Great Western Coffee Shop
15.6.2025 (Sunday) 14:47 - All running AOK
Re: Weymouth - Westbury cancellations, 14 and 15 June 2025
In "Heart of Wessex" [362297/30356/19]
Posted by Timmer at 13:20, 15th June 2025
The 13.32 Swindon to Weymouth has been reinstated from Westbury to Weymouth so one cheer rather than two that someone has been found to provide cover for part of the journey.
Re: Looe Branch Line - timetables, cancellations, engineering work, closures and incidents
In "Shorter journeys in Plymouth and Cornwall" [362296/569/25]
Posted by a-driver at 13:18, 15th June 2025
GWR had years to address this issue when it was in their control before the DfT tightened their grip. Instead of doing so they left it on the "too difficult" pile.
It's never been within GWR's control.  That was the whole point of privatisation!
In "Shorter journeys in Plymouth and Cornwall" [362295/569/25]
Posted by TaplowGreen at 12:52, 15th June 2025
Cancellations to services between Liskeard and Looe
Due to a shortage of train crew between Liskeard and Looe the line is closed.
Train services running to and from these stations may be cancelled. Disruption is expected until 15:00 15/06.
Due to crew shortages, we are unable to run train services today.
An astonishing failure ... on what would be a peak early summer's day.   Should someone come back and explain that there's a local transmitted flu or something else that has struck all the crews in the last 24 hours, this service decimation is "unforgivable" ... but of course it will probably get forgotten in the mists of time and the fog of the next issue.
Two questions when something goes wrong:
1. What lessons will be learned from today?
2. How will those lessons result in actions which make sure this should not happen again?
1.  Lessons were learnt a long time ago.
2.  “7-day railway” discussions have been ongoing for sometime, unfortunately the DfT  won’t release any further funding to resolve the issue. They want to continue with the “cheap sticky plaster” fixes which we all know doesn’t work.
The issue isn’t with GWR. GWR run the operation as per the contract outlined by the DfT.  It’s for the DfT to sort.
In "Heart of Wessex" [362294/30356/19]
Posted by TaplowGreen at 12:49, 15th June 2025
Today being Fathers Day, when some families would like to have been able to have a day out in Weymouth, just for example?
Could it be that some GWR drivers / train manager are fathers too and we have a case of "More fathers than usual being required at home at the same time"
I'm sure virtually every Father working today feels the same.
The fact that the date has been in the calendar for some time however seems to have enabled other businesses who can operate basic workforce planning to sustain their service.
Re: Bus Service 205
In "Transport for London" [362293/30357/46]
Posted by stuving at 12:24, 15th June 2025
Already liked by rogerw
I understand the 30 is changing too and will provide a route as far as Euston from the current 205 stops too.
No - the 30 won't run west of Euston. The Paddington-Euston (and Kings Cross too) route will be covered by 27 and 205, each part-way and overlapping.
Re: 2025 - Service update and amendment log, Swindon <-> Westbury
In "TransWilts line" [362292/29726/18]
Posted by grahame at 11:42, 15th June 2025
16:43 Frome to Swindon due 17:34
16:43 Frome to Swindon due 17:34 will be terminated at Westbury.
It will no longer call at Trowbridge, Melksham, Chippenham and Swindon.
17:44 Swindon to Salisbury due 18:55
17:44 Swindon to Salisbury due 18:55 will be cancelled.
Re: Heathfield Tunnel reopens to walkers for 60th anniversary
In "The Wider Picture in the United Kingdom" [362291/30355/51]
Posted by Mark A at 11:38, 15th June 2025
Hoping the spiral ramp bit attracts a gardening group too, it's compact, defined, manageable, prominent.
Re: Melksham's rail service - where are we, on the anniversary of being Beechinged?
In "TransWilts line" [362290/30162/18]
Posted by grahame at 11:37, 15th June 2025
Further pictures from our legal art wall, new art and the artists at work.
In "Shorter journeys in Plymouth and Cornwall" [362289/569/25]
Posted by grahame at 11:17, 15th June 2025
What do you think the future holds for local Rail User Groups when it's all owned and run by the nation?
That is a superb question.
"What do you think" ... I think (I know!!) that I don't know enough about what the future holds.  I can visualise good and bad scenarios; the question comes do we [just] wait and see or do we look to partner and persuade in what gets set up or not, and in what authority it has.
In "Shorter journeys in Plymouth and Cornwall" [362288/569/25]
Posted by a-driver at 11:10, 15th June 2025
I look forward to the time that everything is owned and run by the nation so there won't be (sometimes correct) buck passing.  I just fear that the nation will follow the time lines taken by the DfT which is the nation and things will get done far far far too slowly if at all.
