derek Twigg, Parliamentary Under-Secretary of State for Transport speaking to contrast my campaign in summer 2006 on Radio 4's "Today" - "We cannot run a train service just for Mr Ellis"; Alex Lawrie and his team find themselves mocked but persistant too.  There are other similarities, such as a need to adjust the campaign along the way whilst retaining the core and the need to go through painfully slow process and wait for opportunities.  There are also big differences and I am personally nothing like as informed on Go-op as I was on TransWilts to evaluate all these things.  I am aware that after more than six long years of working with little apparent progress, most of our ducks on TransWilts lined up, remaining ones were coaxed into place, and that train service started not just for Mr Ellis's journeys but for 180,000 other journeys in the first year.
Posted by Ralph Ayres at 22:18, 1st September 2022
I share others' pessimism.  When this thread started 10 years ago things had already not been happening for quite some time.  A great pity, but somehow the people involved don't seem able to build up any momentum and I've rather lost interest in their announcements as they never seem to come to anything.  Starting an open access operation certainly isn't easy and the most recent (Lumo) seems to have taken around 7 years from inception to passenger-carrying, but Go-Op are well over that with nothing to show for it.  I'm not sure whether to admire or mock their persistence.
Posted by RichardB at 17:18, 31st August 2022
Where are they planning on operating from and to this month?
Still no chance of it happening as far as I’m concerned!
Here you go.   I can't see it happening either.
Posted by IndustryInsider at 11:41, 27th August 2022
Posted by grahame at 11:00, 27th August 2022
From Facebook (And I have managed to loose the link in posting!) - web site at https://go-op.coop
Here's possibly the most important update so far. Following a mandatory industry-wide consultation, GO-OP is currently in the process of formally applying to the ORR for a track access contract. The consultation was largely positive, with all of the established rail operators affected objecting to the GO-OP business plan. But here's the thing, and this was something of a very nice surprise, the Department for Transport supported the GO-OP plan.
So what does this mean? Well, after taking advice from our consultants, it was decided to go ahead with the application. We will know in 2 months time if we have been successful, but fully expect that to be the outcome. The minute that happens, we're hiring!
Other news? It's the GO-OP AGM on Sept 7th. A letter should now be with all GO-OP members containing much more detail which I will post here once they have had a chance to read it
Posted by paul7575 at 14:53, 10th January 2022
Anyone care to take a bet with me that this service probably won't ever be up and running in any meaningful manner and certainly won't be operating before the next Olympics?!
I guess you really meant here, back in 2012, the next Olympics to be held in the UK?
Posted by paul7575 at 14:51, 10th January 2022
“…everything hangs on a successful track access application.”
With a bit of luck ORR will turn down the whole idea of Go-Op. How long ago was the first announcement, and just how many random route options have been discussed ever since?
Posted by Rhydgaled at 14:23, 10th January 2022
Just checked their website - this says-
Rollingstock
A key part of GO-OP’s mission is to reduce environmental impacts travel and adopt sustainable modes of transport. A big leap forward for GO-OP in this area is the recent completion of an innovate UK funded feasibility study proving that a nine-tonne battery can be added to readily available 319 train sets to operate efficiently on non-electrified mainline routes – a solution known as a 769 IPEMU. GO-OP hopes to pave the way for the electrification of routes where overhead line power delivery is either incomplete or absent and impractical to install. It requires not only advanced battery technology on the train itself, but also lineside batteries to support rapid recharging. Further work is now underway to begin preparing units. This electrification of stations may also allow for an expansion of electric car club services, and interchange on to electric buses, in the future.
This is an ambitious project in itself, and will take at least the rest of 2021 to deliver. Therefore, in the first instance GO-OP plan to use Class 156s', diesel multiple-units, for a transitional service.
Note the bold I have added to the quote above and then see...
repurposed Class 153 units.  The configuration below - courtesy of Scotrail - is similar to what we anticipate we will launch with.
Has somebody looked at the ScotRail photograph and confused 153s with 156s? The configuration of the ScotRail class 153s has a large part of the vehicle dedicated to bicycle storage (so very few seats are provided) and, if I understand correctly, toilets which are not wheelchair-friendly. A fleet made up entirely of ScotRail-specification class 153s would therefore be unworkable for passenger services - you would probably have insufficient seating capacity and you would not meet PRM regulations unless you locked the toilets out of use and provided a toilet-less service.
