Problems with Hitachi Intercity Express Trains - discussions from 1 January 2026 onwards
Posted by ChrisB at 19:39, 15th December 2025
Chime Whistle Publishing tweeted earlier and here and here
I've just been sent the GW timetable amendments, due to come into force from 5 January, in reaction to the ongoing fuel pump issues.
Stopping short, DMU vice IET, additional station stops etc.
Two examples are 2E74 19.08 Bristol TM to Gloucester and 2T63 20.09 return.
I can not find any further detail yet, but GWR will have to load them fairly soon. Eyes peeled, folks.
Re: Problems with Hitachi Intercity Express Trains - discussions from 1 January 2026 onwards
Posted by Timmer at 07:05, 16th December 2025
This was posted by Plymouth based train driver ‘irish_mail’ on RailUK Forums:
https://www.railforums.co.uk/threads/iet-availability.293921/
I'm led to believe that we are to return to the "bad old days" of 802s only on the WofE route, and 800s being used more or less exclusively only east of Exeter. This will of course lead to potential shortforms and cancellations on SW services if an 800 cannot readily substitute for an 802 as is commonplace at present. It's noticeable since 800s began coming to the far south west regularly (since Covid), that there have been fewer short forms , and more 9 car trains and a better overall service on GWRs "most intercity" route. These changes are apparently needed as the 800s are being downrated power wise, whilst the 802s will remain with the higher power settings needed for the more challenging WofE route. So slower journey times on 800 served routes, and less stock availability on 802 WofE routes. What isn't to like.........
On another thread it was raised about an unreliable source vs a reliable source. I do tend to find irish_rail’s posts fairly well informed, but take this as you find it. As ever, time will tell.
Posted by ChrisB at 17:30, 30th December 2025
As for a timetable change.... The number of GU's isolated has dropped significantly so I can't see them making that decision now.  They believe the problem is related to contaminated fuel (salt specifically)
Chime Whistle Publishing has retweeted his claim about this timetable change, saying yesterday -
Revised timetable coming into force from 5 January, to allow for two trains to have ten hour repair slots in depot.
Posted by Timmer at 19:03, 30th December 2025
GWR don’t appear as yet to have published a list of altered services or maybe they are only rolling stock changes?
Posted by Chris from Nailsea at 19:09, 30th December 2025
As we were already up to page 23 of pages of posts on the previous topic (at https://www.firstgreatwestern.info/coffeeshop/index.php?topic=24934.0 ), I have now started yet another topic here - hopefully, to keep the discussion into more manageable chunks, in the interests of clarity and ease of future reference.
Hope this helps.  CfN.  Image not available to guests
Posted by a-driver at 19:39, 30th December 2025
Sounds more of a few tweaks to diagrams to release two sets for longer on depot rather then a whole timetable change.
Posted by ChrisB at 20:12, 30th December 2025
extra stops are promised on some services....as an example. no one claimed a full rewrite
Posted by Worcester_Passenger at 14:55, 31st December 2025
I'm hoping that posting on this 'new' topic on December 31 os OK.
Prompted by some comments in a recent edition of Modern Railways, I’ve been looking at scheduled and actual running times.  I’ve used the data from RTT for the Mondays-to-Fridays from November 3 to December 12, for the section of the Cotswold line between Ascott and Evesham. These timings are only to the nearest minute at each location.
I looked at trains that do the ‘standard’ calls, at Kingham, Moreton and Honeybourne, and I excluded the trains with ‘padding’ in their timings (mostly in the up direction in the late afternoon). The ‘standard’ working timetable timing for down trains (pass Ascott to arrive Evesham) is 30 or 30.5 minutes (the variation is down to the dwell time at Honeybourne); in the up direction (depart Evesham to pass Ascott) it is 30.5 or 31 minutes.
I excluded Friday November 14 – there was an issue about defective track between Evesham and Moreton.  I also excluded an occasion when the ‘halts’ train was cancelled (when the following train did these calls), and a couple of occasions when trains skipped stops to catch up with the timetable.
That left me with 476 timings in the down direction and 327 in the up direction.
I’ve plotted the results as cumulative distributions on the two attached charts.  In the down direction, the scheduled running time is 30.25 minutes, depending on the dwell time at Honeybourne. But the median actual running time (achieved by half of the trains) is 32.5 minutes.  And 25% of trains take 34 minutes or longer – some 12% slower than the timetable.
Only 26% of trains take 31 minutes or less.
The chart for the up direction is broadly similar – a scheduled average of 30.75 minutes, a median of 32.5 minutes, and 28% taking 34 minutes or longer.
What this is telling me is that the trains can’t keep up with the current timetable, and that it’s not all surprising to find them being turned short – down Hereford trains only getting as far as Malvern and so on.
The Cotswold line may well suffer badly in this regard – the standard calling pattern between Oxford and Worcester Shrub Hill (57 miles) has 8 intermediate stops, so the station-to-station distance averages out at 6.3 miles. Over that distance, acceleration is very important, and that will be badly affected by engines that are not working.
Unless Hitachi can get the engines working properly soon, an emergency timetable looks very likely.
Posted by Chris from Nailsea at 15:26, 31st December 2025
I'm hoping that posting on this 'new' topic on December 31 is OK.
I'm comfortable with your post appearing here, Worcester_Passenger. Your excellent research will no doubt provide very useful reference material in this ongoing discussion.
Posted by Worcester_Passenger at 16:42, 31st December 2025
Thanks!
Posted by ChrisB at 16:55, 31st December 2025
Just DM'd you, Worcester Passenger!
Posted by IndustryInsider at 10:05, 1st January 2026
Yes, it’s interesting data and well done for producing it.
I don’t wish to pour any scorn on it…but…
There are a few related issues that need to be factored in.
1)  The data is mostly within the leaf fall period.  IETs are better at dealing with that than all the traction that has recently operated along the line - Turbos, 180s, and (especially) HSTs.  But their performance will be affected by wheelslip/slide and the more defensive technique drivers will be using to mitigate its affects.
2)  There has been a long speed restriction of 40mph between Campden Tunnel and Honeybourne in the down direction.  I forget exactly when it was introduced but it would have been during the data period at some point.  It’s over 2 miles long so is causing an additional minute at least to be added.
3) The SRT’s among that stretch of line are generally very tight, so all it takes is for a small station delay to make it impossible to keep to time even with all engines firing.
I guess without another set of data at the same time of year when there are no/few engines isolated amongst the fleet, it is difficult to know exactly what delays are being specifically caused by the current poor engine availability.
Posted by Mark A at 10:21, 1st January 2026
Thanks for this. SRT is another acronym to pop in the acronmym box, mind.
Posted by Chris from Nailsea at 10:39, 1st January 2026
Done!  My first for 2026.  Image not available to guests