In "The Wider Picture in the United Kingdom" [362287/30355/51]
Posted by grahame at 11:09, 15th June 2025
... I'm now thinking of examples of other instances of shortish tunnels in urban areas that don't acquire a bad rap, so it can be done ...
Indeed ... after MANY years of looking for a "solution" for the subway (= shortish tunnel) to Melksham Station, a solution has been found in a legal art all.  Not only the initial job, but now continuing.
In "Shorter journeys in Plymouth and Cornwall" [362286/569/25]
Posted by grahame at 10:53, 15th June 2025
In "Heart of Wessex" [362285/30356/19]
Posted by grahame at 10:50, 15th June 2025
Already liked by Chris from Nailsea, rogerw, Timmer, eightonedee
In "Shorter journeys in Plymouth and Cornwall" [362284/569/25]
Posted by a-driver at 10:46, 15th June 2025
Already liked by Mark A, rogerw, PhilWakely
In "The Wider Picture in the United Kingdom" [362283/30355/51]
Posted by Mark A at 10:45, 15th June 2025
It might be that in part that's because it's not open as a matter of course. It'll help if it's put on a more functional active travel route too - I'm now thinking of examples of other instances of shortish tunnels in urban areas that don't acquire a bad rap, so it can be done. The retrospective publicity around the 2007 opening very much hands the chalice to the people treating the location in an antisocial fashion  too.
Going off at a tangent, the sight of Heathfield Station's building and entrance on the road above the station site is a bit achy: here's Google Streetview.
https://tinyurl.com/4pr3f7yk
The disused stations site is informative on both the station and the line, and makes mention of its distinctive source of fuel for the station lighting.
http://www.disused-stations.org.uk/h/heathfield_sussex/
In "The Wider Picture in the United Kingdom" [362282/30355/51]
Posted by Ralph Ayres at 10:11, 15th June 2025
From Wikipedia:
In 2019, Wealden District Council stated: "due to constant vandalism and anti-social behaviour, the tunnel is to remain closed indefinitely with no plans to look into it".
So it seems occasional openings such as this will be all that happens, which is a pity. I wonder why this particular location suffers more than similar tunnels elsewhere such as in the Bristol/Bath area.
In "Heart of Wessex" [362281/30356/19]
Posted by Chris from Nailsea at 10:09, 15th June 2025
With thanks to my colleague Timmer for his update posts, I have now further expanded the heading of this whole topic, to draw attention to this very frustrating situation.
In "Shorter journeys in Plymouth and Cornwall" [362280/569/25]
Posted by TaplowGreen at 09:45, 15th June 2025
Multiple cancellations today due to crew shortage - the type of sunny weekend summer day when branch lines such as this get the chance to really show their worth, but GWR have failed to provide anyone to run them.
1) Judging by the repetition in similar circumstances across the region over a number of years, none.
2) They won't. GWR are staggering towards the end of their franchise, there is little or no motivation for them to make the efforts required.
In "TransWilts line" [362279/29726/18]
Posted by grahame at 09:38, 15th June 2025
Quoting from Heart of Wessex ...
Updated the subject title to reflect another bad day on the Heart of Wessex Line:
08.01 Weymouth - Bristol Parkway Cancelled
11.32 Swindon - Weymouth Cancelled
13.32 Swindon - Weymouth Cancelled
16.05 Weymouth - Bristol Temple Meads Part cancelled*
*starts at Westbury
Only four trains you may say, but on Sundays, where the service is a lot less frequent, that leaves some big gaps in the timetable.
Like yesterday, is this because of only Westbury crew signing Weymouth now?
On the TransWilts service, don't forget that the first round trip was a rail replacement bus this morning - not really a replacement but a substitution by something different and inferior.
A lot of TransWilts southbound in the morning use it for onward connections which leave Westbury (today) at ...
09:32 and 09:57 (yes, 2 at 25 minutes apart) for Weymouth
09:37 for London
09:54 for Penzance
10:02 for Portsmouth
and these would normally offer connections off the train from Swindon.   Guess what - the bus arrives at Westbury at 10:14 and that breaks all of these connections.   Only 2 other GWR trains are timetabled to leave Westbury before 11:00 and could be described as connection - 10:40 to London (by Real Time Trains tells me it's not expected until 11:10)  and a train at 10:41 which - oh dear - heads up to Swindon which is where the direction the bus came in from in the first place!
Re: Shortage of train crews on Great Western Railway - ongoing discussion
In "Across the West" [362278/18719/26]
Posted by TaplowGreen at 09:12, 15th June 2025
Summer Sunday, so.................