(PRM = Persons of Reduced Mobility)
Posted by eightonedee at 11:30, 4th January 2022
Rollingstock
Have they abandoned the class 769 pipedream?
Posted by Timmer at 10:02, 4th January 2022
So they've moved on from using Pacers to Dogboxes. Progress I guess.
Posted by IndustryInsider at 09:02, 4th January 2022
I’m already looking forward to the 2023 update.
Posted by grahame at 08:27, 4th January 2022
https://www.facebook.com/groups/mineheadraillinkgroup/posts/1579613502384694/
This post is just for those interested in how the GO-OP project is developing.  Here is a 2022 update as promised last year.
a) The very difficult challenge of acquiring suitable rolling stock has now been resolved.  Over the last 6 months a series of meetings with a major ROSCO and Network Rail has resulted in confirmed availability of repurposed Class 153 units.  The configuration below - courtesy of Scotrail - is similar to what we anticipate we will launch with.
b) Over the last 3 months, our reworked business plan - now based around the 153 units - has been circulated amongst all relevant stakeholders, with constructive and robust feedback for GO-OP to act on.  Meetings over the next 2 months will now determine just how this project will advance.
c) The long search for premises may now be over.  A large site near Chippenham has been inspected and the GO-OP board will be making a decision about this later this week.
So, will GO-OP commence operations this year as planned?  That is still the intention, but everything hangs on a successful track access application.  I will update this group when more news is available.
Posted by Rhydgaled at 12:04, 25th September 2021
News from a Taunton councillor at the Railfuture meeting today at Yatton is that Go-op plan to start the Bishops Lydeard to Swindon service in May or December 2022, using class 150 trains retired by Transport for Wales as their new class 19x come into service.
The availability of a reasonable number of relatively cheap-to-run PRM modified diesel trains in the form of the ex-TfW class 150s could be quite an opportunity for new services, whether run by Go-op or otherwise. I'm not sure how to react to the details though - my understanding was that the 150s were to be replaced by 231s and 756s (not by 197s) and not before 2023. The class 197s were originally planned to replace 158s and 175s in 2022 but that is an awful idea since the 158s and 175s are far superior trains to class 197s and the diesel-only 197s would derail any hope of electrification. If the plan has now changed to see 150s replaced by 197s in 2022 instead of 158s and 175s then that's great in some respects but not others.
Discussion of the merits (or otherwise) of the new fleet for TfW is a rather rapid diversion that is completely off-topic.
Not completely off-topic; it's relevant because if TfW aren't releasing 150s in 2022 then obviously the Taunton councillor's news is incorrect. Or, alternatively, if the Taunton councillor is correct then TfW are releasing 150s earlier than originally expected...
Posted by Lee at 20:26, 23rd September 2021
If but that were the only problem with Go-op's proposals...
Posted by Celestial at 19:14, 23rd September 2021
Posted by Rhydgaled at 15:23, 23rd September 2021
Posted by grahame at 07:33, 19th September 2021
Or even from Bishops Lydeard to Minehead !
May I suggest a really novel idea - have a Bishops Lydeard base in the MIDDLE of the route and run a public train service from Taunton to Minehead. Once successful (and the operator has good experience of running that public service), extend it.  Options there would include Taunton - Frome - Trowbridge - Swindon - Oxford - Milton Keynes to fill in gaps linking county towns across Central Southern England, and Bridgwater - Burnham - fast to Bristol suburban stations to supplement their slow and less-than-walkup frequency at present.
An example of a bay platform where a service from Minehead could terminate:
Posted by broadgage at 21:30, 18th September 2021
Posted by ellendune at 20:19, 18th September 2021
Excellent news if it is actually achieved, however Go-op do not have a great record of actually achieving their hopes.
And in the specific case of Bishops Lydeard (or elsewhere on the WSR) To any place on the national network, how many schemes have been talked about, and how many trains have run ?
Yes how about delivering a service from WSR to Taunton for a start and then see where else it might go.
Posted by broadgage at 19:47, 18th September 2021
Posted by Lee at 19:22, 18th September 2021
Indeed - I had the pleasure of witnessing the joint Go-op/TfL photoshoot earlier this week celebrating upcoming rail expansion:
Posted by rogerw at 18:48, 18th September 2021
As the cl769 do not seem to be appearing in the forseeable future perhaps GWR could grap those cl150s to ease the capacity problems in the WoE
Posted by grahame at 17:01, 18th September 2021
Posted by rogerw at 17:23, 27th July 2021
For those of you that like a fairy tale read at bedtime, there is an article on Go-Op in the latest edition of "Rail" (on sale tomorrow)
Posted by grahame at 15:47, 8th June 2021
For anybody who is not a member, but who may be interested in attending, a small payment for the minimum quantity of GO-OP`s convertible, interest-bearing shares will guarantee access to the AGM.
Great shame to apply that condition.
For community groups and their teams who are looking to work with all parties providing public transport in their area, holding a pecuniary interest in any company which might be competing for paths / advantage / contracts it leads to a potential conflict of interest.
It also gives me a similar personal decision to make as a Town Councillor in Melksham - if I were to show my support by buying a few shares, I would gain an interest which would mean that I could not take part in discussions nor votes asking for the support at the council, for which Go-op with surely (as a community co-operative) be seeking at some point.
It strikes me that the absence of guests at their meeting was potentially a difficult decision for Go-op - but that they may not have made the right decision by turning off people and community representatives who would love to use their services, in addition to others running on the line, should their service come about and call at Melksham.
Posted by grahame at 11:57, 8th June 2021
From https://www.facebook.com/gooptrain/ - a public post
Not an update - but something that may be interesting to visitors to this group.  In mid-July, it's the GO-OP AGM.  This will be open to all members, and at the AGM we can expect to be updated on all recent developments as the project continues to make progress - I`ll post more information here about the AGM shortly.  For anybody who is not a member, but who may be interested in attending, a small payment for the minimum quantity of GO-OP`s convertible, interest-bearing shares will guarantee access to the AGM.  Please note that as a co-operative, GO-OP shares cannot be traded.
Here is the relevant page from the website that provides links to the 2 categories of membership.
http://www.go-op.coop/join/
Posted by grahame at 12:25, 5th June 2021
A brief update (really no news) on this from the public question and answer section at the TransWilts CIC annual meeting on Thursday - an answer from a senior GWR manager was that "We [GWR] know as much as you [TransWilts member audience do". "Until platform 4 is reinstated at Westbury and there's substantial double tracking of the single line section, we don't believe there's room for a second operator". For TransWilts, a director commented that the draft Go-op timetable does provide two useful journeys each way per day, with the others within 30 minutes of an existing service, and they would much rather have any extra capacity used to point towards Salisbury and Southampton as in the TransWilts Strategic plan.
Posted by RichardB at 22:36, 19th May 2021
I did a double take when I saw this  -!
https://www.bbc.co.uk/news/business-57169730
I wonder if Gwyneth Paltrow is interested in running a train service between Bishop's Lydeard and Oxford.  Could have some unusual stuff on the trolley if so.  I think it would be very newsworthy.
Posted by Lee at 19:29, 19th May 2021
I guess this means that the Big Battery will have to be "consciously uncoupled" at the end of each operating day.
Posted by eightonedee at 18:49, 19th May 2021
Posted by paul7575 at 13:56, 12th May 2021
We need journalists prepared to actually challenge these proposals, rather than just republish fantasy PR verbatim.
Posted by Lee at 12:20, 12th May 2021
From the Melksham News
Story posted on May 12, 2021
Rail travel in Melksham could get a boost from a train operator proposing a significant addition to the rail timetable from summer 2022.
The proposal from GO-OP – an independent co-operative society – to provide passenger routes between Bishops Lydeard in Somerset (a station on the independent West Somerset Rail- way, not currently served by the main or connecting lines) and Swindon, could “significantly” increase the volume of services at Melksham by a third.
The service will provide an additional six departures a day from Melksham – an additional three services to Chippenham and Swindon; and three direct services connecting the town to Westbury, Frome, Castle Cary and Taunton.
And the service will open up more interchange possibilities, making trips to Salisbury, Southampton and Yeovil more viable.