We have very limited road transport in place, taxis will shuttle hourly. Please note, they may not run to the train timetable. Please see station staff.
Re: 15th June 2018 - GWR Community Rail Conference
In "Diary - what's happening when?" [362277/19245/34]
Posted by grahame at 09:06, 15th June 2025
Came up "on this day". A conference that was the turning point (or rather brought things to a head) for me. Lovely to be back in Swindon yesterday - with European Passengers' Federation / TravelWatch SouthWest, and lovely to have local support there from the likes of the Gloucestershire and Oxfordshire CRPs helping bring in the local level. After the conference I travelled home and was joined by one of the key EPF officers who's stopping in the UK for a few more days, and we travelled on a nicely busy (running in time) TransWilts train where I left him as he carried on to make a connection in Westbury.
Re: North Cotswold line delays and cancellations - 2025
In "London to the Cotswolds" [362276/29711/14]
Posted by Worcester_Passenger at 09:02, 15th June 2025
Sunday June 15
15/06/25 07:36 London Paddington to Great Malvern due 10:15 will be started from Reading.
Last Updated:14/06/2025 20:13
RTT reports this as starting from Paddington.
15/06/25 13:12 Worcester Foregate Street to London Paddington due 15:24 will be cancelled.
Last Updated:14/06/2025 20:18
Re: Falmouth Branch Line - stations, facilities, services and improvements
In "Shorter journeys in Plymouth and Cornwall" [362275/33/25]
Posted by old original at 08:57, 15th June 2025
Naive question.  ........Could a 5 car IET go down the docks?
GWR sent an HST to Falmouth to celebrate the 150th Anniversary of the branch, so, probably, yes ?
but it would take longer to load / unload at the docks as only the front half would platformed and so a lot of passenegers would have to walk through the train...
In "Shorter journeys in Plymouth and Cornwall" [362274/569/25]
Posted by grahame at 08:57, 15th June 2025
Re: Bus Service 205
In "Transport for London" [362273/30357/46]
Posted by grahame at 08:10, 15th June 2025
Already liked by Worcester_Passenger, Chris from Nailsea
Your best bet in probably getting an 18 from bus stop R at "Bishops Bridge Road/Little Venice" (really between the two) which goes to Euston station itself. That's pretty close to Paddington - the traipse from Euston to St Pancras is longer, though still quicker in many cases than another bus.
Many ideas - and thanks for that one.  I understand the 30 is changing too and will provide a route as far as Euston from the current 205 stops too.
I have dropped TfL a note asking for official advice ... let's see how / if they respond.
I am a repeated but not frequent use of bus service 205 from Paddington to St Pancras, interchanging from main line trains from Wiltshire where I live to onward services via Eurostar and also to places like Cambridge. I am also a passenger advocate advising others how best to travel and a number of us have mobility and sensory issues that mean we need to minimise interchanges, distance moved and level changes, even if lifts are provided.
I am disappointed to read that the through bus will no longer run from Paddington to Kings Cross as from a weeks time.  We heard this news late in the day as I understand that consultations have been with London residents - which we are not - we are visitors who together help make your city work and help you justify the public transport which is usually very good.
1. What consultation was done and reach put out to groups like ours who use London's services but don't live there?
2. Is there an alternative I have missed of direct surface provision that works without an extra interchange for those who find the underground difficult?
You say "no personal information" BUT you are very welcome to share my details and get back in touch as appropriate - indeed I encourage you to do so to help make systems / alternatives better and well known - Graham
In "Shorter journeys in Plymouth and Cornwall" [362272/569/25]
Posted by TaplowGreen at 08:06, 15th June 2025
In "Shorter journeys in Plymouth and Cornwall" [362271/33/25]
Posted by PhilWakely at 08:03, 15th June 2025
Already liked by GBM
Tube driver knitting and watching TV
In "The Wider Picture in the United Kingdom" [362270/30361/51]
Posted by TaplowGreen at 07:55, 15th June 2025
Almost beyond belief, but thankfully no longer employed on the railway........
https://www.msn.com/en-gb/travel/news/tube-driver-caught-knitting-and-watching-video-on-his-phone-while-operating-northern-line-train/ar-AA1GH8in?ocid=socialshare
In "Heart of Wessex" [362269/30356/19]
Posted by Timmer at 07:53, 15th June 2025
*starts at Westbury
Re: European Passengers Federation - 13th and 14th June 2025
In "The Wider Picture Overseas" [362268/29670/52]
Posted by grahame at 06:30, 15th June 2025
What a fantastically useful and thought provoking conference!  It has helped set me up for a long time to come ... more to tell in coming posts perhaps, and certainly to trickle out over time as it helps me tune my thoughts and see the bigger picture.