((continues))
I'm surprised you weren't asked to comment, grahame.
I have to say I remain concerned at how the proposed Go-op service is being reported as if it is likely to go ahead, when even a cursory glance beneath the surface reveals multiple hurdles to be overcome.
Posted by grahame at 11:55, 12th May 2021
((continues))
Posted by grahame at 08:58, 4th May 2021
From the Wiltshire Times
A new train company is hoping to open up the south west and even the south coast to rail passengers from Wiltshire
Go-Op trains, a co-operative based in Taunton wants to run services from Swindon down through Wiltshire taking in Chippenham, Melksham, Trowbridge, and Westbury all the way to Weston Super Mare and Taunton and Bishops Lydeard.
It could even hook up with the heritage West Somerset Railway at the end of its route – allowing leisure passengers access to Minehead.
But the firm says the plan will be for commuters as well as those travelling for leisure.
Article continues ....
Posted by grahame at 18:16, 25th April 2021
...and thought to themselves "let's see how he likes it when we write the future timetable for his line!"
I am sure that's just me being "Mr Cynic" though...
I suspect it is, Lee.   There are some useful trains in there - not just the one picked out by Celestial.   There's headscrathers too.
I've gotten very technical on this on the Transport Scholars area ... http://www.passenger.char/24926 ... also dropped a note to the signatory on the timetable .... "Clearly a lot of work in there, but some things puzzle us. Is there background documentation?  Would love to help inform / tune from a community viewpoint if it’s still at that stage."
Posted by grahame at 20:06, 24th April 2021
Posted by stuving at 16:30, 24th April 2021
I won't be holding my breath.
I notice the really useful 1644 from Swindon has a note that says "Cancel one day every 24 weeks, and one day every four weeks."
So does that mean it is cancelled one day every four weeks, and then an additional cancellation every 24 weeks?
And why? Is it so that some maintenance schedule is kept (say a visit by a track recording vehicle), or maybe a very occasional freight path?
Measurement trains almost certainly. They do run on 4-, 8-, and 24-week schedules, and those are in the TPR  (national section). The last stable one I've got shows those runs at the wrong time of day to affect that service. However, from the version currently on line, it looks as if the timings are being revised.
Posted by Celestial at 15:44, 24th April 2021
Posted by Lee at 20:40, 23rd April 2021
From Go-op
PRESS RELEASE
Friday 23rd April 2021
Rail users co-operative adopts a viable timetable for Somerset and Wiltshire rail link Rail travel could get a boost in Somerset and Wiltshire as a new train operator adopts a significant addition to the rail timetables from summer 2022. The proposal from GO-OP, which unusually for the rail industry is a co-operative, includes connecting mainline rail with Bishops Lydeard on the independent West Somerset Railway line. By starting a not-for-profit business owned by those who travel on its trains and work for it, GO-OP’s ambition is to establish a new ‘rail corridor’ between Taunton and Swindon. Several stations in Somerset and Wiltshire that have limited levels of service such as Castle Cary, Frome, and Melksham will see significant increases in the number of departures; and connecting services will open up rail journeys that are currently impractical such as Taunton to Yeovil and Frome to Swindon.
Discussions between GO-OP and the West Somerset Railway could lead to a scheduled daily service linking the national rail network, via Taunton, to the heritage railway at Bishops Lydeard for the first time in 50 years. Passengers will be able to change there for leisure services to Minehead, and may also see an increase in bus services so that more people in West Somerset and North Devon can access the railway.
Further quote from "a WSR spokesperson" :
“The WSR has always encouraged train operators to run trains to connect with the very popular heritage steam trains that run from Bishops Lydeard to Minehead”, said a spokesperson for West Somerset Railway. “We are at an early stage and will continue discussions as GO-OP resolves the many issues involved in running on the national network."
Definitely looks like a fair bit of cooperation has taken place between WSR and Go-op on this:
“We have been working towards this point for many years since we first began meeting as a group of frustrated rail travellers”, said GO-OP’s Operations Director Alex Lawrie, “and for a while it looked like the pandemic might be one challenge too many. We are very grateful to the volunteers and staff of the West Somerset Railway, and to the many rail industry experts, who have enabled us to bring forward proposals that actually exceed our original ambitions in many ways.”
There's even a timetable, which would certainly have quite an impact on the TransWilts line, particularly in terms of the viability of future ambitions such as regular pattern services to Southampton, Oxford snd Birmingham.
It's almost as if someone at the WSR has read grahame's Minehead timetable proposals...
Footnote - a guess at what a National Rail service could look like
Year 1:
80 minute journeys ...
From Minehead at
05*45, 07#05, 09z00, 12w00, 15w00, 18:00 and 21:00
From Taunton at
07:05, 10w30, 13w30, 16z30, 18#00, 19:30 and 22*30
Don't like guessing ... wanted a bit of light relief from something else so had a play, and had a couple of nagging wonders if it would work.
* Crossing National Rail services at Williton ONLY
* Terminating at platform on Seaward Road directly beside / behind Butlins
* National Rail trains do not use Minehead heritage station which can be locked secure out of hours
Early train all year off Minehead handles connecting London and Bristol commuters
Second train is for Bristol / Cardiff ... school and commuters in to Taunton
Third train is hospital / shopping / leisure traffic
18:00 caters for commuters returning home from Minehead (pity about it being much earlier in summer?)
21:00 is final train for homebound people;  Bristol connection at Taunton M-F
First train off Taunton provides for commuters into Minehead
Next two in winter provide for daytime arrivals (time difference no great problem in summer?)
16:30, 17:55 and 19:30 are school / commuter returns (pity 16:30 is earlier in summer)
Late train inbound at 22:30 for the night owls
Norton Fitzwarren, Doniford, Crowcombe and Stogumber services possibly thinner than need be, pointing joerneys towards Taunton in the morning, back later in the day.
* Heritage trains cross at Crowcombe, Williton and Blue Anchor
* Heritage YELLOW timetable used - peak services only minor mods.
- Only mix of heritage and National is from 18:09 to 18:30 - cross at Crowcombe.
- Diesel heritage services call at Minehead (Seaward Road)
- Only first outbound / last inbound steam trains call at Seaward Road to avoid cutting into service time
Keeping an eye on both day trips out from Butlins and arrival / departures from there.
Some summer / through train concerns as might be a bit tight; want to avoid double change?  How about longer layover at Bishops Lydeard which allow for staff PNBs?    How important is through Bristol service during day in summer - are connection at Taunton for London ad the north more critical?   Changes at Bishops Lydeard - run National Rail terminators to bay so that it can be cross platform to / from heritage and National Rail will not get in way of steam run around.
Connections at Bishop's Lydeard quicker in one direction, slower in other for mechandising
All have some allowance for making up time
All services except 16:15 off Minehead have National Rail connections (no NR train avaiable)
Posted by rogerw at 20:02, 23rd April 2021
I'll say this for them. They don't give up. But it always seems to be next year. 12 months to introduction seems very optimistic given the procedures that have to be completed and trains to be acquired.
Posted by grahame at 19:14, 23rd April 2021
From Go-op
PRESS RELEASE
Posted by TonyK at 21:13, 21st January 2021
The long history of Go-op is certainly a factor which helps colour views of their proposals.
To be fair, 8 years is but a moment in railway projects. I am surprised they are still going for it, though, even if "it" changes often.
Posted by grahame at 21:06, 21st January 2021
Sorry grahame, force of habit. I have learned not to get too excited when I see Go-op over the past 8 years. I'll be wrong one day.
Posted by TonyK at 20:00, 21st January 2021
Posted by grahame at 16:34, 21st January 2021
It's something new to talk about for a few years, I suppose.
Hmmm ... or has Go-op now learned its way in to be making proposals where all the ducks line up? Answer, please, not here but in the "Transport Scholars" area - http://www.passenger.chat/24561 .
Posted by TonyK at 16:27, 21st January 2021
Posted by grahame at 16:15, 21st January 2021
From the Bishops Lydeard Facebook Page, that excellent source of news about plans on the TransWilts line
GO-OP is a co-operative society, planning to run an electric train service between Bishops Lydeard, Taunton & Swindon. They have launched a consultation about their plans. More details below in the link above and for our Transport scholar members at http://www.passenger.chat/24561 where I've just started a discussion on the issues.
Electric innovation in Bishops Lydeard? Your views are requested.
A project funded by Innovation UK is seeking to bring 21st century rail technology to the 19th century station at Bishops Lydeard ? a renewable energy generation and storage system for a battery powered train.
The "Transport Scholars" board referred to (above) is where we occasionally go deeply into specific subject - admins, moderators, data managers always there - other members very welcome if they wish to be.  Please like this topic if you would like me to add you in so the link works - I will check back from time to time until 25th January to follow up.  As an alternative, send me a personal message.  Sorry - Transport Scholars is a members-only area for regular contributors
Posted by eightonedee at 15:06, 12th July 2020
He talks a good game, but never mind what has actually happened, stating that his class 769 rolling stock would be delivered on time is possibly symptomatic of a lack of appreciation of what is really involved?  Even this time last year it seemed clear from information on this forum that the timescale was constantly slipping.  Anyone out there think he would have got his trains by January?
Posted by Celestial at 11:03, 12th July 2020
Missed this video - over a year old; sadly, a year is not a long time in setting up a rail service, so still worth a read.
Or maybe that should be a decade in Go-Op's case?
Posted by bobm at 10:49, 12th July 2020
Posted by grahame at 07:06, 12th July 2020
Building a co-operative train line: Alex Lawrie of Go-op
Posted by IndustryInsider at 17:06, 25th December 2019
Indeed.  And that probably won’t happen.  Though I still wonder how detailed their discussions have been thus far.
Posted by ChrisB at 17:04, 25th December 2019
They won’t sign on the rolling stock dotted line until they get a favourable response from the ORR applications
Posted by IndustryInsider at 16:09, 25th December 2019
I wonder how detailed their discussions with suppliers of said types of rolling stock have been?  You would imagine they are about to announce the deal(s) if they are to be working their trains within 18 months.
Posted by Rhydgaled at 09:52, 25th December 2019
For completeness of proposal, following from forms on the ORR website.
https://orr.gov.uk/__data/assets/pdf_file/0014/42044/go-op-open-access-economic-equilibrium-test-form-november-2019.pdf
Taunton – Castle Cary – Bruton* - Frome* - Westbury – Trowbridge – Melksham – Chippenham – Swindon
Two services each day may be extended beyond Taunton to Exeter with Exeter St David – Tiverton Parkway – Taunton; and two extended beyond Swindon with Swindon – Bristol Parkway.
No more than every two hours; southbound from Swindon at xx08, northbound from Westbury at xx15. First departure from Westbury after 0630, last arrival at Westbury before 2130. Stations marked * may be passed on some trips.
Class 319 IPEMU
https://orr.gov.uk/__data/assets/pdf_file/0013/42043/go-op-open-access-economic-equilibrium-test-form-2019-11-15.pdf
1. Taunton – Bishops Lydeard – Williton - Watchet (national network to Norton Fitzwarren Junction, West Somerset Railway beyond). Once per day each way, this will be extended with Taunton - Castle Cary or Taunton – Castle Cary – Frome.
2. Castle Cary – Yeovil Pen Mill – Yeovil Junction. Once per day each way, this may be extended with Frome – Castle Cary. Twice per day each way, this may be extended with Yeovil Junction – Sherborne – Templecombe – Gillingham; twice per day each way it may instead operate Castle Cary – Yeovil Pen Mill – Thornford – Yetminster – Maiden Newton – Dorchester West. These extensions may be needed to make efficient use of capacity, or to add regularity to services from market towns.
No more than every two hours; timings will be subject to discussion with GWR with the aim of approaching an hourly clockface service for Yeovil Pen Mill. First departure from either Frome or Castle Cary between 0500 and 0630, last arrival at Frome or Castle Cary between 2100 and 2230. This service is dependent on GO-OP securing rights for mainline Taunton – Swindon services which are the subject of a separate application.
Class 230 IPEMU
Interesting choice of rolling stock. Both 230 and 319 are suffixed IPEMU. The only other train that has been given that designation as far as I can recall is the class 379 battery prototype unit. In other words, IPEMU means battery trains without on-board diesel generator. Vivarail has their rapid-charge concept for the 230s, but the 319 would only have a little bit of OverHead - Line Equipment (OHLE) between Chippenham and Swindon to charge up the batteries. I didn't think that battery technology had advanced enough to allow such range.
Edit: VickiS - Clarifying acronym
Posted by grahame at 15:19, 20th December 2019
Class 319 IPEMU
Class 230 IPEMU
Posted by TonyK at 12:13, 20th December 2019
And another service application from Taunton to Watchet, one of which may start from Castle Cary or Frome, and another from Castle Cary to Yeovil, some of which may, or may not, be extended to Dorchester or Gillingham.
I didn't think there was much spare capacity on the lines around Yeovil for a Viva Rail 230 to trundle around getting in GWR and SWR's way, especially now SWR has filled in some of the gaps.
Taunton to Watchet? Why not Minehead?
Posted by IndustryInsider at 12:00, 20th December 2019
Good to see the plans are at such an advanced stage after all these years.  I’m looking forward to travelling on the first train in 18 months time, though I won’t book any overnight accommodation yet as I’ve no idea where the train will be running to or from!
Posted by Celestial at 11:53, 20th December 2019
Posted by grahame at 11:17, 20th December 2019
From Transport Extra
Prospective open access train operator Go-Op Co-operative Ltd has submitted new applications to the Office of Rail and Road for services in southwest England from May 2021.
The primary application covers a service between Taunton and Swindon via Castle Cary, Frome, Westbury, Trowbridge, Melksham, and Chippenham.
Trains would operate no more than every two hours and two services each day could be extended beyond Taunton to Exeter St David’s and beyond Swindon to Bristol...
Posted by grahame at 11:34, 26th August 2019
I have the tools now that you have supplied the link - thank you
The information available at this point is clearly limited and high-level, providing a number of options for proposed routes and extremely limited information on the service pattern and rolling stock. Therefore, it is challenging to understand the extent of the impacts (and whether they would be substantial) upon the economic equilibrium of numerous public service contracts.
Posted by Celestial at 11:27, 26th August 2019
I see the DfT also think the application is rather vague and woolly.
https://orr.gov.uk/__data/assets/pdf_file/0004/41593/go-op_economic_equilibrium_test_notification.pdf
(Sorry, I can't paste a quote, but the first paragraph of the DfT's letter says so, although in more polite terms.)
Posted by grahame at 06:18, 21st June 2019
So curiously Go-op has now applied for a service that goes nowhere near Oxford, but ...
I can't help thinking that all the time and energy spent in dreaming up routes and dreaming of running their own trains might not have been better spent engaging with GWR or other TOCs lobbying for services to fill gaps in current services and carrying out customer research to demonstrate that there's demand to justify them.
I'm noting these comments and went to sleep (after an eventful day that "Transport Scholars" will have read about) answering in my mind - and it's a very long answer.
You are right to raise these issues - and more. Yet some of them have significant and excellent answers and whist certain concerns remained to be resolved, others are far more logically correct from looking at public evidence in numbers than you might expect.   A full answer to follow as I get the opportunity - just wanted to flag "not as daft as you might speculate".
I'm running out of time to post a major reply here ... please excuse this brain dump.  No doubt - lots of spelling and grandma mistakes (  )  and double dipped claims of the same dividend.
In summary, I believe that there is double-plus evidence reaching the same conclusion in different directions, that there are untapped passengers flows - unaddressed travel requirements - on just about all legs of the proposed / suggested Go-op routes. There may not be a glossy case statement, the result of an expensive survey putting this particuar set of evidence together, but there's some pretty well known stuff in the 'right circles' there and I could easily enough cobble together a paper if only I had the time.  And, yes, I note the tails now wagging with Nuneaton becoming Newport and we're back to Dorchester and Taunton. The areas are riddled with good cases - some gooder than others.
Just because there are good cases, services will only work if all the ducks are in a row. Trains, paths, crew, price, passenger confidence in the service, timed when they want to go, advertised, appropriate cross ticketing and easy ticket purchase, information, comfort, ability to share station facilities, etc.  I know some of those overlap something rotten - this is a very quick morning note not a full list or report.   For a franchised service, or one sponsored by a local authority or grant body for a trial, risk looms huge, with elimination of public / taxpayer risk being frustratingly high up the agenda.  Political expedience and planning something which fits best into a grand overall government infrastructure is also key and can frustratingly hold a scheme back (or propel it forward even if risky!). But with an open access provider, only the safety risks and the risks of the service interfering with someone else's trains really need to be robustly and publicly considered - it's their shareholders who take the financial risk in the setup, and the risks of carrying fresh air or of not having enough serviceable trains or staff to run the service.  So if they're happy, that means far less studies for open access. We 'grin' at the lack of detailed studies, etc, on parts of the route, perhaps.   Or perhaps we are simply not privy to matters commercial in confidence.  Either way, that's OK.
I do look at some previous open access services and note their lack of robustness over quite short lead times. And for than reason I was concerned at an earlier point at suggestions that my town's service might almost exclusively be run by such a service.   The risk of it going "belly up" in early build-up days was a risk I would prefer to be without, and such a risk if perceived in public would put people off making life changing decisions based on the service in question.  Open Access has no government guaranteed safety new such as that we see repeatedly used on service such as franchised express trains from London via Peterborough. And this lack of guarantee on an operation that provides virtually all services to a place would be a hurdle putting people off using it - no safety net - resulting in many having an objection to using it, and traffic not being what they wished.
Now – take a line / service that's running anyway - that's moved up from an unusable service of 2 trains each way per day to a frankly poor service of 8 or 9 trains each way per day.  Serving a town which should generate 350,000 journeys per annum but which has only moved up from 3,000 to 75,000 and paused there because no more people could fit on the trains.  And whilst the trains are longer is still growing again only slowly because of gaps of 132 minutes (and going up to 150 minutes!) at peak shoulders for a typical journey of 10 to 28 minutes and you see a gap which could be well filled by another service combed in, to the mutual profitable benefit of both operators.  Food for thought, and I can come up with other data that's not purely Melksham numbers but for the line / service as a whole, less spectacular in proportion, but far higher in magnitude.
I am not reaching any conclusion as to whether all ducks are in a row. But I have some more evidence and more thought than many that, perhaps, they are. And I have far more evidence and thought that a combined service that's hourly on the Swindon - Chippenham - Melksham - Trowbridge - Westbury - Frome - Yeovil and/or Taunton corridors would / will be capable of generating spectacular further passenger numbers growth, however changes of train at Westbury work out; in may ways, it's two different flows joined end to end.
Edit to correct some of the more major spelling issues, and highlight key points in the mass of text!
Posted by grahame at 09:53, 20th June 2019
Posted by TonyK at 19:51, 19th June 2019
Which thought occurred to me also. Permission to run five trains daily from Euston to Blackpool North by Alliance Rail Holdings subsidiary Grand Central has been granted from September. This must have taken years out of someone's life, with a lot of expense and no income. The first try ended in failure, when they got the permission but couldn't source Pendolinos. This time, the proposal is to use Class 91s, which, because they can't tilt (or at least can't straighten up if they do) are limited to 110 mph. This means the trains will stop only at Nuneaton and Milton Keynes before Preston, thereafter making a decent local stopping service to Blackpool North. In this, they are up against Virgin, with three or four daily direct trains, at a time when the big operators are grumbling about lack of profit. I can't honestly see the point.
Re: Go-Op Cooperative - proposals for additional rail services (merged posts)
Posted by eightonedee at 19:10, 19th June 2019
Posted by Celestial at 17:50, 19th June 2019
So curiously Go-op has now applied for a service that goes nowhere near Oxford, but may go to Newport, or may go to Cheltenham.  And it may go to Exeter, or if not to Dorchester, or if not to.... oh I give up.
It seems odd that after so many years they still can't decide where they want to go, and even make an application which leaves all the options open.  I can't imagine they will be taken very seriously.  Why don't they just start with something simple like Westbury to Oxford, and if that works built up from there.  At least all of them involve an extra train every two hours through Melksham, which I presume will please Grahame.
https://orr.gov.uk/__data/assets/pdf_file/0004/41278/open-access-economic-equilibrium-test-form-go-op-june-2019.pdf
From https://greatbritishrailways.info/t11010.html?topic=11010.msg267488 - go insecure
